[MD] Spohn, BMR, Random tech, B&M
Car: 86 z28, 87 IROC, 88 sc, 93 z28
Engine: LG4, LB9, LO3, LT1
Transmission: 700r4, T5, 700r4, 4L60
Axle/Gears: 3.73, 3.45, 2.73, 3.42
B&M Console Megashifter - Used – the thread on the stick is almost completely stripped - $75
350 block 2 piece rms, 4 bolt mains high nickel casting $100
LT1 Dual fan setup $40
(2) swing out kits NIB $40
Hypertech TPI ignition coil Used for less than 3k miles $30
Aeromotive universal fuel sump NIB $100
SOLD Spohn torque arm with t56 cross member mount- Used - spherical rod end and front drive shaft loop - $250
SOLD New Random Technologies transmission mount torque arm - $200
SOLD New weld in control arm relocation brackets - $45
SOLD Front control arms with new poly bushings and ball joints. Sand blasted and painted gloss black. $100
SOLD Used 2 inch lowering springs $100
SOLD LT1 PBR Brake setup $150
All prices do not include shipping. Parts are located in Frederick MD but I am back and forth between there and Knoxville, TN - Pick-up welcome.
Pictures can be found at http://good-times.webshots.com/album...swSGH?start=24
Last edited by 1986z28; Jun 21, 2010 at 08:27 PM. Reason: sold items and lower prices
Car: 1988 Camaro SC
Engine: Undecided
Transmission: Stock-for now.
Axle/Gears: Stock-for now.
Re: Spohn, BMR, Random tech, B&M
DrewsCam - The STB was sold a while back.
Gawboots - The block is from a '70s pickup - It was hot tanked and magnafluxed. It is ready to be machined and rebuilt. I bought the block about 5 years ago so I don't know anything else about it's history.
TTT offers?
Car: 1987 Chevy El Camino
Engine: 357 CID w/Lingerfelter Super Ram
Transmission: 700-R4
Axle/Gears: GN 8.5 342's
What is the best deal that you could give me on the Megashifter shipped to 91406?
Is it repairable, or does it need a new rod?
Thanks,
Dave
Thanks,
Dave
drb930 - The **** screws on but will it does not have enough thread left on the rod to keep it from spinning. If I was keeping my car an auto, I would drill through the bottom of the handle into the rod, tap them both, and use a small bolt to lock it in place. There are other ways it can be done and you can also buy short or tall rods from B&M.
I would do 130 shipped.
gregsz-28 - I do not want to split up the torque arm and crossmember. I don't think I can sell the crossmember on its own.
BrOdBaNd - The DS is sold.
TTT
gregsz-28 - You can make an offer
Replied. Lower prices and additional items included.
Car: 90 chevy camaro convertible iroc
Engine: 305 tpi
Transmission: 700r4 with hurst dual gate shifter
still have the lowering springs
Here are all of the springs that I have:
the ones for $100 + shipping are made by dropzone. I had them on my 86 for about 6 months before I parted it.
I have a brand new eibach pro-kit I would sell for $200 + shipping.
I also have a set of intrax front springs that I would sell for $60 + shipping. I had these on my iroc with chopped rear springs.
TTT I have updated all of the items that are sold and lowered the prices on everything remaining.
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Axle/Gears: 12 bolt 3.73 Eaton posi
How much for the power steering pump bracket from the end of page 2?
Car: 92 RS, 02 SS leather seats, eibach
Engine: Stock 305 at the moment.
Transmission: Stock M5.
Torque arm...
Standard Duty?
Pro Series?
T-56 from a 93-97 F-Body?
LSx Swap T-56?
Mild Steel?
Chrome moly?
Stock 10 bolt?
9 inch?
12 bolt?
Other?
Might as well throw color in there...
Standard Duty?
Pro Series?
LSx Swap T-56?
Mild Steel?
Chrome moly?
Stock 10 bolt?
9 inch?
12 bolt?
Other?
racing geek - I would have to find where put all od the accessories I need to part out lbp and an lt1 I have.
Standard Duty
Mild Steel
It will work with the stock or after market rear end with the factory style through bolt mount.
spherical rod end
front driveshaft loop
Red power coat
There is a link with pictures in the first post.
Standard Duty
Mild Steel
spherical rod end
Red power coat
TTT
Car: 1982' camaro Z/28
Engine: lt-1 out of a 95' impala ss
Transmission: viper spec t-56
Axle/Gears: Ford 9in 3.90 gears
what would you take for the ta is it a firm price?
I am firm on the price. I have already lowered it twice. Thanks
TTT lower prices and more items
I am firm on $250+ shipping. Thanks
