[Sold] Dart Iron Eagle sbc heads
Old Feb 3, 2011 | 07:07 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Dart Iron Eagle SBC heads: 215cc Runner 64cc chamber. port/polish, all work done by Ray Romito of Romito Race Engines. Straight plug heads, runners cleaned up, matched to a 1206 gasket. Heads made 49x/49x Hp/Tq on a 9.5:1 compression and 525 lift non roller cam. Heads include Comp 1.5 Roller Tip Rockers, springs (for hyd flat tappet cam)
$600---deposit given for heads, deal pending
Old Feb 3, 2011 | 07:17 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
Re: Dart Iron Eagle sbc heads, th350, spohn crossmember, torque arm and panhard bar
Is the torque arm one that mounts to the transmission or to the crossmember?
Old Feb 3, 2011 | 07:28 PM
xpndbl3's Avatar
Car: 1984 Z28
crossmember mount
Old Feb 3, 2011 | 07:35 PM
brodysZ28's Avatar
Engine: 383
Hmmm I might be interested in that, I have a tremec so I dont think your crossmember will work for me? But would that torque arm bolt up to any x member they make?
Is this one of the biggest fixes for wheel hop?
Old Feb 3, 2011 | 07:48 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
That, and a good set of lower control arms.
Old Feb 3, 2011 | 07:53 PM
xpndbl3's Avatar
Car: 1984 Z28
yes it will bolt up to any of the crossmembers, probably be cheapest to just add a section of steel to allow it to mate up with your tremec now, or sell this mount and buy the other one. Lots of choices when it comes to his products.
Also this is one of the thing to reduce/eliminate wheel hop, along with LCAs and relocation brackets if needed. These are stout pieces.
Old Feb 3, 2011 | 07:54 PM
brodysZ28's Avatar
Engine: 383
Yea, pretty sketchy at the track, gotta take care of that wheel hop or I can kiss my rear end goodbye.
How much would you want for the arm sent to NH 03608?
Old Feb 3, 2011 | 07:55 PM
xpndbl3's Avatar
Car: 1984 Z28
Well if interested let me know, I can have it off the car pretty soon if you wanted to paypal payment for it and shipping
Old Feb 4, 2011 | 11:38 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Are the springs still in good shape on the heads, or are they ready to be replaced? Are they ready to bolt on, or in need of a VJ?
Old Feb 4, 2011 | 12:06 PM
xpndbl3's Avatar
Car: 1984 Z28
Motor combo is changing so new heads are being tossed on along with a much larger cam. Springs should test out fine for a flat tappet cam, no known issues with this combo at all. No burning oil, motor was extremely clean during tear down, no oil mist in the intake, on the pistons, etc. Engine builder was really impressed by it, but he is well known in the area for quality builds. If you want to know more details about the combo let me know, I'm sure we can work something out for a local guy
Old Feb 4, 2011 | 02:32 PM
jshalsey77's Avatar
Car: 82 Z28 hardtop / 87 Iroc
Engine: SBC
Hello, im interested in the trans, torque w/ cross member. what would you take for these items dont need the pan arm
Old Feb 4, 2011 | 03:17 PM
xpndbl3's Avatar
Car: 1984 Z28
675
Old Feb 4, 2011 | 03:22 PM
frankinmaro's Avatar
Car: 87 Frankinmaro
Engine: ZZ4 short block 67 327 462 castings
Transmission: TH350-c out of Y body
Axle/Gears: 97 4th gen Torsen 3.23
yeah PM me your info thanks
Old Feb 4, 2011 | 03:54 PM
jshalsey77's Avatar
Engine: SBC
Can you call me for more info 260 894 2508
Old Feb 4, 2011 | 05:47 PM
xpndbl3's Avatar
Car: 1984 Z28
heads have a deposit on them.....so they are being held until next weekend.
Chuck84TA
Jul 15, 2016 09:05 PM
gixxer92
Sep 1, 2015 04:32 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
