Mini Ram, Throttle body, Injectors, MAF,
Old Sep 7, 2009 | 03:14 PM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
Ok guys got a couple things for sale here. Ive decided to go in a different direction with my project. all items have about at least 5000 miles on them except the mini ram, i bought tht used. so heres whats for sale...
1) TPIS mini ram its your typical mini ram for standard bolt chevy heads, made an incredible difference on my 383 stroker with throttle repsonse and gas milage. comes with fuel rails, sensors and water kneck, paid 840 for it i'll let it go for 600 obo
2) BBK adlustable regulator for stock tpi setup, brand new, never been installed, in original box/packaging. paid 80 brand new from summit, let it go for 50 obo
3) BBK twin 58 throttle body paid 320 for it, let it go for 200 obo
4) ACCEL 32 lb injectors paid 280, let em gor for 180 obo
5) BOSCH Maf with cut screens dont remember how much i piad for it, 50 bucks obo
Thanks for looking
Old Sep 9, 2009 | 04:29 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Re: Mini Ram, Throttle body, Injectors, MAF,
Afternoon bump
Old Sep 11, 2009 | 04:36 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Nightly pump
Old Sep 11, 2009 | 04:39 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
will the BOSCH maf fit on my gta?? pm please...
Corvette Chris's Avatar
Car: 86 Corvette
Axle/Gears: 2.59 D36
PM sent on Miniram.
Old Sep 11, 2009 | 05:40 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
PM sent back chris
Old Sep 12, 2009 | 01:05 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
MAF sold
Pics of the mini ram
Old Sep 13, 2009 | 12:35 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
To the top...
Old Sep 13, 2009 | 07:19 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Mini ram sold
Still got some good parts here
Old Sep 18, 2009 | 07:58 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Bump...
Old Sep 21, 2009 | 04:44 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
To the top once again
Old Sep 22, 2009 | 11:04 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
have any pics of the 58mm bbk i can see please.
Old Sep 23, 2009 | 06:36 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
I'll post some up later tonite
Old Sep 24, 2009 | 01:44 AM
Car: 92 1500p\u 2wd
alright, ill keep an eye out for the pics!
Old Sep 24, 2009 | 01:54 PM
riverdog's Avatar
Car: 86 Z
Engine: 383 Mini Ram
Transmission: TCI Street Fighter 700R4
Got the mini ram today. Thanx.
Old Sep 27, 2009 | 02:07 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Sorry for the delay guys, my grandmother ended up in the hospital and ive been going to see her after work everyday for awhile. Heres some pics...
Injector numbers: 01D111B (32 lb)
Throttle body numbers: EO D-245-9
Old Sep 28, 2009 | 06:57 PM
Car: 92 1500p\u 2wd
when i look up that BBK number i get a 52mm not 58mm....
Old Sep 28, 2009 | 07:11 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
really? what website did you look it up on?
Old Sep 28, 2009 | 07:23 PM
Car: 92 1500p\u 2wd
i googled it.....also went to the bbk website and there numbers are d-245-13
Old Sep 30, 2009 | 02:39 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Sorry to hear about your grandmother. Hope she's doing better now!
The 01D111B number for the injectors doesn't show any results in Google. Zip, zilch, nada. Is there another number on the injectors? Maybe starting with 15?
Lou
Old Sep 30, 2009 | 04:37 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
None jus tht it says 32 lb and my camera sucks at taking pics, ive tryed every angle at takin it but it jus comes out like crap
Old Sep 30, 2009 | 04:39 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
As for the throttle body i dont wat else to tell ya, i ordered it from either summit or jegs and thats what they sent me
Old Sep 30, 2009 | 05:17 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
when i look up that BBK number i get a 52mm not 58mm....:
There are no part # 's stamped on a BBK TB.The EO # is the CARB compilance exemption # for Cal emissions.See
arb.ca.gov/msprog/aftermkt/devices/eo/D-245-13.pdf
Only way to tell is to measure throttle blades because the part # is only on the box, not the TB.
Old Oct 3, 2009 | 02:11 PM
riverdog's Avatar
Car: 86 Z
bump...got the mini ram fired up today.
Old Oct 3, 2009 | 05:16 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
thanks josh, saw the pics shes look real good
Old Oct 4, 2009 | 06:09 PM
Car: 92 1500p\u 2wd
so is there anyway u can show us that its a true 58mm and not a 52mm TB? im interested in it but already have a 52mm bbk.
Old Oct 5, 2009 | 06:14 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
i'll see if i can take a pics while measuring the blades
Old Oct 6, 2009 | 03:16 PM
peepsrs's Avatar
Car: 91 Rs
Engine: 383 hydrolic roller carb
Did you or did anyone reading this have trouble setting the tps with the bbk throttle body...If not how did you go about setting it.
Old Oct 6, 2009 | 06:20 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
ad no problem doing it, i finaglled and messed wit it untill i got the points to match up to the tb and then tuned it when i had it goin
Old Oct 6, 2009 | 09:33 PM
peepsrs's Avatar
Car: 91 Rs
so you didnt set it using a meter with resistance?... thats how the tpi book tells you how to do it but my stuff is way off what that tells you
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
justin57
Aug 20, 2015 07:05 PM
mdtoren
Aug 16, 2015 05:45 PM
