Project Part Out. Performance and Looks
Car: 1986 Z28
Engine: 406
Axle/Gears: 9-inch w/ 3.50 posi
Well ive got afew things id like to sell. My project has went south and i have this stuff that i wont be needing.
1. Built 10bolt- 3.73 richmond gears, richmond powertrax locker, ta stud girdle, syn fluid, all new bearings, seals, welded axle tubes, new drum brakes and hardware. have receipts and pics. $400 prefer local pkup unless u arrange freight.
2. UMI lower control arms and panhard rod. Non-adj. NIB $150 plus shiping. Red
3. UMI bolt in lower control arm brackets. NIB $75 plus shipping Red
4. 4in lift off hardwood hood drilled for pins never painted still in black gel-coat. $175 plus freight. Will include new hood pin set.
5. Airbag setup for rear springs, dual bags and all hardware. NIB $60 plus shipping.
6. Spohn torque arm, and crossmember for TH350 swap w/ driveshaft loop. About 3000miles on it. $350 plus shipping.
7. Complete fuel system Aero pump, 20 ft of 8an and fittings, screw on filter base with filter. NIB. $300 plus shipping.
If intersted in any of this stuff send me a PM. Im sure there is more. Or u can call me at (573) 421-3467 could work out something on delivery if ur not to far. Thanks
Eric
Eric
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
Re: Project Part Out. Performance and Looks
lol it's harwood not hardwood
sorry just had to point it out, bump for the sale
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
im interested in the lca's and the panhard bar. how much would the shipping be to 32216?
Car: 1984 Z28
How much use on the 10 bolt? How did you like the Powertrax? 26 or 28 spline? New axles? Thanks for your time.
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
What kind of things are you looking to trade? interested in the Spohn torque arm
Car: 1988 firebird
Engine: 305 tpi
how much for shipping on the lower control arms and panhard bars to 32216?
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Car: 1992 25th Anniversary White W/ Red
Engine: Procharged 383CI/ Soon LS2 Turbo
Transmission: Manual 700R4
Axle/Gears: 4:11/Auburn Posi/Moser Axle
whats the deal with the air bags, why so cheap?
Car: 1986 Z28
Engine: 406
Come on guys make me some offers on the stuff. May accept trades just let me know what u have. THANKS
Car: 1986 Z28
Engine: 406
No thanks that is to cheap these are bnib. I paid 170 plus shipping. which was around $25.
Car: 1986 Z28
Engine: 406
bump
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
IS the fuel system for carb or FI?
Please send me all the info and Pics would be helpful.
Outstunn1@aol.com
Outstunn1@aol.com
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Is the fuel pump set up EFI???? Nitro
Car: 1986 Z28
Engine: 406
Everything is gone. Traded locally thanks for all the interest.
