Manual Brake Conversion
Car: Trans Am
I have a manual brake conversion plate I bought from PA racing, but sold the car before I installed. I did mock it up, and it fits like a glove. It is made of aluminum plate, with studs to mount the master cylinder and bolts to mount to the firewall. I believe it cost me around $65.
SOLD
For that matter, I have a Mopar 1 1/32" master cylinder (with the deep well for a manual brake pushrod) PN P5249271. Also never installed. Cost me $125.
REMOVED
SOLD
REMOVED
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
still for sale?
what push rod do you need? is that included?
willing to make a package deal for it all?
how much for it shipped to 60506?
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
block is good as sold, are you wanting the cylinder? I`m trying to find out what the 1 inch size plus bore will do for pedal travel and pressure but if your taking it I understand
Car: Trans Am
Yes, the block is sold, but if you are looking for another give PA racing a call. It's not listed on their site but they can make you one.
Car: Trans Am
It uses 3/16" line, and comes with the appropriate hardware, so I'm going to assume SA, but not 100% sure. If you really need to know I can find out.
Edit: I believe the front (rear circuit) is 9/16-20 and the rear (front circuit) is 1/2-20.
Just got the plate in the mail, Thank you..feedback left for you
1992 Trans Am
May 10, 2023 07:19 PM
