Aluminum Drive shaft
Old Aug 3, 2008 | 05:32 PM
88-I.R.O.C.'s Avatar
Car: 1988 IROC-Z
Engine: LS2
Axle/Gears: Strange 60 3:73
I have an aluminum Drive shaft. It will fit any 82-02 f-body manual or automatic. It will work with some after market rears. No u joints, i will install some if so desired(for cost of u-joints), but otherwise it is clean and ready to go. save weight!
$150 bo shipped anywhere in the US.
Old Aug 3, 2008 | 05:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Aluminum Drive shaft
IIRC, it won't fit TH350's 82-83.
JamesC
Old Aug 3, 2008 | 05:47 PM
Car: 1988 IROC-Z
Engine: LS2
JamesC
Could be All 700R4, 4l60, 4l80, t5, t56 should work i believe though
Old Aug 3, 2008 | 08:09 PM
eeeeeefirebird's Avatar
is it balanced? why are you selling it?
Old Aug 3, 2008 | 08:30 PM
Car: 1988 IROC-Z
Engine: LS2
From the factory it is balanced, i have S60, custom drive shaft needed.
Old Aug 3, 2008 | 08:34 PM
do you have any kind of part number? brand?
Old Aug 3, 2008 | 08:53 PM
Car: 1988 IROC-Z
Engine: LS2
It is stock OEM. I do not have a part #. Special option JG1 on the RPO sheet, which i have.
Old Aug 3, 2008 | 08:55 PM
ohk. so how much does it weigh versus stock driveshaft? app.. sorry for all the questions
Old Aug 3, 2008 | 09:23 PM
JamesC's Avatar
The p/n should be on the tail of the shaft (a metal label of some sort): 10085375.
JamesC
Old Aug 6, 2008 | 08:32 PM
powerslave's Avatar
Car: 87 Z28
Engine: TPI 350
Axle/Gears: 2:73
How long is it (center of U- Joint)?
Old Aug 6, 2008 | 08:37 PM
JamesC's Avatar
Center to center 41 1/2.
JamesC
Old Aug 11, 2008 | 07:58 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Still have the drive shaft for sale?
Old Aug 11, 2008 | 09:32 PM
Car: 1988 IROC-Z
Engine: LS2
yep
Old Aug 11, 2008 | 09:38 PM
dctrumpet's Avatar
Awesome. It does not have the transmission yoke or differential yoke correct? It's ok to use my factory yokes? 92 firebird TBI?
Old Aug 11, 2008 | 10:24 PM
Car: 1988 IROC-Z
Engine: LS2
Should be the same. If you want, for the price of the u-joints, i will put new u-joints in and include the old transmission yoke. The rear u-joint is strapped into the rear axle with 4 bolts. Whereas the front is joined to a yoke that slips into the transmission. Whatever you want to do. Just let me know.
Old Aug 11, 2008 | 10:26 PM
dctrumpet's Avatar
I assume the yokes are steel and not aluminum correct?
Old Aug 11, 2008 | 10:44 PM
Car: 1988 IROC-Z
Engine: LS2
the transmission yoke is steel
Old Aug 11, 2008 | 10:47 PM
dctrumpet's Avatar
The rear/differential yoke is aluminum? Will my stock front and rear yokes work? I think I am going to take it off your hands. $150 shipped to Illinois? Right?
I also assume that it has no issues while it was installed prior to your upgrade?
Old Aug 11, 2008 | 10:52 PM
Car: 1988 IROC-Z
Engine: LS2
Never saw this till now...hmmmm
IIRC a stocker steel is maybe 20-21#. I weighed mine and it weighed 11#. I think 1 pound rotating weight saved is the equivalent of removing 4 pounds that's not moving.
you have a pm
Last edited by 88-I.R.O.C.; Aug 11, 2008 at 10:53 PM. Reason: Automerged Doublepost
Old Aug 11, 2008 | 10:55 PM
dctrumpet's Avatar
PM? meaning yahoo or hotmail?
Old Aug 11, 2008 | 11:00 PM
Car: 1988 IROC-Z
Engine: LS2
There is no rear yoke. The u-joint slips into the driveshaft through the two holes, then the other half of the u-joint is strapped to the center section of the axle via two pieces of metal and 4 bolts. Really quite easy to change.
On here. Top right it should say your username and under that it should say Private messages Click there
Last edited by 88-I.R.O.C.; Aug 11, 2008 at 11:02 PM. Reason: Automerged Doublepost
Old Aug 11, 2008 | 11:06 PM
dctrumpet's Avatar
Duh! LOL. I did know that. I had to visualize what i was asking. PayPal? Tell me the terms
Old Aug 11, 2008 | 11:11 PM
Car: 1988 IROC-Z
Engine: LS2
proposed terms are in the pm, i do not like putting my e-mail on here for spam bots. Just shoot back a pm to me
Old Aug 11, 2008 | 11:20 PM
dctrumpet's Avatar
Just sent two PM's to you. Thanks
Old Aug 11, 2008 | 11:36 PM
Car: 1988 IROC-Z
Engine: LS2
SOLD
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
