FS: WORKING POWER ANTENNA AND OTHER POWER ANTENNA PARTS
Old Dec 23, 2007 | 08:17 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
I have a fully working power antenna that I just rebuilt for sale. I put in a brand new AC Delco rebuild kit and I cleaned and greased the parts inside and resealed the assembly. The mast is in fantastic shape, it only has one or two spots on it but it has no pitting or rust. I cleaned and lubricated the mast as well. The only thing I'm missing right now is the 90* part of the mounting bracket that screws on the mast that the bracket screws onto because the box it was in got thrown away. I'm going to see if GM still makes this part, and if not, I'll see if I have something to make the piece out of. This is everything you need to install a power antenna on a car that did not come with one.
I would like $100 shipped.
I had two antennas and I used the best parts from each plus the cable repair kit to make the best antenna since one of the masts was broken and won't come out for some reason. So I have some good left over parts. One of the antennas had been rebuilt sometime in the past, so I have what is basically the cable repair kit, but I'm not sure how much use it has had. I also have the housing with the motor, bezel, and the antenna nut.
Make an offer on what you need.
Old Dec 26, 2007 | 06:43 PM
Car: 2012 Corvette
Engine: LS3
Re: FS: WORKING POWER ANTENNA AND OTHER POWER ANTENNA PARTS
ttt
Old Dec 29, 2007 | 08:17 AM
Car: 2012 Corvette
Engine: LS3
ttt
Old Dec 31, 2007 | 06:17 AM
Car: 2012 Corvette
Engine: LS3
ttt
Old Jan 3, 2008 | 09:07 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
PM SENT
Old Jan 3, 2008 | 08:35 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
payment sent from breitstei@aol.com
Old Jan 4, 2008 | 04:45 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
when will it be shipped? the sooner the better
Old Jan 4, 2008 | 04:59 PM
Car: 2012 Corvette
Engine: LS3
It will ship tomorrow.
Old Jan 4, 2008 | 05:04 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
thank you
Old Jan 9, 2008 | 11:48 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
thanks man just got it today( afew mins ago it was very well packed and exactly what you described it as but just a question. where does the pink and orage wire connect to? also where does that mount suport ( thing in lil baggy ) mount to?
Old Jan 9, 2008 | 05:55 PM
Car: 2012 Corvette
Engine: LS3
I don't remember which is which off hand, but one wire needs to go to an always on 12v source and one goes to the amp trigger on your headunit. Both of them need to be powered for the antenna to go up and only one needs power for the antenna to go down. I'm wanting to say it's the pink wire that needs to go to the amp trigger, just touch the wires to your battery to make sure. The bracket in the bag mounts in the same spot the regular antenna mounts. You'll have to find some pictures of the antenna to see which way the bracket mounts to the mast because I don't have any for some reason.
Old Jan 9, 2008 | 06:39 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
thanks man
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
1nastygta
Aug 8, 2015 07:38 PM
