CFI system, serp setup, T-5 parts, plus more!
Old Mar 28, 2011 | 01:13 PM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Ok,
I decided to swap in a LT1/T56 combo and ditch my old cross-fire system and converted T-5 combo. I ran out of garage space and am now using my neighbor’s garage to store stuff. I need this stuff gone. Some items are priced fairly and won’t be negotiable. Others may be negotiable. (Higher the price, potentially more flex) I won’t be on here all the time, so reply on here and drop me a PM and tell me what you want. I will try and get pictures up tonight.
I will accept Paypal, money orders, cash, and cashier’s checks. I will ship everything and if you are local I can meet you.
I am located in New Orleans.
Here is the stuff I got:
-T-56 Shifter base, stock, torn boot $Make an offer
-Reman LT1 starter (some use) $50 shipped
-Summit 45* coolant neck $20 shipped
Polished and swivels
-T5 cross member $30 shipped
-T5 NWC rebuild kit brand new $100 shipped
Has all bearings, springs, small parts, brass syncros, syncro inserts, fork pads, ect. I will even toss in a printed out T-5 manual in binder with protective sleeves.
I have what is left of the T5. If you need something let me know. None of the gears are any good, the case was weeping under the counter bearing so I don’t think that is good. The tail shaft is useable, the shift cover looks good, has a broken shift fork though, bell housing had the bottom cut off when I got it, I don’t think it is any good. Let me know.
-A/C compressor from 90 V-8 car with hoses MAKE AN OFFER!
-Rebuilt 1 wire alt, fits serp accy MAKE AN OFFER!
-Water pump for serp belt accy, has 5 miles on it MAKE AN OFFER!
Last edited by supr_fly03; Apr 23, 2011 at 11:29 AM. Reason: Added items, updated prices
Old Mar 30, 2011 | 09:00 AM
supr_fly03's Avatar
Car: 83 Z28
Re: CFI system, serp setup, T-5 parts, plus more!
TT
Old Mar 30, 2011 | 01:49 PM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
How much for just the clutch and pressure plate?
Old Mar 30, 2011 | 02:00 PM
supr_fly03's Avatar
Car: 83 Z28
I had a guy send me a PM on it and few other items, if I dont hear from him by friday you can have it for $75 shipped. Pretty sure I have an extra new pilot bushing too I will have to check.
Old Mar 31, 2011 | 07:48 AM
supr_fly03's Avatar
Car: 83 Z28
Sale pending on the following:
T5 Flywheel, clutch, pressure plate $150 plus shipping
T5 mech speedo sender w/gear $15 shipped
T5 elec speedo sender w/gear $30 shipped
T5 torque arm mount bracket $40 shipped
T5 B&M shifter w/bronze bushing $80 shipped
Old Mar 31, 2011 | 12:47 PM
dabomb6608's Avatar
Give me a pm if the sale doesnt happen on the clutch and pressure plate.
Old Mar 31, 2011 | 03:13 PM
supr_fly03's Avatar
Car: 83 Z28
Ok, I will let you know. The guy said he would make payment sometime today.
Elec speedo adapter and torque arm SOLD!
Old Apr 2, 2011 | 09:03 AM
supr_fly03's Avatar
Car: 83 Z28
TT
Sold clutch/flyweel/shifter
Old Apr 4, 2011 | 02:23 PM
supr_fly03's Avatar
Car: 83 Z28
TT
Sale pending on CFI system.
Old Apr 5, 2011 | 11:34 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Do you still have the rebuild kit? I don't need the paperwork as I have my own plus 2 service manuals .
:edit: Oh, and what was the OD gear ratio? I'm looking for the short one (.65:1 or something like that) if they're any good, and also for a decent 5th gear shift fork (not bent).
Seems like the front countershaft area is a common problem... I had the entire housing break up there right at the corner, had it fixed, and it still lost ATF...
Old Apr 5, 2011 | 12:18 PM
supr_fly03's Avatar
Car: 83 Z28
I do still have the rebuild kit, brand new.
According to the T5 thread it has the .72 OD. It was from an 87 V8 car. I have the 5th shift fork and visibly it looked good. The broken shift fork was the 2nd one on the top cover.
I have the case, but it was weeping from the front counter bearing cap and there is some scarring on the inside of the case where the counter shaft rotated.
Send me a PM and we will discuss the details.
Old Apr 5, 2011 | 01:56 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Well, that OD is a lot better than the .76 I have now (which is better than the other trans had with a .78) but not quite the .70 or less I'm shooting for for the gas mileage.
Let me see what I have after I go to the JY and get my quarter panel and front bumper fillers and I'll let you know. Definitely looking for the rebuild kit, however.
Old Apr 12, 2011 | 08:46 PM
fatalicshock's Avatar
Car: 87 Trans Am
how much for the shift fork???
Old Apr 13, 2011 | 12:14 PM
supr_fly03's Avatar
Car: 83 Z28
Which shift fork you want? The middle shift fork is broke. The front one is good.
Old Apr 23, 2011 | 11:14 AM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
how much for the pedal assembly shipped to V0R 1N1 Canada?
Old Apr 23, 2011 | 11:27 AM
supr_fly03's Avatar
Car: 83 Z28
Just recieved payment for the pedals and hydraulics today. Thanks for asking. List updated.
Old Mar 22, 2012 | 03:45 PM
Camman9167's Avatar
Car: 1991 Camaro RS
Engine: 305 Small Block
Axle/Gears: Factory
are you selling the torque arm bracket?
Terrell351
Jun 13, 2021 01:13 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Street Lethal
Aug 13, 2015 08:28 PM
1nastygta
Aug 8, 2015 07:38 PM
