[CA] F/S Aluminum Drive Shaft
Car: 1983 Z-28
Engine: 5.7 L
Want a title? Post!
Car: 88 IROC-Z28
Engine: Monster 355
Transmission: Borg Warner Super T10
Axle/Gears: 28 spline, locker, 3.42s
Re: F/S Aluminum Drive Shaft
length u joint to u joint? splines on yoke?
Car: 1992 Camaro
Engine: LB9
Transmission: WC T5
Axle/Gears: 10 Bolt - 3.42
that's a good ? from hot rod. Can you provide that info and we can verify if it'll fit.
Car: 1992 Camaro
Engine: LB9
Transmission: WC T5
thanks for posting the pics, I need to confirm if a b4c had a 26 spline or a 28 spline axle?
I'm interested amd may be able to pull mine off tomorrow to check.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The part number, 10085375, denotes that the shaft is the so-called thirdgen 1LE alum shaft (RPO JG1), which was found in both T-5's and 700R4's.
JamesC
JamesC
Engine: gone
Transmission: gone
Axle/Gears: gone
For the record thirdgen driveshafts are universal. You can put that from a 700r4 to a t5, v6 to v8. So all of the questions were not needed. They'll even fit into a 4th gen. And 4th gen into 3rd gen...
Car: 1983 Z-28
Engine: 5.7 L
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
$80.00 Picked Up???
Car: 1983 Z-28
Engine: 5.7 L
Bump...
Did the sale go through???
Hit me up, 562-233-8396
Car: 1983 Z-28
Engine: 5.7 L
Sold today at 0800 for $80.00
Thank You.
Thank You.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
