[IN] Crane Retro Fit Roller cam/lifters, 278/286 224/230
Old Feb 10, 2010 | 11:22 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Axle/Gears: 3.23 Posi
I have a crane retro fit roller cam and lifters. It came out of a 383 that I got from my wife's uncle. I checked with Crane cams this morning and verified the grind.
278/286 adv. 224/230 @.050 .510/.530 112 LSA
It is in really good shape. This would be a good cam for a mild 350 and a great price to get into a roller cam.
Cam and lifters, 425 shipped. The lifters alone cost that.
I can get pics if anyone wants them.
Jason
Old Feb 14, 2010 | 01:11 PM
LilJayV10's Avatar
Engine: 406 Roller
Re: Crane Retro Fit Roller cam, 278/286 224/230
ttt
Old Feb 23, 2010 | 01:20 AM
LilJayV10's Avatar
Engine: 406 Roller
bump
Old Feb 23, 2010 | 07:28 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
what is the LSA?
Old Feb 23, 2010 | 11:03 PM
robert1's Avatar
Got a part number? I can't find those specs on Summit's site.
Old Feb 24, 2010 | 12:31 AM
LilJayV10's Avatar
Engine: 406 Roller
PART NUMBER: 119531 ENGINE TYPE: HYDRAULIC ROLLER SPECIAL
GRINDNO: HIR-278-2S-12
ENGINE IDENT: CHEVY 57-87 V8 262-400 ALSO 87-95 TRUCK
(ALSO 1987-95 NON-ROLLER TRUCKS)
VALVE SETTING: INTAKE .000 EXHAUST .000 HOT
INTAKE @ CAM
3400 @ VALVE
510 ROCKER ARM RATIO
INTAKE @ CAM
3534 @ VALVE
530 1.5 ROCKER ARM RATIO
LIFT: EXHAUST @ CAM @ VALVE
ALL LIFTS ARE BASED ON ZERO LASH AND THEORETICAL ROCKER RATIOS
CAM TIMING
OPENS
CLOSES
ADVERTISED DURATION
.004 EXHAUST INTAKE 28 BTDC 70 ABDC 278 ° °
TAPPET LIFT EXHAUST
76 BBDC 30 ATDC 286 °
SPRING REQUIREMENTS
RECOMMENDED RPM RANGE WITH
MATCHING COMPONENTS
TRIPLE DUAL OUTER INNER
PART NUMBER
99838 MINIMUM RPM
2500
LOADS: CLOSED:
112 LBS @ 1.650 OR 1 21/32 MAXIMUM RPM 6000
OPEN:
318 LBS @ 1.140 VALVE FLOAT 6500
CAM TIMING
OPENS
CLOSES
MAX LIFT
DURATION
@ .050 INTAKE
2 BTDC 40 ABDC 109 ° ATDC 222 °
TAPPET LIFT EXHAUST
50 BBDC 0 ATDC 115 ° BTDC 230 °
Old Feb 24, 2010 | 12:33 AM
LilJayV10's Avatar
Engine: 406 Roller
That doesn't look like it does on the cam card crane sent me, the part number is HIR-278-2S-12
I am going to email crane and ask them. I don't see it on the cam card. I can email you the cam card if you want.
Old Feb 24, 2010 | 10:44 AM
LilJayV10's Avatar
Engine: 406 Roller
it's on a 112 LSA
Old Feb 28, 2010 | 07:35 PM
LilJayV10's Avatar
Engine: 406 Roller
bump. if interested make reasonable offer.
Old Mar 3, 2010 | 08:32 AM
LilJayV10's Avatar
Engine: 406 Roller
bump
Old Mar 12, 2010 | 01:38 AM
LilJayV10's Avatar
Engine: 406 Roller
bump
Old Mar 22, 2010 | 12:41 AM
LilJayV10's Avatar
Engine: 406 Roller
Still have it. If pics would help let me know.
Old Mar 28, 2010 | 02:14 AM
LilJayV10's Avatar
Engine: 406 Roller
I will get some pics in the morning.
Old Apr 16, 2010 | 12:35 AM
LilJayV10's Avatar
Engine: 406 Roller
Re: Crane Retro Fit Roller cam/lifters, 278/286 224/230
still for sale.
Old Apr 16, 2010 | 08:16 AM
chrisr0315's Avatar
Car: Hot Wheels
Engine: Stroker 383
interested in trading for 44mab Ruger lever action rifle exc. shape .Can be shipped legally thru ffl
Old Apr 16, 2010 | 08:35 AM
LilJayV10's Avatar
Engine: 406 Roller
Not interested in the rifle. Thank you for the interest though.
Old Jun 16, 2010 | 11:08 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
will you post pict's?
Old Jun 17, 2010 | 02:00 AM
LilJayV10's Avatar
Engine: 406 Roller
Sorry, it's been so long I have decided to keep them.
Old Jun 17, 2010 | 08:15 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Would you sell just the lifters?
Old Jun 18, 2010 | 06:00 PM
if you change your mind...I would be interested in both
craig
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
camaro71633
Sep 1, 2015 10:24 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
