[Sold] AFR 195's Eliminator Heads 75cc-#1038-NEW
Old Sep 29, 2009 | 01:41 PM
darakus's Avatar
Car: 1988 Trans Am GTA
Transmission: 700r4 rebuild, heavy duty clutch pa
Cleaning out the garage, these heads are new. Bought them for my supercharger to lower the compression but am going a different route now. I actually just sold the supercharger so I don't need these heads. 1250 + shipping.
195 SBC ELIMINATOR STREET HEAD FLOW NUMBERS
AFR INTAKE AFR EXHAUST
.200 137 CFM 110 CFM
.300 194 CFM 158 CFM
.400 240 CFM 190 CFM
.500 270 CFM 207 CFM
.550 280 CFM 211 CFM
.600 286 CFM 215 CFM
195cc Street Heads, L98 Angle Plug w/heat riser, 75cc
The Ultimate Bolt-on Emissions Legal Street Weapon. 195cc intake port small block Chevy cylinder heads are L98 angle plug versions. These heads feature a 75cc combustion chamber with a 64cc exhaust port and a 3/4” thick head deck (ideal for nitrous or blower applications). Standard valves are 2.050 (comp package has 2.080) intake and 1.600 exhaust with AFR’s hardened ductile iron interlocking valve seats. The exceptional flow characteristics, ideal operating range of 2000 rpm to 6500 rpm, 23º valve angle, and standard valve spacing make this the perfect street head for 350 cid to 400 cid engines from 1955-86. . No special parts are required. Dual valve cover bolt pattern is standard. Exhaust port is raised .100 over GM L98 Head.
More info available here :
http://www.summitracing.com/parts/AF...n/?prefilter=0
Attached Thumbnails AFR 195's Eliminator Heads 75cc-#1038-NEW-dsc00314.jpg   AFR 195's Eliminator Heads 75cc-#1038-NEW-dsc00313.jpg
Old Sep 30, 2009 | 07:59 PM
darakus's Avatar
Re: AFR 195's Eliminator Heads 75cc-#1038-NEW
TTT
Old Oct 3, 2009 | 07:37 AM
darakus's Avatar
Heads really good for you nitrous people out there!!
Old Oct 9, 2009 | 09:57 PM
darakus's Avatar
TTT
Old Oct 9, 2009 | 10:24 PM
jmat2407's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: BW 3.23
I can give ya like $900 for them.
Old Oct 10, 2009 | 01:14 PM
darakus's Avatar
lol.......................no
Old Oct 10, 2009 | 11:54 PM
Clemson327's Avatar
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
Dang...wish I hadn't already bought mine already. Bump for a great deal on a great set of heads.
Old Oct 18, 2009 | 08:00 PM
darakus's Avatar
TTT
Old Oct 31, 2009 | 09:37 PM
darakus's Avatar
Take er to de top
Old Nov 3, 2009 | 09:10 AM
Wildebird's Avatar
Great price for a great set of heads. I have the 65cc 1040's. Plus you wont have to wait the 2 1/2 months for AFR to build them.
Only complaint with them is the shallow center holes for the centerbolt stuff. Easily fixed though.
Old Nov 15, 2009 | 05:20 PM
darakus's Avatar
Bump
Old Nov 16, 2009 | 01:10 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
If I didnt buy a set of RPMS I would have been all over this. If I could find a buyer from mine id be over this for sure as well. Good luck with the sale
Old Nov 16, 2009 | 08:54 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
2 1/2 months?
I can get you 1040s for under $1300, with the 8017 spring package in under 14 days.
AFR heads are great. Whomever buys these will be VERY HAPPY! Like darakus said, the 75cc chambers are great for nitrous and a blower with some reverse dome pistons.
-- Joe
Old Nov 29, 2009 | 04:12 PM
darakus's Avatar
Heads are still available, shipping negotiable ...
Old Dec 4, 2009 | 05:17 PM
darakus's Avatar
pm sent
Old Dec 12, 2009 | 02:15 PM
darakus's Avatar
as previously posted, shipping is negotiable
Old Dec 24, 2009 | 10:04 AM
darakus's Avatar
Merry Xmas all!! New heads are wanting a new home(motor) to spread the joy....
Old Dec 24, 2009 | 12:59 PM
the gtaman's Avatar
Car: 1989 firebird gta
Engine: sbc 355 hsr 280xfi 58mm tb
Transmission: raptor 700r-4, 2800 stall
yeah i ordered a set last month but won't get them until jan 2010 !
Old Dec 24, 2009 | 01:14 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
AFR is on holiday brake until Jan 4th.
-- Joe
Old Jan 9, 2010 | 01:17 AM
darakus's Avatar
ttt
Old Jan 30, 2010 | 06:12 PM
darakus's Avatar
ttt
Old Feb 1, 2010 | 12:40 AM
lakers73kb8's Avatar
Want a title? Post!
are they for centerbolt valve covers? i'm looking forward on putting them on a 95 tahoe..
Old Feb 1, 2010 | 09:15 PM
darakus's Avatar
hey lakers73kb8 these would not fit on your hoe.
Upon further viewing on their website -- Available for 1987 to present engines with center bolt valve covers and 2 center intake bolts at 72° angle (AFR #1041).
sorry for the mixup!!
Old Feb 3, 2010 | 12:49 PM
88BlackZ-51's Avatar
The Ultimate Bolt-on Emissions Legal Street Weapon. The AFR Emissions Legal (versions from 1969-94 with heat riser, CARB EO #D-250-2), 195cc intake port small block Chevy cylinder heads are available in your choice of straight or L98 angle plug versions. These heads feature a 75cc combustion chamber with a 64cc exhaust port and a 3/4” thick head deck (ideal for nitrous or blower applications). Standard valves are 2.050 (comp package has 2.080) intake and 1.600 exhaust with AFR’s hardened ductile iron interlocking valve seats. The exceptional flow characteristics, ideal operating range of 2000 rpm to 6500 rpm, 23º valve angle, and standard valve spacing make this the perfect street head for 350 cid to 400 cid engines from 1955-86. Available for 1987 to present engines with center bolt valve covers and 2 center intake bolts at 72º angle. No special parts are required. Dual valve cover bolt pattern is standard. Exhaust port is raised .100 over GM L98 Head.
Why don't you put them on kijiji, and sell them local?
Old Apr 18, 2010 | 11:22 PM
darakus's Avatar
hey guys just got back from working, the heads are still available.
Yea I am trying to sell these local 88blackz-51,why you wanna buy them?
Old Apr 19, 2010 | 11:25 AM
smiths87t/a's Avatar
Will they fit the perimeter bolt valve covers also?
Old Apr 19, 2010 | 03:35 PM
darakus's Avatar
yes they are - Dual valve cover bolt pattern is standard .. just to clarify they are for -- 350 cid to 400 cid engines from 1955-86.
Old Apr 30, 2010 | 10:36 PM
darakus's Avatar
springs here ........................ get these heads before summer!!
Old May 16, 2010 | 09:51 PM
darakus's Avatar
ttt
Old May 16, 2010 | 10:44 PM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
$1000 shipped?
Old May 16, 2010 | 10:48 PM
Originally Posted by Blown84Bird
$1000 shipped?
wow!
Old May 16, 2010 | 10:57 PM
darakus's Avatar
I realize we're in a recession but come on lol
Old May 16, 2010 | 11:05 PM
If you don't want to that's cool I wont lose any sleep over it LOL
Old Jun 5, 2010 | 11:29 AM
darakus's Avatar
ttt
Old Jun 11, 2010 | 01:57 AM
Bump to help a fellow 3rd genner
Old Jun 12, 2010 | 01:08 PM
woottang30's Avatar
Car: '89 Formula
Engine: 355 SBC, AFR 195s
Transmission: T-56 Swap
Axle/Gears: 7.5 Eaton LSD w 4.10s
good location, very interested, pm sent.
Old Jun 13, 2010 | 02:51 PM
vwdave's Avatar
Watching this thread makes me not want to sell my heads.
The guy is already selling something for a great price and people are still lowballing him.
Old Jun 13, 2010 | 04:14 PM
woottang30's Avatar
Car: '89 Formula
whats your postal code? if the shipping is reasonable, i'm very interested in negotiating a sale!
Old Jun 16, 2010 | 09:11 PM
darakus's Avatar
Heads SOLD!!
Old Jun 17, 2010 | 07:59 AM
vwdave's Avatar
Heads SOLD!!
Grats.
92projectcamaro
Jan 18, 2016 08:00 AM
z28guy134
Sep 1, 2015 11:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
