[IL] Edelbrock Hi-flow TPI, aluminum113 head, nib gmpp 1.6RR
Old Sep 25, 2009 | 06:46 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I recently boght a gta so my 87 trans am and all the parts I have for it must go.... prices do not include shipping or 3%paypal fee. thanks
Edelbrock Hiflow tpi, slightly ported base, runners, plenum port matched to runners and opened up for a 58mm TB, fuel rails with bbk afpr ..SOLD
NIB GMPP aluminum self aligning 1.6 full roller rockers with polylocks..SOLD
Auminum 113 heads rebuilt 1k miles ago...z28 springs(.600lift ones) valve guides milled to except up to .580 lift but set up for .520 right now, comp hardened pushrod guides....SOLD
Headman shortie header with matching ypipe.. $150
energy suspension poly control arm bushing kit(rear) nib...$25
msd 6al with remote coil harness...SOLD
freshly rebuilt 601 (305 heads) 0miles,swirl intake valves, partially ported,53cc chambers....$100
comp cams 258 hr12 cam with @ 29k miles ...SOLD
stock 89 l98 iroc cam..$20
Hollow 36mm front swaybar and mounting brackets...$45
ported stock tpi with tb fuel rails and injectors(awfull paint job is free :-)...$135
Vortec heads(062) have around 90-100k,recently had them magnafluxed and they have no cracks
have all the oe harware(valves,springs seals ,retainers exc,...$150
powerstop crossdrilled rotors,,, brand new SOLD
heres a link.. http://www.summitracing.com/parts/PWR-AR-8213L/#
thanks for lookin. PM me or reply to thread if interested.
Old Sep 25, 2009 | 07:08 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Re: Edelbrock Hi-flow TPI, aluminum113 head, nib gmpp 1.6RR
Will the springs in the heads work with a roller cam?any port work done to them?
Old Sep 25, 2009 | 07:36 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Yes, They were on a motor with an lt4 hotcam.
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
a bit more info on on the hi-flow set up is it 89-92 no cold start can you send me a pic or 2 to godreject@man.com and more details pls. Thanks
Old Sep 25, 2009 | 08:09 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
its is 89-92 no cs injector and Im posting pics now
Old Sep 25, 2009 | 08:10 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
edelbrock hi flow intake
Old Sep 25, 2009 | 08:17 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
corvette 113 heads
Old Sep 25, 2009 | 08:19 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
gmpp rr nib
Old Sep 25, 2009 | 08:21 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
hedman headers
Old Sep 25, 2009 | 08:23 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Old Sep 25, 2009 | 08:25 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
601 heads
One of the ported bowls n guide
Old Sep 25, 2009 | 08:26 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
compcam and stock l98 cam with @90k
Old Sep 25, 2009 | 08:38 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
ported stock tpi
Old Sep 25, 2009 | 11:00 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Axle/Gears: 12 bolt 3.73 Eaton posi
My car is an 87 so it has the cold start injector, but would I be able to use your Edelbrock setup and get a custom chip burnt to get rid of the cold start injector? Would there be any other stuff that would need to be changed? This would be going on a 1973 350 block but with a 1987 TPI harness.
About the headers and y-pipe... what size primaries, what size collectors, any rust, any holes, any dents?
Old Sep 25, 2009 | 11:28 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
alot of members have just removed the cold start injector (without erasing from ecm) and not had a problem but some do say its a bit harder to start on cold days but thats it from what I know
Old Sep 26, 2009 | 12:06 AM
Car: 1987 IROC-Z
ok
What about header and y-pipe info?
Old Sep 26, 2009 | 08:09 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
heres a summit link for the ypipe and headers, there is no 02 bung and I have adapters for the ball socket type header that come with it also forgot to mention the ypipe was massaged to fit a car with subframe connectors.
headers
http://www.summitracing.com/parts/HED-68479/
ypipe
http://www.summitracing.com/parts/HED-17470/
Old Sep 26, 2009 | 08:14 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
x
Last edited by FlippindaBird; Sep 26, 2009 at 08:15 PM. Reason: found the answer in thread
Old Sep 27, 2009 | 12:46 AM
Car: 1987 IROC-Z
After examining the pictures of the black Edelbrock setup, it looks like the manifold and plenum are from 85-88 and the runners and fuel rail are from 88-92...
Can I get some part numbers?
Old Sep 27, 2009 | 08:30 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Part#s, from where? I spoke to a member and when we figured out the upper plenum is the older version, if anyone needs more pics just ask... I think I got all the pms if not let me know ... Ill get shipping quotes tomorrow when Im back in Illinois. thanks
Old Sep 28, 2009 | 05:29 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
all shipping quotes sent out,,,ttt
Old Sep 29, 2009 | 05:43 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Will trade/partial trade for 3rdgen tubular LCAs, tubular Torque arm, brake upgrades, trip guage pod for A piller, autometer guages(trans,oil,tach,) 26x16 MT ets or drag radials, LS1 drive shaft,,,,or? whatcha got
Old Sep 29, 2009 | 05:58 PM
Car: 1987 IROC-Z
Would you give me a deal on some parts if I get you fully dimensioned and scaled 1:1 patterns to make your own LCARB, PHBRB, or the caliper relocation brackets needed for the LS1 brake upgrade?
Let me know,
Mike
Old Sep 29, 2009 | 06:05 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
My friend has the relocation brackets for me and as far as the brakes Ive got 12 baer rotors with pbr calipers in the rear and Im looking for a complete bolt on ls1(or better) front set up with modifyied spindle and hub
Old Sep 29, 2009 | 11:07 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Interested in the rockers, PM sent.
Old Sep 29, 2009 | 11:35 PM
irocZwatts's Avatar
Engine: 5.7
Quick question, What is cold start injectors????
Old Sep 30, 2009 | 05:44 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
All pms replied.
Old Sep 30, 2009 | 09:11 AM
Engine: 350 SBC TPI
Originally Posted by wanab03ss
Auminum 113 heads rebuilt 1k miles ago...z28 springs(.600lift ones) valve guides milled to except up to .580 lift but set up for .520 right now, comp hardened pushrod guides....$425
Who Rebuilt them?
comp cams 258 hr12 cam with @ 29k miles ....$150
What is the Comp Cams part #?
Old Sep 30, 2009 | 06:33 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Dont know. I didnt have them rebuilt. I bought them of a member from the corvette forums who posted them on here.
the comp cam is 258hr12
Old Sep 30, 2009 | 07:24 PM
85irocz28's Avatar
Car: 1985 Iroc Z
Engine: 383 carbed
Transmission: Th 400 tci super street
Axle/Gears: 3:42 9 Bolt
how much is shippin on da 36mm sway to 08844 jersey
Old Sep 30, 2009 | 07:46 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
I think the swaybar would be expensive to ship bu I could find out on Sat for you.
The GMPP full roller rockers are sold...
Seems alot of people are having a hard time fining the 258hr-12 cam online, heres a link
http://www.summitracing.com/parts/CCA-08-500-8/
Old Sep 30, 2009 | 07:57 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
When you search for 258hr-12, it shows usually the 07-500-8 cam, not the 08-500-8. It depends on the search engine, though.
Btw, if TexasSilhouette passes up on the rockers, I would be interested. But he's got them first, of course.
Lou
Old Sep 30, 2009 | 08:12 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
that # you gave is for an lt1 engine not a standard sbc....
113 heads and cam are pending sale..
Old Oct 2, 2009 | 05:36 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
113 heads and comp 258hr12 cam are sold
Old Oct 3, 2009 | 07:17 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
added powerstop crossdrilled rotors and a set of vortec 062 heads.... to everyone who pmed about the headers n ypipe theyll have to be picked up cause shipping quote was @$60 depending on zip due to the large box required.
Old Oct 18, 2009 | 01:53 AM
lotsofsparepart's Avatar
Car: 1991 S10 4X4
Engine: 1989 TPI 355
Transmission: NV-3500 5 speed
Axle/Gears: 3.08
P.M. Sent for the Edelbrock setup.
Old Oct 18, 2009 | 09:59 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
crossdrilled rotors sold, pms replied.. also the edelbrock setup is being repainted.
Old Oct 18, 2009 | 10:38 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
They need to me masked off and a fresh coat of black engine paint sprayed...
Old Oct 18, 2009 | 05:55 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
sale pending on intake
Old Oct 19, 2009 | 06:37 PM
Car: 1991 S10 4X4
Axle/Gears: 3.08
Payment sent for intake.
Thanks, Jared
Old Oct 19, 2009 | 07:33 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Intake sold, Ill get it shipped asap,, should be tomorrow. thanks
Old Oct 19, 2009 | 07:39 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
A Little off topic, but isn't it against paypal's policies to make the buyer pay for paypal's fees? I do believe it says that somewhere in their disclaimer.
Old Oct 19, 2009 | 07:51 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
OK, well I guess like summit racing Ill call it a 3% handling fee. Sorry no free shipping though.. :-)
Old Oct 19, 2009 | 08:08 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
. This is the cost of doing business. Incorporate this cost into the cost of your item, not the shipping and handling fee. Shipping and handling fees are lumped together in your stated or calculated cost. Be sure to add a little to offset Paypal percentage fee on the shipping cost. Say it costs $20 to ship an item, paypal collects 3% on the $20 so you loose and additional 60 cents in Paypal fees. Shipping cost of $6 is about 18 cents, so if you charge actual shipping, you are loosing money. Charge $5 for Priority Mail 1 pound package and the actual $4.80 + free box from postal system, free delivery confirmation when generating shipping label with paypal and you are good to go. Don't forget the cost of tape, packing materials, etc. Use postal system Priority Mail boxes (free) when you can. Used boxes from the store or recycle center.
Copied directly from paypal. Like they stated, it's the cost of doing business. If you're buying something then, do you complain about the paypal fees, or just eat them with a smile on your face? I doubt it's the latter of the 2. Kinda sucks, cause I'm close and would drive to you to get that exhaust.
Old Oct 19, 2009 | 08:41 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Im confused. Do you want the exhaust??? Im not charging paypal fee if paypal isnt used, and I only charge what shipping actually costs,, I dont include my time or gas to package it drive there and ship it. If someone wants to pick something up Im all for it,,, its saves me time and $$. FYI its common practice for people to add the 3% for paypal. Lets get back to the subject of parts for sale, Im not a business so I dont treat it as such since Im just a thirdgen enthusiast with some extra parts for sale at a good price.
Old Oct 20, 2009 | 07:02 PM
phoenix_rising's Avatar
Shipping quote and sharper pics of heads to b_schall20@hotmail.com please. Still have the headers? Thanks!
Old Oct 23, 2009 | 06:24 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
113 Heads were sold already,,,, headers have to be picked up.
thanks to everyone who has purchased parts and to those who left feedback, every buyer so far has been an absolute pleasure to do buisness with.. Hope everyone enjoys there parts..
a couple pics of the vortecs if thats what you wanted... there still bare from being magnafluxed but I have all the valves,springs and hardware.
midge54
Dec 27, 2019 04:14 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
89-S-dime
Aug 12, 2015 11:57 AM
