rear end and other misc parts
Old May 11, 2011 | 08:12 PM
nhslacrosse2's Avatar
Car: 1991 z28
Axle/Gears: 2.77 posi
i am looking for a rear end for my 1991 z28 5 speed. i have recently discovered that my car was orgionally an automatic, and the rear end has 2.77 posi. i am looking for either a 3.42, or 3.73, must be a posi and i would like it to have disc brakes but if had drums that would be ok too. im also looking for some interior parts such as rear speaker covers, third tail light assembly, and i need a front liscens plate bracket as well. the interior is grey, email me with anything you have at nhslacrosse2@yahoo.com im located in sussex county NJ thanks
Old May 12, 2011 | 09:10 AM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Re: rear end and other misc parts
know anyone coming thru indiana soon? I dont know the gear ratio though.
Any way to easily tell if the plate is not there? Someone pulled off the cover but gears are all there. Need ur email for pics. disc posi as far as i remember
Old May 12, 2011 | 05:46 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Sending email with pics
Old May 17, 2011 | 03:44 PM
Car: 1991 z28
well i need to know the gear ratio in the rear before i try and make arrangements to get it. im pretty sure the gear ratio should be stamped on one of the gears in the rear end.. you could also spin the tire one time and cout hom many times the drive shaft goes around.
Old May 17, 2011 | 03:58 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the rear is a 10-Bolt:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old May 28, 2011 | 10:04 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
I have a 10 bolt 3.73, disc brake, LCARB's, long ARP wheel studs, does need a carrier though, sides and spiders are out of this one. $150.00 plus the ride.
Old May 28, 2011 | 08:43 PM
88Z350's Avatar
Car: 1988 Iroc Z28
hey man let me check tommorow i have a disc posi rear at the shop , cant remember what gear is in it . if it is what you are looking for i would let it go for 150 . i live just south of allentown pa on route 309 any way i will shoot you a message tommorow
Old May 28, 2011 | 09:00 PM
soon's Avatar
I have a 10 bolt with 4:11s in it, with posi, and a bullet proof cover. If you are interested I will sell for cheap! Its just sitting in my garage, because I put in a new rear end this winter.
Old Jun 2, 2011 | 07:25 PM
Car: 1991 z28
what would i have to do in order to make it a working rear end? im not really familiar with rears. is it posi?
Old Jun 2, 2011 | 07:26 PM
Car: 1991 z28
how cheap are you willing to let it go?
Old Jun 2, 2011 | 09:29 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Unless you can locate a good used limited slip unit, you would need one of these , http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
to make it complete.
Old Jun 19, 2011 | 07:09 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I have a front license plate bracket off of an '89 Camaro if you still need one. Also, keep in mind that if you buy one of those rear carriers, your axles are the 28 spline.
Old Jun 21, 2011 | 11:05 AM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
Found one from an 86 TA thats has disc brakes, borg warner 2.77 or 2.73 which ever it was i forget. But it showed about 88 k in the car. bTorque arm included as pic , I would go $350 + shipping.
Send me your email for pics if interested
Thx
Ray
Old Jun 22, 2011 | 11:28 AM
Car: 1991 z28
thanks but i got my hands on a front license plate bracket the other day
Old Jun 22, 2011 | 06:35 PM
5.0slayer's Avatar
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
im in ohio and i have a 9 bolt posi with 3.27, i will let go im parting it out going with a diff body style, very nice but drums, was just rebuild like a year ago and drove it for like 200 miles if that, can send pics and im looking to get 200
Old Jun 26, 2011 | 08:46 PM
k.jward09's Avatar
sent you a email
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Aug 5, 2015 11:57 PM
