[Sold] Cloyes Double Roller Chain w/ retainer plate and bolts (w/pics)-$35 shipped!!
Car: 89 Formula
Engine: 383 SBC/HSR
Also, a Cloyes Double-Roller timing chain w/bolts in original package. It includes retainer plate w/ bolts!! Cloyes Part #9-1100, it only has 5k miles on it also. This bolt pattern fits cars which originally had a hydraulic cam. See CL ad:
http://austin.craigslist.org/pts/2222249019.html
Firm Price: SOLD!!
Firm Price: SOLD!!
Car: 89 Formula
Engine: 383 SBC/HSR
Re: Comp Extreme Hyd. Roller Cam (#XR276HR-10), with Cloyes Timing Chain (w/pics)-Che
bump...
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Re: Comp Extreme Hyd. Camshaft XR276HR-10 & Cloyes Timing Chain (w/pics)-$160 Shipped
what all had been done to the motor the cam was run on? I'm looking for a cam that I dont have to change my stock l98 heads. I understand springs will have to. Also what rockers where you using?
Car: 89 Formula
Engine: 383 SBC/HSR
BLOCK:……………………………350 / 355 C.I.
COMPRESSION:……………..….10.8:1
HEADS:……………………………JEGS 197cc ALUMINUM HEADS
CAMSHAFT:………………………COMP X-ENERGY 227/236 @ .050, .514/.524 LIFT, 112 LSA
PUSHRODS:……………….….….STOCK
ROCKER ARMS:…………………..COMP 1.5 ROLLER TIP
PISTONS:…………………………..SPEED PRO HYPEREUTECTIC DOME TOP
CRANKSHAFT:……………………STOCK
RODS:………………………………STOCK
THROTTLE BODY:………………..52mm TPIS
INTAKE:………………………….…HOLLEY STEALTH RAM WITH RAM AIR INDUCTION
FUEL INJECTORS:……………….30 lb./hr. ACCEL
FUEL REGULATOR……………….BILLET KIRBAN PERFORMACE
FUEL PUMP…………….………….GRANETELLI 255 lb./hr
IGNITION:…………………………. CRANE COIL & IGNITION BOX
WATER PUMP……………………..MEZIERE ELECTRIC
ENGINE MANAGEMENT:………...STOCK ECM/CHIP
EXHAUST SYSTEM:………………1-3/4” HOOKER LT’S / 3” DUAL WITH MOROSO BULLETS
TRANSMISSION:…………………..BOWTIE OVERDRIVES 700R4 LEVEL 2
TORQUE CONVERTER:………....TCS 2600
FRONT SUSPENSION:……….…..LAKEWOOD 90/10 DRAG STRUTS, NO SWAY BARS
REAR SUSPENSION:…………….COMP ENGINEERING SHOCKS, LAKEWOOD CONTROL ARMS &
TRACTION BARS, LAKEWOOD SUBFRAMES, EDELBROCK TORQUE ARM,
UMI PANHARD BAR
REAR END:………..……………....3:73 BORG WARNER FULL SPOOL, TA PERFORMACE DIFF COVER
WHEELS:………….……………….STREET, 17X8/17X9 CHAMP 800 CENTERLINES
STRIP, 15X3.5/15X8 WELD DRAGLITE
TIRES:………………..……….…....FRONT 275/45, REAR 315/35 BF GOODRICH
RACE TIRES:……………………....FRONT SKINNES, REAR 15X10 HOOSIER SLICKS
FUEL OCTANE:……………..…….93 OCTANE
RACE WEIGHT:………..………….3,300 lbs.
BEST ET/MPH…………….………11.91/111 mph
BEST 60 FT……………….……….1.67
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
You say you used an ADS chip who programed it and is the chip for sale?
Car: 89 Formula
Engine: 383 SBC/HSR
I got it for $200 five years ago, programed by ADS themselves. You can have it for $80 if you want it.
Car: 89 Formula
Engine: 383 SBC/HSR
I have a Comp Cam Extreme Energy Hydraulic Roller Camshaft #XR276HR-10 with around 5k miles. It's been custom ground by Delta Camshaft for a little more duration and lift. I ran this cam in my Formula with the stock ECM and had no idle problems, it ran best of 11.90 @ 110mph and it sounded mean!!
227/236@.050
514/524 lift
113 LSA/
2000-5800rpm range
Firm Price: $125 Shipped
227/236@.050
514/524 lift
113 LSA/
2000-5800rpm range
Engine: gone
Transmission: gone
Axle/Gears: gone
you swapping to an LS1 or something heatseeker your selling all your good ****!
Car: 89 Formula
Engine: 383 SBC/HSR
Car: 1966 El Camino Custom
Transmission: 200R4
Re: Cloyes Double Roller Chain w/ retainer plate and bolts (w/pics)-$35 shipped!!
PayPal sent on Cloyes Double Roller timing chain set
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
RyanJB
Sep 14, 2015 03:39 PM
