[AR] SLP posi, install kit
Old Feb 23, 2009 | 06:10 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I bought a SLP posi pull out back when they were still selling them from the 02 f-bodys. Never installed it, and now I just flat replaced the axle. Anyway, It did make it thru a B&E in my storage unit, so the box it was in is trashed, but I dont think any damage was done to it. Asking 75 plus shipping.
I also bought an install kit from randys ring and pinion. This box is still un-opened, but I know whats in it. Asking 75 plus shipping for it also (I think I paid 100).
I go get quotes at my actual shipping place because the online quotes are not accurate. Post here so I know who has first dibs on what item, then give me a pm please with zipcode if you want shipping quotes.
Old Feb 23, 2009 | 08:04 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Re: SLP posi, install kit
What spline count on that slp? Never used, 3 series?
Old Feb 23, 2009 | 09:27 PM
gberri88's Avatar
Want a title? Post!
Car: 1987 Firebird Formula
Axle/Gears: 3:73 posi
what gear ratio is the ring and pinion and what size rearend will it fit?
Old Feb 23, 2009 | 10:16 PM
nicksL98's Avatar
I'll take the posi, PM sent
Old Feb 24, 2009 | 07:00 AM
Dale's Avatar
Engine: 350 S-TPI
gberri, I think it is for series3 gears.
Whatever fbodys and s10 rear ends are.. 10 bolt?
Old Feb 24, 2009 | 05:31 PM
Dale's Avatar
Engine: 350 S-TPI
slp posi is sold
Diffy/gear install kit still forsale. I see they have different versions, I dont know which one I got. I'll lower the price to 60+shipping for it.
Old Mar 8, 2009 | 04:48 AM
ahhwataday's Avatar
Car: 98 Camaro 00 lifted silverado
What type of bearings are in the install kit?
Old Mar 9, 2009 | 07:43 AM
Dale's Avatar
Engine: 350 S-TPI
His site advertises Timken bearings right now. Dont know if that is what he sold/used 4 years ago or not. As I mentioned, the package is still un-opened.
Old Mar 9, 2009 | 08:20 AM
ahhwataday's Avatar
I might grab them from you. I think I only need the pinion bearings, differential bearings and races though. Ill let you know either way.
Old Mar 9, 2009 | 11:06 AM
Dale's Avatar
Engine: 350 S-TPI
Let me know soon as you can. I've been putting lots of stuff on ebay lately to try and get some tires for my daily driver.
Old Mar 9, 2009 | 06:22 PM
ahhwataday's Avatar
Does the kit have differential bearings and races, Pinion bearings and races, crush sleave?
Old Mar 9, 2009 | 06:23 PM
ahhwataday's Avatar
Can you send me a pic of the kit please
Old Mar 9, 2009 | 07:53 PM
Dale's Avatar
Engine: 350 S-TPI
purchased on 9-1-05, paid 96.52
part yk gm7.5-b (hopefully link is correct) http://www.ringpinion.com/ProductDet...px?ProdID=1130
curret kit offers...
Yukon Master Overhaul Kit for '82-'99 GM 7.5" and 7.625" differential. This kit uses Timken Bearings and Races along with high quality seals and small parts. Included in this kit are carrier bearings and races, pinion bearings and races, pinion seal, complete shim kit, ring gear bolts, pinion nut, crush sleeve (if applicable), oil baffles and slingers (if applicable), Thread locking compound, marking compound with brush, and gasket. Yukon’s Master Overhaul kits are the most comprehensive and complete kits on the market. They do extensive research to ensure that every kit is specially tailored to your application. Includes super shims.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
toronto formula
Nov 10, 2015 06:17 AM
hectre13
Aug 26, 2015 08:17 AM
