[CT] carb'd wiring harness, A/C delete box
Old Jan 2, 2010 | 01:42 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Transmission: t56
I need an engine wiring harness out of an 84-87 firebird (carb'd not fuel injected) and an A/C delete box.
thanks, Tim
Old Jan 2, 2010 | 05:49 PM
ted gerlach's Avatar
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
Re: carb'd wiring harness, A/C delete box
i have the harness off a carbed car think it was an 82
Old Jan 2, 2010 | 07:59 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Transmission: t56
I need one from an 84-87 so the C100 connector will plug right in with minimal mods.
Old Jan 2, 2010 | 08:06 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
i have the carb intake harness and comp for $250 shipped the car has 8" of snow on it now though so i wont be able to get it off till nice weather, its a virgin 87 firebird LG4/700r4 with 120k miles even got a braided fuel line from the pump to the carb that ill throw in for free, cost 55$ from jegs and the stock single snorkel air intake or a dual snorkel intake from a mopar that i had on for a while, im converting to tpi so "everything must go!"
Old Jan 2, 2010 | 08:35 PM
Terry Kennedy's Avatar
Car: 88 IROC
Transmission: pg
Axle/Gears: 9" w/3.89
I got the a/c delete box $125 plus shipping
Old Jan 2, 2010 | 11:46 PM
kurfbird's Avatar
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
I ahve an a/c delete box from a 88 camaro 125.00 shipped lower 48 states
Old Jan 4, 2010 | 12:36 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
So far the closest I've come on the harness is from an 84 Trans Am. It should have the same wiper plugs as the 87, ( your washer pump is inside the wiper motor right ?? ) but would be lacking the Electrical speedo wiring at C100. I also found a Camaro Carb engine harness too, but it is also missing the electric speedo wiring.
I do have a couple AC Delete Boxes too,.... One is partially restored and the other is in typical used/unfinished condition.
I'm going to try 2 more places for a matching harness in the next couple days. I'll re-post here once I have an update.
Old Jan 4, 2010 | 05:33 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Transmission: t56
thanks john but I got good deals on the parts I needed so unless one of the parts turns out to be a no show I should be all set!
-Tim
Terrell351
Jun 13, 2021 01:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
BikeFarm
Aug 11, 2015 11:35 PM
