87-92 F body Serpentine Setup. ASP Crank Pulley and GM Delete Pulleys
Old Mar 14, 2008 | 06:56 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
GM 87-92 F-Body Serpentine Setup-Includes 100 Amp Alternator, PS pump, Brackets, Tensioner, Fasteners, new GM AC Delete Pulley and Smog Pump Delete Pulley, Water Pump Pulley, and USP Underdrive Pulley. Used $200 Shipped FIRM. Add 3% for paypal.
I WIL NOT SELL THE DELETE PULLEYS SEPERATE.
Old Mar 14, 2008 | 10:12 PM
87iroczzz's Avatar
Car: 1988 IROC-Z
Re: 87-92 F body Serpentine Setup. ASP Crank Pulley and GM Delete Pulleys
pm sent
Old Mar 14, 2008 | 11:52 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
I will take that smog delete pulley, How much?
Old Mar 15, 2008 | 02:40 PM
drain89's Avatar
bump
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
if you read his add it says " I WILL NOT SELL THE DELETE PULLIES SEPERATE"
Old Mar 15, 2008 | 02:56 PM
drain89's Avatar
I added that after he posted and I recieved 5 pm's wanting to know if I'd sell the smog delete pulley.
Old Mar 15, 2008 | 05:03 PM
ah ok my bad.
Old Mar 16, 2008 | 12:56 AM
camaro55427's Avatar
Car: 89 Iroc z
Engine: 350 carbed
Transmission: built 700 R4 2200 stall
Axle/Gears: 3.73 10 bolt
just a lil ? for ya, how did u get the pulley off the p/s pump so u can remove the bracket ha
Old Mar 16, 2008 | 01:02 AM
drain89's Avatar
I didn't remove the pump from the bracket. Just the bracket from the block. It requires a special puller to get that pulley off...
Old Mar 16, 2008 | 04:22 PM
drain89's Avatar
The alternator is a low mile remanufactured Delco-Remy 100A. So you basically you're getting everything for less than the price of the Alt, delete pulleys and underdrive crank pulley. That's like a serpentine upgrade for free.
Old Mar 17, 2008 | 10:45 PM
Car: 89 Iroc z
Engine: 350 carbed
oh ok, thought so wasnt sure well how did u get the bracket off cause the one bolt is behind the pulley
edit nvm found out
Old Mar 18, 2008 | 09:16 PM
drain89's Avatar
bump
Old Mar 19, 2008 | 05:21 PM
drain89's Avatar
sale pending
Old Mar 21, 2008 | 05:56 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
I'd buy the smog pump delete RIGHT now if your willing to part.
Old Mar 21, 2008 | 06:00 PM
drain89's Avatar
Sold-It shipped out this morning.
Old Mar 21, 2008 | 06:18 PM
drain89's Avatar
Just go to the dealer and ask for one from a 90's model saudi export caprice.
The middle east vehicles and I think Aussie ones didn't have all the emissions stuff we do.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
Street Lethal
Aug 12, 2015 11:33 AM
