NEED: some odds and ends for T5 swap
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I am looking for a clutch reservoir & bracket (and hoses for it and the master/slave cyl hoses) as well as a T5 torque arm mount. If you have either, please PM me.
Thanks,
Thanks,
Car: 89 Iroc Convertible
Re: NEED: some odds and ends for T5 swap
Man I just pulled all that stuff yesterday off a 92 RS 305 TBI Car for my T-5 Swap.Good luck with your search
I have:
pm sent with prices.
- T5 Inspection Cover
- Clutch Master with U bolt and line, slave is there but not sure is good
- Clutch reservoir with bracket and hose
- Torque arm mount and bushings
- Lower shifter boot
- Clutch pedal assembly
- Bolts for the small starter (auto starter bolts too long)
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got the T5 Hydraulics,........ $65 + shipping. ( will not seperate ) I'm pretty sure I still have the reservoir bracket too.
Post your Zip if your interested.
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
I also have all the T-5 hydaulics.
80 Shipped.
lmk
80 Shipped.
lmk
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I found a spare reservoir bracket if you still need one. I'll have to double check on the reservoir.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Hi, sent you the shift boot, I'm just posting on here so I can give you feedback, Thanks, Henry
