[FL] 82-84 Trans Am power bulge air cleaner assemblies
Old Feb 11, 2011 | 05:14 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I have 3 sets of 82-84 Trans Am Factory Power bulge air cleaner/lid/underhod solenoid assemblies. These are kind of hard to find and I have been holding onto these in case I needed any of them but I could use the money more than i could use them right now. One of the lower bases has had another "snorkel" riveted onto the opposite side, that will only work if you relocate your coolant overflow jug, because it would hit it. I have another under-hood solenoid assembly but its still mounted to my T/A. These originally came on LG4/L69 engines, and will not work with crossfire engines.
$80 a set which is one air cleaner bottom, one lid with rubber gasket, and one underhood air box with solenoid. I have 3 sets.
Old Feb 12, 2011 | 01:07 AM
Re: 82-84 Trans Am power bulge air cleaner assemblies
up
Old Feb 22, 2011 | 03:19 PM
up
Old Feb 22, 2011 | 06:46 PM
Duane C's Avatar
Car: 92 RS Conv. Heritage
Engine: stock 305 TBI
Transmission: stock Auto
Axle/Gears: stock
pm sent
Old Feb 24, 2011 | 09:47 AM
Originally Posted by Duane C
pm sent
Replied.
Old Feb 24, 2011 | 11:23 PM
Up.
Old Feb 25, 2011 | 04:28 PM
Up.
Old Feb 27, 2011 | 06:23 PM
Up.
Old Feb 28, 2011 | 11:03 AM
Up..
Old Mar 6, 2011 | 10:42 PM
Up..
Old Mar 10, 2011 | 09:03 PM
Up..
Old Mar 10, 2011 | 09:43 PM
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
If you ever wanna sell just the rubber gasket strip ring thing that goes on the top cover, shoot me a PM. If not, I understand, it's a set. I'll go about figuring out a custom one.
Old Mar 12, 2011 | 10:30 AM
Yeah I would rather keep them as complete sets, thaks though!
Bump.
Old Mar 13, 2011 | 05:04 PM
Up
Old Mar 16, 2011 | 02:55 PM
Up..
Hard to find, make me an offer!
Old Mar 24, 2011 | 02:10 AM
$80/set
Old Mar 27, 2011 | 02:44 PM
Bump.
Old Mar 27, 2011 | 10:18 PM
kitt_me's Avatar
Car: Honda and Trans Am 82
Bumpss for a nice setup,some one please tell me how to make my power bulge functional? Apprieate it
Where do the wires and relays go? ANy write here on this subject
Thnks
Old Mar 28, 2011 | 02:57 PM
Thnks
It is pretty straight forward. The air cleaner installed on the carb just like any other air cleaner, and the air box installs on the hood with 3 screws. The solenoid gets grounded to the hood and the power wire goes to a vacuum switch that has 1 hot wire going to it, and when the switch reaches the proper vacuum, it completes the circuit which opens the flap within the air box. I am not sure if it has a relay or not, but that's the basics of how it works.
Old Mar 28, 2011 | 03:03 PM
Car: 82,83,99 T/As
Engine: 350,350,383
No relay. Uses switched on power. That's how mine is at least.
Old Mar 28, 2011 | 03:13 PM
Yeah, didn't think so because I didn't see a relay on mine for it, either.
Old Mar 29, 2011 | 03:22 PM
Up $70/set
Old Mar 30, 2011 | 02:17 PM
Up
Old Mar 31, 2011 | 09:08 PM
Up
Old Apr 1, 2011 | 01:21 PM
Up
Old Apr 5, 2011 | 01:06 AM
Up
Old Apr 5, 2011 | 01:34 PM
kitt_me's Avatar
I am interested,could you take pics of this setup and guide me where the power wire goes into a vacum switch that has 1 hot wire going to it? Pmed you
Old Apr 5, 2011 | 03:39 PM
Here is a pic of the vac switch thats on my T/A. My car does not have this assembly installed currently, though. I am not sure where it gets the power from exactly, but I can try to trace it if you want..
Old Apr 5, 2011 | 09:35 PM
kitt_me's Avatar
Thanks buddy,My car doesnt have this set up,Can I have your email so i can send you my car setup pic ?
Old Apr 5, 2011 | 10:25 PM
Car: 82,83,99 T/As
Engine: 350,350,383
You can wire it so that it get's power when you have the key on "on". Just find a switched power wire. It'll open when you turn the key, but when the car turns on it'll close. Just attatch a vacuum hose to the top. Then at WOT/hard accel, it will open.
Old Apr 5, 2011 | 10:50 PM
You could send the pics through a PM, but I will PM you my email address anyway.
Old Apr 7, 2011 | 09:13 PM
Up
Old Apr 8, 2011 | 02:24 PM
Up
Old Apr 10, 2011 | 07:55 PM
Up
Old Apr 10, 2011 | 09:14 PM
ReNeGaDe_Z's Avatar
Car: 1990 Formula, 1989 Mustang LX
Engine: Stock TBI 305, Built 302
Transmission: 700R4, AOD
Axle/Gears: 4.10, 4.10
Will this bolt up on a TBI car? Mine does have the bulge hood.
Old Apr 10, 2011 | 09:41 PM
AS far as I know, yes it will work with TBI.
Old Apr 12, 2011 | 03:09 AM
Up
Old Apr 12, 2011 | 07:44 PM
One assembly has been sold.
2 remaining.
Old Apr 21, 2011 | 09:24 PM
2 remaining.
Old Apr 24, 2011 | 10:04 PM
2 remaining.
Old May 30, 2011 | 10:50 AM
2 remaining.
Old May 30, 2011 | 02:06 PM
kitt_me's Avatar
bumpsss
Old May 24, 2012 | 01:28 AM
Patrick Freitag's Avatar
Car: 87 Firebird Formula
Engine: TBI, V8, 305cui, w. A/C
Transmission: TH700R4
Hi !
Do you still have one set of this of 82-84 Trans Am Factory Power bulge air cleaner/lid/underhod solenoid assemblies ?
Regs
P.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
