[FL] Complete TPI system with airfoil & throttle spacer. 200 + shipping !!"SOLD"!!
Old Jan 27, 2011 | 11:09 PM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
I have a TPI setup from a 91 camaro 305. This comes with the ECM, wire harness, and the complete tpi system with a hypertech airfoil and a helix throttle spacer. I did feel the little power those parts gave. It has a brand new map sensor and egr valve, not to mention this is a speed density system. The injectors are bad and that is the reason why i pulled the system off the engine. They sell the bosch 3 injectors at southbayfuelinjectors.com for i think 125. 200 + shipping for the complete system and i will even include the distributor and cap that was replaced not to long ago. Only other thing that you will need is a water neck gasket since i cleaned the base and removed it.
Attached Thumbnails Complete TPI system with airfoil & throttle spacer. 200 + shipping !!"SOLD"!!-025.jpg   Complete TPI system with airfoil & throttle spacer. 200 + shipping !!"SOLD"!!-026.jpg   Complete TPI system with airfoil & throttle spacer. 200 + shipping !!"SOLD"!!-028.jpg
Old Jan 31, 2011 | 08:22 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Re: Air Foil & Throttle Body Spacer
Bump
Old Mar 3, 2011 | 12:16 AM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Heres some more pics.......Look at the last few posts, i cleaned the system!
Attached Thumbnails Complete TPI system with airfoil & throttle spacer. 200 + shipping !!"SOLD"!!-001.jpg   Complete TPI system with airfoil & throttle spacer. 200 + shipping !!"SOLD"!!-007.jpg   Complete TPI system with airfoil & throttle spacer. 200 + shipping !!"SOLD"!!-006.jpg
Old Mar 21, 2011 | 02:37 PM
tpis's Avatar
Car: 92 camaro 92 s10 99 caddy 91 4x4
Engine: 305 tbi for now
Transmission: 700 r4
Axle/Gears: 3.73 limited slip
Re: Complete TPI setup with air foil and throttle spacer!
How much just for the harness? If you were to part it from the system.
Old Mar 21, 2011 | 02:48 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Id sell it for 125 plus shipping
Old Mar 22, 2011 | 12:40 AM
1BADZ28SD's Avatar
Engine: 5.7Liter HSR
how much for the intake
Old Mar 22, 2011 | 08:04 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
200 OBO
Old Mar 22, 2011 | 08:23 PM
tpis's Avatar
Would I be able to use your ecm, or did you have vats removed from it or would I need your key.
Old Mar 22, 2011 | 08:39 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
I did have vats removed but i will provide a key. I wont part the ecm from the wire harness though, i want to keep it all together
Old Mar 23, 2011 | 07:10 PM
tpis's Avatar
How much for the harness and ecm together? and what would be shipping to Iowa you think.
Old Mar 23, 2011 | 08:16 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
The harness + Ecm and key i will sell for 125 and add 20 for shipping. I want to be on the safe side with the shipping since i never have shipped something that heavy before. If it totals out to more than 20 ill pay out of my pocket for the rest.
Old Mar 23, 2011 | 08:43 PM
tpis's Avatar
I will be getting a hold of you soon!
Old Mar 23, 2011 | 08:53 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Sounds good just PM me for my info
Old Mar 23, 2011 | 09:42 PM
Jawsdiver's Avatar
Car: 85' Jeep CJ7
Engine: 407 w/Accel Super Ram
Transmission: Bullet Proofed DANA 300
Axle/Gears: Dana 44's w/4:56 & ARB's
I am toying with the idea of building a 350 4-bolt for my wifes Jeep. I have the motor and 2 new thruster ecu's to use but I have a couple of quick questions before we strike a done deal though. The price isn't an issue if all of the sensors are included. I have a full set of newly rebuilt 30lb Bosch III injectors so that should solve that issue. What shape is the harness in and is it a Gen6 or 7? What kind of distributor does this come with... a dual sync? Is there an O2 and/or knock sensor with this?? Is the system complete minus the thermostat housing? If you can please drop me line or txt to discuss. I have sent my contact info to you via PM. Thanks
Old Mar 30, 2011 | 10:32 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Bump...make offers, will sell the air foil or spacer seperate.
Old Mar 31, 2011 | 10:20 PM
86ta-adf's Avatar
Car: 86 Trans Am
How much for the air foil and how much for the spacer? Or both.
Old Mar 31, 2011 | 11:10 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Make an offer
Old Apr 3, 2011 | 10:48 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Heres some more pics, except i spent all day cleaning it. Im still not finished cleaning
Attached Thumbnails Complete TPI system with airfoil & throttle spacer. 200 + shipping !!"SOLD"!!-100.jpg   Complete TPI system with airfoil & throttle spacer. 200 + shipping !!"SOLD"!!-166.jpg   Complete TPI system with airfoil & throttle spacer. 200 + shipping !!"SOLD"!!-167.jpg
Old Apr 3, 2011 | 10:49 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Attached Thumbnails Complete TPI system with airfoil & throttle spacer. 200 + shipping !!"SOLD"!!-101.jpg
Old Apr 3, 2011 | 11:08 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Honestly if someone is interested in this unit i will sell the complete system for 250 + shipping.
Old Apr 10, 2011 | 07:55 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Im to the point where i just need this gone. Im selling everything listed for 200 + the shipping cost. Thats probably the cheapest system you will find, all that it needs are new injectors and the thermostat with gasket.
Old Apr 12, 2011 | 10:40 AM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
How much would shipping be to 76301. Did I read right that this is vats delete and otherwise complete ready to bolt on w/ new gaskets and injectors?
Old Apr 12, 2011 | 12:28 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
The total comes to 44.79 https://www.fedex.com/ratefinder/sta...=getQuickQuote . Yes it had a vats delete, it has all the gaskets but the water neck gasket and you need a new thermostat and injectors. That was my stalling problem from those bad injectors.
Old Apr 12, 2011 | 12:54 PM
91phoenix's Avatar
Thanks for the quick replies and with the last info I requested I will buy this.
Old Apr 12, 2011 | 12:58 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Sounds good, just PM the info. Thanks
Old Apr 13, 2011 | 10:12 PM
Jaxom's Avatar
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
Re: Complete TPI system with airfoil & throttle spacer. 200 + shipping
Sold? Or still available?
If available I'll take it. Just lemme know.
Old Apr 14, 2011 | 05:31 AM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Sale is pending
Old Apr 16, 2011 | 11:49 PM
jbzr1's Avatar
Want a title? Post!
Car: 89 Corvette
Transmission: 700 auto
Axle/Gears: 3.08
If available i will purchase now please advise thanks.
Old Apr 20, 2011 | 10:26 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Sold
Old Apr 27, 2011 | 10:09 PM
91phoenix's Avatar
This TPI system just arrived today well packaged and just as described. I am very satisified.
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
