[Sold] Hypertech and jet Tbi 305 chip's
Old Feb 14, 2012 | 04:12 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I have a used Hypertech p/n 122362 eprom. The specific application is 1992 L03 Tbi automatic transmission. will work with the 1228746 ecm 89-92 f-body. sold as is $80 shipped to the lower 48.
I also have a jet performance chip as well p/n 19110 $55 shipped
http://www.summitracing.com/parts/JE...n/?prefilter=1
Old Feb 15, 2012 | 03:37 PM
white1991rs's Avatar
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
Re: Hypertech Tbi 305 chip
Is this a stage 1 or stage 2 chip?
Old Feb 15, 2012 | 05:53 PM
Engine: Lb9
Transmission: M20
Sorry, I don't know how its classified bye looking at summitracing it shows to be a thermomaster.
http://www.summitracing.com/parts/HYP-122362/
Old Feb 20, 2012 | 08:43 PM
Engine: Lb9
Transmission: M20
Ttt
Old Feb 23, 2012 | 02:46 AM
92rs!'s Avatar
Car: 1992 Camaro RS
Engine: 305 TBI L03
I'll take it. But where does it go haha
Old Feb 23, 2012 | 09:55 AM
Engine: Lb9
Transmission: M20
92rs! your ecm is located on the passenger side under the dash. there are two 7mm screws that hold the ecm bracket to the dash support. First you will need to disconnect you battery and then remove the ecm. once the ecm is removed there is a access cover that need to be removed to expose the eprom. you can grab the eprom and gentle pull , rocking the eprom length wise while pulling sometimes makes removal of stubborn eproms easier. the eprom can only go in one way you will notice the little plastic carrier has pegs on the bottom and the spacing is different from one side to the other. or if you notice the notch on the top of the carrier before you remove your old eprom to see the direction it's facing.
Old Feb 23, 2012 | 11:06 AM
92rs!'s Avatar
Car: 1992 Camaro RS
Engine: 305 TBI L03
Sorry I looked it up & changed my mind.
Old Feb 28, 2012 | 12:02 PM
Engine: Lb9
Transmission: M20
ttt
Old Mar 3, 2012 | 08:16 PM
Engine: Lb9
Transmission: M20
bump
Old Mar 14, 2012 | 10:58 AM
Engine: 5.0 L03 V8
Did you ever run these on your car? if so was there any improvement from your stock chip?
Old Mar 14, 2012 | 11:02 AM
Engine: Lb9
Transmission: M20
Re: Hypertech and jet Tbi 305 chip's
I have never run either of these two eproms, There were pulled for tpi conversions
Old Mar 19, 2012 | 12:09 PM
Engine: 5.0 L03 V8
Is the price firm? If you really want to get rid of it I'd take it for like 20
Old Mar 19, 2012 | 12:13 PM
Engine: Lb9
Transmission: M20
I would like to get a little more than that. witch one are you interested in the hypertech or the jet ?
Old Mar 20, 2012 | 10:23 AM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Axle/Gears: 3.42 Detroit locker
pm'd
Old Mar 20, 2012 | 10:31 AM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
message keeps repeating itself with no answer.. lol.
Old Mar 20, 2012 | 10:35 AM
Engine: Lb9
Transmission: M20
sale pending on both eprom's !
Old Mar 30, 2012 | 10:21 PM
plemon90ta's Avatar
Car: 1990 TA
Engine: 350 in the works
Transmission: th700r
Axle/Gears: 10 bolt Eaton Posi 373
Are they sold ? I'm interested if you still have them. Patrick.
Old Mar 30, 2012 | 10:55 PM
Engine: Lb9
Transmission: M20
03-20-2012 at 07:42 PM SOLD
Glowsock
Jul 24, 2025 03:15 PM
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
NBrehm
Aug 25, 2015 11:49 PM
