slp dual cold air intake - k/n filters
Old Jun 15, 2008 | 09:00 PM
blkgta's Avatar
slp dual cold air intake - k/n filters - from 89 gta
nice shape - see photos
200.00
Old Jun 16, 2008 | 08:10 AM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Re: slp dual cold air intake - k/n filters
would this work on a camro if i moved bat and the canister?
Old Jun 16, 2008 | 09:04 PM
88 350 tpi formula's Avatar
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
where in illinois are you? I will take it. sent you a pm
Old Jun 16, 2008 | 10:33 PM
blkgta's Avatar
elmhurst , il - 5 miles from o'hare airport
pm sent
Old Jun 17, 2008 | 05:10 PM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
how much for shipping to 64093? thanks
Old Jun 17, 2008 | 09:05 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Moving the battery and canister are required regardless which car you put it on.
It is also for a 90-92 Speed Density TPI setup. There is no space for a MAF.
The kit also came with a different water outlet and radiator hose to re-route the hose (not sure if the seller is supplying it with the kit).
This is a very nice kit and had it on my 86 Trans Am with a 91 TPI setup.
Here is a larger image from my car so you can see how it looks.
blkgta, if you want me to remove the pic or edit my post, just ask me.
Old Jun 20, 2008 | 12:21 PM
blkgta's Avatar
sold - thank you
Old Oct 29, 2009 | 12:52 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
if im able to mount my maf between that small gap will i get some nice gains from this cai over the stock tpi intake on a built iroc
Old Oct 29, 2009 | 01:11 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Axle/Gears: 12 bolt 3.73 Eaton posi
No, there is physically no room to put it there.
Old Oct 29, 2009 | 09:08 AM
MADMAXGTA's Avatar
Car: 89 TTA
Awesome set up,for map systems,If i didnt have maf this would be sold.
Old Oct 29, 2009 | 10:17 AM
Car: 1987 IROC-Z
It was sold... Over a year ago...
Old Oct 29, 2009 | 10:18 AM
MADMAXGTA's Avatar
Car: 89 TTA
doooh.
Old Oct 29, 2009 | 12:41 PM
Drew's Avatar
I've got one I'd sell. But I'd want a lot more then $200 for it. LOL
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
