Holley Stealth Ram, 58mm Throttle body, 30lb Fuel Injectors
Car: 89 IROC-Z
Axle/Gears: 4.10
Holley stealth ram, fuel rails, 58mm throttle body, Holley injectors, kirban adjustable fuel pressure regulator, AN steel braided fuel lines that will hook up to the stock metal lines on a 3rd gen and Lokar throttle cable. $950 + shipping. The throttle body had a diffrent style throttle hook up then what my car had on it. Thats why i have the Lokar cable. The top of the intake and throttle body has a few nicks in the metel from where I had clearance issuses with the hood. The port on the fuel rail where you hook up a pressure gauge is leaking but that should be a easy fix. I have put less than 500miles on this. I bought the HSR, fuel rails, injectors and throttle body used in march. The previous owner claimed only 100miles on it. Everything else i bought brand new in April. I also have the following items; a tpiparts prom chip setup for 42lb injectors, no-VATS, no-EGR, no cold start injector and no-AIR. I don't remember what the fan on/off temps where set to. Also have a holley non-adjustable fuel pressure regulator, K&N cone air filter that can mount to the TB.
Stealth Ram - Sold
Fuel Rails - Sold
Kirban fuel press reg - Sold
Fuel lines - Sold
Holley 58mm throttle body - $250
Holley 30lb fuel injectors - $175
Lokar throttle cable - $25
K&N cone - $25
tpiparts chip - $50
holley non-adj fuel press reg - $25
Prices not including shipping
Stealth Ram - Sold
Fuel Rails - Sold
Fuel lines - Sold
K&N cone - $25
tpiparts chip - $50
Car: 89 IROC-Z
Axle/Gears: 4.10
Re: Holley Stealth Ram
This pic was taken when i was still installing it. The kirban press reg isn't on it yet in this pic.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
FWIW
your pricing is a little high compared to what most are asking for used HSR's ( even with the extras )
https://www.thirdgen.org/forums/engi...am-extras.html
https://www.thirdgen.org/forums/engi...ml#post4657181
Car: 89 IROC-Z
Axle/Gears: 4.10
Here are pics of the kirban fuel press reg and the holley non-adjustable fuel press reg. Also a cone K&N air filter.
Car: 89 IROC-Z
Axle/Gears: 4.10
Current price is $950. I don't want to separate this setup but i might. I'll take $55 shipped for the chip. This chip goes between the oringinal prom and ECM.
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
Will the chip fit a stock 350 TPI ecm..and would it work with a 383 ??? mhhhhhh
Car: 89 IROC-Z
Axle/Gears: 4.10
It should work with 1986-1989 TPI engines with ECM number 1227165. As long as you don't need VATs, EGR, smog A.I.R. or cold start injector.
Car: 89 IROC-Z
Axle/Gears: 4.10
I don't know if it will work. It should work only as well as the stock prom with a 383.
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
Do you still have that kirban regulator?
Car: 85 Trans Am
Engine: 383 HSR
Hey just got the Stealth ram... Looks great... can't wait to get this thing polished up and painted so i can get it on my car. My 383 was getting starved with that stock tpi system.
Car: 89 IROC-Z
Axle/Gears: 4.10
I'm glad your satisfied with it. It was the best thing i ever put on the IrocZ. Now i got some cash for some go fast parts on my 2001 Trans Am.
This is a great intake, on a stock motor, its worth 35 hp over the TPI intake, but the 700r4 trans is meant more for the TPI long runner intake. The jump from first to second can use the torque and going into third. The HSR is better suited to a TH350 trans with its tighter gear spacing. My car ran a 13.2 at 103 with a 9.0:1 compression, check it out, I just added the new video to my youtube also, check it out
My youtube I'm Cronsformula350 all one word
Why is everyone saying bump? Whats up with that?
Well I'm getting some RHS heads from Lloyd Ellioit, for a great price, there 50 CC chambers instead of what I have now, my worlds are great, but have 72 CC's so thats hurting me, so I'll be a little more than 10.5:1 compression, and my power will jump up substantially
Car: 85 Trans Am
Engine: 383 HSR
Re: Holley Stealth Ram, 58mm Throttle body, 30lb Fuel Injectors
free bump
added some after pics, you wouldn't believe the amount of time i got in sanding smooth all that casting. I say it was worth it next step is cleaning and painting the engine bay. see what ya think
Car: 89 IROC-Z
Axle/Gears: 4.10
It looks good. Yeah i bet the sanding wasn't fun. I have been trying to polish my stock intake but its very time consuming sanding the casting.
Very nice job!
9192camaro
16
Feb 3, 2019 12:21 AM
L98GTA87
Aug 11, 2015 06:55 PM
