[IA] NTB! Steering Column 85-89 Camaro.
Car: 88 SC, 89 Silvy, 13 Cruze
Engine: LO3, LO5, LUW
Transmission: 700R4, 700R4, M40-6
Axle/Gears: 2.73, 2.73, 3.94
BOUGHT! Thanks again John in RI
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: NTB! Steering Column 85-89 Camaro.
84-89, Tilt, Auto Steering Column,.....$95 + Shipping (has key). I Might have a non-tilt version that would be a bit cheaper too.
If you don't find anything local just post your ZIP & I'll use it to get a few shipping quotes for Ya'.
My zip is 50316, I can't find squat here, been looking for 2 months.
Shipping would be $24 for parcel or ground shipping, insurance included. ( Priority Mail would be $45. ) The column doesn't have a ignition in it now but I've got one with key that can quickly be installed. It's a Tilt, Auto, Column with no cruise and no delay wiper. The Tilt is tight & I would also remove the mounting bracket from the middle so it"s lighter and smaller for shipping purposes.
Here's a pic:
If you would prefer a Tilt Coulmn WITH cruise control and delay I've got one of those too. $130 + shipping.
LMK what works best for you.
Here's a pic:
I'd like the Title w/ cruise, how many miles are on the column, and could you possibly do 135 shipped? 130+ shipping is a little out of my price range :/
I've got to pass........ That's the only 'fully loaded' column I've got and I'd rather keep it than sell it for less.
Priority Mail ( insured ) $45.30
Parcel Post ( insured ) $24.00
P.S. You could simply install your current cruise lever into the $95 tilt, non-cruise/delay coulmn if you needed to retain that option.
Car: Base 91 'bird
Engine: 3.1 v6
Axle/Gears: 9-bolt 3.27 & PBR
I've got one fully loaded with good tilt and key. Lettering is a bit faded. I'd let you have it for $135 shipped if shipping is not too much. Only wrinkle is it's still in the car ('86 TA) and I'm not sure how quickly I can get to it to pull it out. How desperate are you? I assume the Firebird column is the same as the Camaro one. Wheel is not included.
-V8R
Yup, All the cruise control functions are controlled directly thru the blinker lever and all that's need to make an 84-88 column a "cruise" column is to install the proper turn signal arm.
I'll install the ignition key cylinder, prep for shipping, & check operation of the whole column later this evening. There's a chance I will not be able to send another update till sometime tomorrow - my 2 boys play basketball for seperate teams and the weekends get pretty BUSY around here !
Oh Ya; I honestly don't know how many miles are on this steering column. There's only a few "special" columns that allow me to rememebr the car I pulled it from. ( I know my VATS column came from a 120K 89 Formula for example. ) I'm pretty sure that I pulled the key cylinder from this column for use in my S10 Blazer,........ That truck was junked over 2 years ago so the $95 Tilt Camaro column has been in storage for awhile.
Okay sounds good, PM sent
