Couple parts left from 1986 Z/28 (Super cheap Must go!!)
I have the following parts left for sale:
Heater control panel $10
T-top bag. Zipper works fine. It is missing the pull tap on the zipper. $20
Power hatch motor . works good $25
Black sun visors $10pr
Aftermarket steeering wheel w/ GM adapter (Black foam grip w/ chrome 3 spoke center) $20
Located in Hatboro,PA
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: Couple parts left from 1986 Z/28
Interested in the power hatch motor. Can you send me a pic of two to alpha283@yahoo.com? Thanks. Also how much to ship to 94112
Will
Will
hey im interested in the steering column woundering of you still have... also if you could send a pic of the column to me that would be great... i need one bad...sparky14820@yahoo.com
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Do you still have the Column? If it's Tight like you say, It's Sold.
Re: Couple parts left from 1986 Z/28 (Super cheap Must go!!)
Hello there......... It's me again. You wouldn't happen to have a black Seat belt set for the Driver's Side, would you?
Thank you. I sure could use that belt.......... And the Loops that attach to the seats too if you got em. I Also need the plastic Rocker plates.
Car: 85 Camaro IROC, 88 K-1500
Engine: 357 TPI, 350TBI
Transmission: T-5, NV3500
Axle/Gears: 3.42 posi, 3.73 i believe
t top bags still available?
thanks,
joe
thanks,
joe
1992 Trans Am
May 10, 2023 07:19 PM
