SBC Parts! Centerforce Flywheel, Front Acc. Setup, Cam Bearing Tool, T-5 Stuff +++++
Old Feb 21, 2011 | 11:19 PM
91_rs-teal's Avatar
Car: 1991 Camaro, Best 12.40 @ 115.8 MPH
Engine: LS1, HCI, Headers
Transmission: T56, Monster Stg. 4
Axle/Gears: 7.5" 10 Bolt - 3.73's w/ posi
Hello I'm posting because im looking to go a different route,
I had a 1974 SBC block 4 bolt main .40 over KB pistons, that im finishing parting out
- Engine, AFR Heads, Edelbrock Intake, Speed Demon Carb, Rockers, Regulator, Trans, T-5 Pedals, Oil Pump, Oil Primer, Valve Covers & Girdles - ALL SOLD!
- K&N extreme air lid 14" and filter 14" x 3 3/4" (1K Miles) and base plate - SOLD!
- Speed Pro, Stock Replacement Lifters (used only for cam break in) - $25 Shipped
- Standard length comp cam push rods - SOLD!
- SBC ARP SS Valve Cover Stud Kit - SOLD!
- SBC Vortec Style Edelbrock Intake Manifold Bolt Kit(New) - SOLD!
- SBC Autozone Starter (Replaced 7k ago)(Short hole side is drilled to 1/2") - $40 Shipped (Price Lowered 4-25)
http://s1098.photobucket.com/albums/...aropart008.jpg
- Summit Racing Cam Bearing Install Tool for SBC (little oxidizing on one part) - $40 Shipped (Price Lowered 4-19)
link @ http://www.summitracing.com/parts/SUM-900130/?rtype=10
- Centerforce steel flywheel(been resurfaced once) - $150 + Shipping (Price Lowered 4-16)
http://s1098.photobucket.com/albums/...aropart006.jpg
link @ http://www.summitracing.com/parts/CTF-700100/
- T-5 Trans Crossmemeber, Powder Coated Black w/ Poly Mount - $40 Shipped
http://s1098.photobucket.com/albums/...aropart007.jpg
http://s1098.photobucket.com/albums/...t5stuff003.jpg
- T-5 Hydrolics: Master, Slave, Res. and Lines - $40 Shipped (Price Lowered 5-3)
http://s1098.photobucket.com/albums/...t=100_2225.jpg
Most Parts Are Used and Are In Working Order, A Couple New. Open to Reasonable Offers. Would Like To Receive Payment Through "Pay Pal" or Cash in Person. Additional Pictures On Request.
I'm Located in Alto, MI (S/E of Grand Rapids) and Ship to Lower 48 States Only! Unless Otherwize Noted.
I can answer any questions if interested
Thanks,
Brandon
Attached Thumbnails SBC Parts! Centerforce Flywheel, Front Acc. Setup, Cam Bearing Tool, T-5 Stuff +++++-flywheel.jpg   SBC Parts! Centerforce Flywheel, Front Acc. Setup, Cam Bearing Tool, T-5 Stuff +++++-pedals.jpg
Old Feb 22, 2011 | 03:08 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Older SBC Parts, AFR 195cc heads, Demon 650, t-5, +++
PM Sent.
Old Feb 23, 2011 | 03:26 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
What type of fuel pressure regulator, is it a return style and will it work for a V8
Old Feb 23, 2011 | 04:04 PM
91_rs-teal's Avatar
it is a return style
http://www.summitracing.com/parts/MAA-4309/?rtype=10
the gauge leaks, but i do have two of them
originally posted with the lines, but i think ill still need them
cam off a carbed v8 car
pic @
http://s1098.photobucket.com/albums/...reg006edit.jpg
Old Feb 23, 2011 | 04:59 PM
kainedogg's Avatar
Are you including a non leaking gauge with the Mallory?
Old Feb 24, 2011 | 11:15 AM
mr.oldv8's Avatar
Car: 85 IROC
Engine: L69
Axle/Gears: 3.73's
Is that you rock bottom price on the b/m short shifter?
Old Feb 24, 2011 | 04:19 PM
91_rs-teal's Avatar
yes a 15 psi, summit gauge
Old Feb 24, 2011 | 04:20 PM
91_rs-teal's Avatar
$90 shipped
Old Feb 24, 2011 | 09:17 PM
91_rs-teal's Avatar
video of engine parts are comin off of
http://www.youtube.com/watch?v=JQYYMuR34tE
Old Feb 24, 2011 | 10:06 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
pm sent...
Old Feb 27, 2011 | 09:59 PM
91_rs-teal's Avatar
bump ttt
Old Feb 28, 2011 | 07:32 PM
91_rs-teal's Avatar
bump, heads come with ARP's
Old Mar 2, 2011 | 06:19 PM
91_rs-teal's Avatar
bump, need to sell a couple more things to start my swap
Old Mar 6, 2011 | 11:41 AM
91_rs-teal's Avatar
Re: Carbed SBC Parts, Speed Demon 650 DP, t-5 Parts, 1.5 Roller Rockers, Stud Gridles
bump, price lowered on the serp. setup
Old Mar 7, 2011 | 10:01 AM
jllee05's Avatar
Car: 91 camaro "RS"
Engine: 6.6L dart 400 SHP, DArt PRO-1 heads
Transmission: built 700r4
Axle/Gears: 3.73 posi!
interested in t-5(trans, bellhousing, and shifter only) are u willing to ship???....if so how about 250???
Old Mar 7, 2011 | 04:50 PM
91_rs-teal's Avatar
sorry not willing to ship the trans
Old Mar 10, 2011 | 04:43 PM
91_rs-teal's Avatar
Re: SBC Parts, Speed Demon 650 DP, 1.5 Roller Rockers, Stud Gridles, 92 Camaro Acc. S
bump ttt
Old Mar 17, 2011 | 02:29 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: SBC Parts, 1.5 Roller Rockers, Stud Gridles, 92 Camaro Acc. Setup, T-5 Mount
Just wondering if the regulator is still for sale??? If so is it a mallory 4309?? Thanks
Old Mar 17, 2011 | 04:42 PM
91_rs-teal's Avatar
sry sold
Old Mar 23, 2011 | 06:51 PM
91_rs-teal's Avatar
bump :P
Old Mar 23, 2011 | 09:24 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Is the timing set new or used?
Old Mar 25, 2011 | 11:02 AM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
pm sent
Old Mar 25, 2011 | 05:00 PM
91_rs-teal's Avatar
used, not sure how many miles, can get a pic if ur still interested
Old Mar 25, 2011 | 05:05 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Are those pushrods hardened? If so, they in good shape?
Old Mar 25, 2011 | 05:52 PM
91_rs-teal's Avatar
Re: SBC Parts, Centerforce Flywheel, 3/8" Stud Gridles, 92 Camaro Acc. Setup, T-5 Mou
pic added, http://s1098.photobucket.com/albums/...ent=p-rods.jpg
standard replacement push rods, can go a little cheaper if combined with somthing
Old Apr 2, 2011 | 11:35 AM
91_rs-teal's Avatar
up once more
Old Apr 14, 2011 | 04:14 PM
91_rs-teal's Avatar
bump, lifters and t-5 hydrolics added
Old Apr 16, 2011 | 11:55 AM
91_rs-teal's Avatar
Re: SBC Parts, Centerforce Flywheel, 3/8" Stud Gridles, SBC Cam Bearing Tool, T-5 Mou
bump with lower prices
Old Apr 16, 2011 | 03:07 PM
ATOMIC's Avatar
Car: 88 gta (black/black wheels)
Engine: 350tpi
Transmission: 700r
Axle/Gears: 3.27 posi
I'll take the valve covers, whats your paypal info? pm it to me.
Old Apr 19, 2011 | 04:34 PM
91_rs-teal's Avatar
bump, some small parts added
Old Apr 21, 2011 | 08:46 PM
91_rs-teal's Avatar
Re: SBC Parts! Centerforce Flywheel, 3/8" Stud Gridles, SBC Cam Bearing Tool, T-5 Mou
bump, balancer added
Old Apr 23, 2011 | 02:31 PM
83Z28BlackBetty's Avatar
Car: 1983 Z-28, Black w/ Silver Stripes
Engine: LT1 350
Axle/Gears: 3.27 9 bolt posi discs
Re: SBC Parts! Centerforce Flywheel, 3/8" Stud Gridles, Cam Bearing Tool, T-5 Stuff +
I'm interested in the clutch hydraulics (master, slave, lines, etc.) how much for the pedal assembly as well?
~JAKE
Old Apr 25, 2011 | 07:40 PM
91_rs-teal's Avatar
pump for lower prices
Old Apr 28, 2011 | 05:19 PM
91_rs-teal's Avatar
Re: SBC Parts! Centerforce Flywheel, Front Acc. Setup, Cam Bearing Tool, T-5 Stuff ++
bump for cheap t-5 pedals!
Old May 1, 2011 | 04:19 PM
91_rs-teal's Avatar
bumped once more
Old May 3, 2011 | 08:28 AM
hotrodtech's Avatar
Want a title? Post!
Car: 88 IROC-Z28
Engine: Monster 355
Transmission: Borg Warner Super T10
Axle/Gears: 28 spline, locker, 3.42s
is the K&N intake still available? very interested
Old May 5, 2011 | 02:07 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
hey you still got those slave and master for the t5? if so i want them get me info i think i can come pick them up from you
Old May 8, 2011 | 10:17 AM
91_rs-teal's Avatar
bump once more, parting the front acc. let me know whatcha need
Old May 20, 2011 | 04:15 PM
91_rs-teal's Avatar
bumped up top!
Old May 22, 2011 | 09:10 AM
91_rs-teal's Avatar
bump K&N sold, still have t-5 hydrolics!
Old Jun 12, 2011 | 11:15 AM
91_rs-teal's Avatar
bumped up
Old Jul 28, 2011 | 10:15 PM
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
do u still have the clutch pedals and hydraulics? and the t5 crossmember and front accessory's for the motor those r the parts i still need to get again for my swap. if so how much shipped to portageville ny 14536?
also would u have a t5 bell housing? i have heard third gen bell housings tilt the tranny 15 degrees up and if thats true then my s10 bell housing wont work?
Old Nov 9, 2011 | 05:13 PM
91_rs-teal's Avatar
bumped ttt
Old Mar 7, 2012 | 02:04 PM
AMERICAN METAL's Avatar
Car: 1989 Camaro iroc-z
Engine: 355, patriot 190cc, comp 280h
Transmission: 700r4, 3k tall, tci constant press
Axle/Gears: 10 bolt /4.10 GM POSI
do you still have the pedals?
Terrell351
Jun 13, 2021 01:13 PM
anesthes
Mar 10, 2016 10:35 PM
TheExaminer
Aug 25, 2015 07:34 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
1nastygta
Aug 8, 2015 07:38 PM
