Southern California Area Southern California Members.
1LE Brake job done.... hope it works.
Old Apr 5, 2002 | 01:15 AM
JERRYWHO's Avatar
Just had to do some little changes to it.
Jerry
Old Apr 5, 2002 | 01:16 AM
JERRYWHO's Avatar
One more picture.
Old Apr 5, 2002 | 08:47 AM
BGNCHRS's Avatar
That is a VERY NICE JOB Jerry. :hail: Like those lightened rotors and BIG Wilwood binders.
I don't think you'll have a problem makin them work. Maybe an adjustable prop valve and check that the MC bore has enough volume to pump those binders up but I'm sure you know all that.
Barry F
Old Apr 5, 2002 | 10:12 AM
8T8IROC's Avatar
Car: Moving...
Engine: Running...
Transmission: Shifting...
Wow....
That looks awesome Jerry!
Old Apr 5, 2002 | 10:28 AM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
That looks way cool!:hail:
So do you have a list of what you have there?
I really like those Wilwoods
It looks like the only 1LE part is the spindle.
Old Apr 5, 2002 | 08:02 PM
BretD 88GTA's Avatar
Car: Yes...
Transmission: See "Engine"...
Looks good Jerry!
Are those street or drag rotors to save weight?
Old Apr 6, 2002 | 03:05 AM
JERRYWHO's Avatar
The spindles are factory GM 1LE parts. The rotors are Raybestos 1LE size #5994 and was 52 LBS out of the box per pair. The stock rotors are 42 Lbs and with some mill time the Raybestos 1LE rotors are now 37 per pair. The calipers hit the scale at 3 LBS each so with the thicker pads the total weight loss is 12 LBS.
My cars is more for drag racing so what i look for is weight reduction the most and if you get more stopping power thats good but is not needed for what i do.
Wilwood has six piston calipers if you need killer brakes on your car. The price for all the parts is in the high 900s and thats way more than the $391 for the parts on my car.
Jerry
Old Apr 19, 2002 | 08:20 PM
lasersi's Avatar
Jerry,
Has your friend completed the tubular a-arms with the spring perches for auto cross yet? If so is he selling them? Please let me know, or if possible, do you have an e-mail address for him? I would like to buy a set if possible.
Thanks,
Eric C.
1989 GTA
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
neekolzun
Aug 24, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
kyleb24
Aug 15, 2015 08:24 AM
