[OH] 2.8/3.1L parts(about anything youd need)
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Title says it. I have about any OEM part you would need for a 3.1L V6 engine (A/C Equipted but the a/c parts I do have are not for sale). Just trying to make a few bucks so the prices are very very cheep IMO. Just post up what you need and ill take a pic, get shipping prices and give you a price. Thanks for looking.
Car: 1991 Camaro RS
Re: 3.1L parts/about anything youd need.
TTT
I have everything from the fuel rail, injectors, the 700r4 trans, the sensors, power stearing pump/all accesories, all emissions stuff, and if there is any intrest in the intakes or heads i can port them to the max like the ones on my car.
Make offers, just dont say free....lmao
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Just curious price of heads ported to 02301?
Expecting a lawsuit settlement soon. Want to keep a 3.1 but get as much power as possible outta it.
Car: 1991 Camaro RS
Before shipping id want a good 150 bucks for them. Remember itll take me 30-40 hrs to do then the way i did mine. I started porting the other ones i have the other day a little here and there so that i dont have to just port them when someone wants..ill hopefully have them done when someone wants them.
I get paid on the first.
I'm just trying to get a little more out of a 3.1 without going hybred.
Already had 12°timing set, egr delete, and speed governor moved to 255 MPH. ( thanks again Brian)
Was thinking these heads with 1.6 roller rockers and a delta cam. Undecided on duration. Open to suggestions though. 260 270 range maybe?
going to get headers and already did a cat delete.
Current heads are stock with MANY broken exhaust studs. The PO was horrible to this car. So little by little I'm bringing it back to the way I want.
Car: 1991 Camaro RS
Ill keep working on them and if you want them and there done, there yours.
For a cam.. get the delta 260 grind cam assuming the following. Your automatic right?? And 1990-92 speed density car?? That cam, ported heads, and a mild ecm tune will add you the most power your gonna make for the $$ unless you go hybrid, turbo, or n20. Those engines are good base engines... but it "usually" takes boost or n20 to really wake them up. The day i added boost to my car, is the day i came to the reality that our engines really sux for performance, even with the common bolt on parts(cam, headers, tuning...exc.)
Im sure you may have seen it but heres a nice lopy idle with the 260 cam and ported heads. The reason its so lopey is because it wasent tuned yet and was sticking rich. Im realility you'd never hear a lope with a 260 cam when its tuned right. Its a nice mild streatable cam.
The last few seconds of the video is the best part for the lope.
TTT on the parts. I have plenty of stuff all still for sale.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
A/C or no A/C? If the car didn't have A/C, how much for the pipe connecting the heater core to the water pump and intake outlet (the one running down the passenger's side frame rail by the starter)? Or are you keeping that?
Car: 1991 Camaro RS
@ maverick
The car did originally have a/c. Sorry about that. I didnt even think to add that detail on the first post on parts.
Yeah I'm automatic.
Later on I'd probably turbo it.
With the delta 260, would 1.6 roller rockers work or should I go 1.5?
And what would be needed tuning wise? I'm already 12° with egr, and speed limiter modified.
Should I switch over injectors to the ford 2.9s?
I was also thinking about ceramic coated pacesetter headers.
Car: 1991 Camaro RS
TTT on the parts!!
cavy... I "heard" that 1.6 rockers may hit the vavle covers. So im not sure what youd want there. I have 1.5 rollers(stockers) You may want to look into that before youd get 1.6 rockers just to be sure on what mods would be needed(pushrod length, valve covers)
Tuning youd need about 200 bucks in items to be able to tune/datalog it whenever you want. All the stuffs from moates. The GP1 package and a Burn2 chip burner@ moates.net. Also a aldl cable from aldlcables.com which cost 55 bucks IIRC. The cable is to datalog via laptop. Theres more options on equiptment but this is the items I have and I like them ALOT.
Well damn...lol I'll need to wait on the tuning stuff til my settlement comes in.
I've heard 1.6 full rollers hit but roller tips don't. Also heard the stock pushrods can be used. If you get self alligning just reuse the pivot nut things. Sounds kinda weird to me though.
Could I piece it along? Like due the heads then the cam and rockers later?
Car: 1991 Camaro RS
Parts TTT come on now, someone has to want something....
Honestly Id do it all at one time. Takeing the top of the engine of over and over can sux..lol The cost of gaskets will nickle and dime you, let alone you have to tune it so much more to get what you want out of it.
Save up the cash, get the parts, and do it all at one time. Its much simpler in my mind.
I say this all the time.,, but if you could do one thing that would help the car out immensily, it would be to learn how to tune it first. Theres no way your gonna want to drive it all over with a cam and ported heads on it without a tune. Speed density does not compinsate for your mods at all. Believe me I did that on my car for about 50 miles and said helll with that!! Tuning it right will add more Hp and will make it have the MPG it should have.
I'll need to get a computer and all the tuning stuff.
Out on permanent disability ( 2 neck surgeries awaiting the third. )
So my monthly income has taken a big hit.
Kinda wish I had the ***** to rob an armored car. lol Don't like the possiblity of prison or getting ventilated by lead.
Car: 1991 Camaro RS
TTT
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
.................how much for a tune?
Car: 1991 Camaro RS
Car: 1991 Camaro RS
Bump
Car: 1991 Firebird
Car: 1991 Camaro RS
I see you have a 3.1L what are the mods to it? Every mod that is on it...
Give me 25 bucks for a burnt chip to your door.
But if you have the abilities to just burn the chips then give me 15 bucks for a tune. Hows that sound??
Ive got a good amount of tuning on my 3.1L and lots of good tunes depending on what you have done and what your needs are.
I think thats pretty damn cheep IMO for solid tune files. But im also a person who tries to help out the V6 community as much as I can.
Let me know.
Let me know.
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
price and shipping for:
belt tensioner bracket
power steering bracket
air pump bracket
basically anything on the front side that holds the drive belt items in place. I want an extra set to clean up and paint while I am preparing my 3.4 to go in.
air pump bracket
Car: 1991 Camaro RS
58mark I have all those items except the alluminum power steering bracket as I broke mine and the extra one is going to be used there.
Today is wednesday. If you can wait till saturday I will be able to weigh all the items, see whats the smallest box I can fit them in and then give you a set price. Is that ok????? Ill even take a pic of all the brackets in on picture so I know your getting what you want. The camaro is not at my new house and its 1 hr away along will all my extra parts I have. I will be going there saturday asap as always to work on it.
that's fine. I'm in no hurry. Just wanted to speak up for them
If size or weight becomes an issue, give me a separate price for JUST the power steering bracket
Car: 1991 Camaro RS
Ok will do. Im sure they wont be too much for shipping as most of those brackets are alluminum. Believe me im not trying to make much $$ off them at all. Just trying to get my shop under control...lol Ill get right to it on saturday and contact you asap.
oh wait.. you said you didn't have the power steering bracket... bummer.
still interested, but that's the one I wanted the most. I have a vibration in my AC and I was told it was probably a cracked PS bracket
Car: 1991 Camaro RS
Thats what happend to me. The bottom of the bracket broke on mine over the summer so now I use the good one. Sorry about that but all the other stuff is yours for the taking. Ill talk to ya on saturday.
Car: 1991 Firebird
Let me know.
Let me know.
I'll send ya a pm later. I've got mods coming in the mail, so this is a future tune. Thanks man.
Engine: 2.7L V6
Axle/Gears: 4.41
Forgot I also am in the market for an EGR valve. Just the solenoid unit, don't need the tubes it's sitting on (going onto a 93-95 3100 plenum, plus I already have those but the solenoid unit is broke).
Car: 1991 Camaro RS
This part only correct?
Engine: 2.7L V6
Axle/Gears: 4.41
Yeah, that thingmajig. Just that, nothing else. Have gaskets as well.
Car: 1991 Camaro RS
Ok mav the parts are at my prievous house still. I will be there saturday morning to ship it out ok? Unless your in a huge rush I really dont want to drive 2 hrs there and back durring the week.
Ill send you a invoice on friday ok? Through paypal if thats the way you wana do it. Sure you dont need anything else. Im sure I can jam some other stuff in that medium usps box...lol
Engine: 2.7L V6
Axle/Gears: 4.41
I'm not in any hurry. The car is in the garage right now (stupid storm!) and I can't currently get into my toolbox to get anything out until I get the car out. I won't need to install the valve until I can get the 2 broken exhaust studs drilled out of the one head and get the engine reassembled (put the engine in like an idiot before I drilled the studs out so I had to take everything back apart again
). Thread Starter
Car: 1991 Camaro RS
). Thread Starter
Car: 1991 Camaro RS
Injectors SOLD
Mav do you still want the Egr as if you do I can ship it asap for ya now.
58mark heres some of the brackets..... Just let me know what you want and Im sure shipping to tx wouldnt be more then 15 bucks or so in total.
All the alt stuff:
Heres the tentioner:
Forgot what this is for but do you want it?
PS bracket the steel on only though:
Then all the AIR stuff too:
All the alt stuff:
Engine: 2.7L V6
Axle/Gears: 4.41
Yes, I still want it, but if someone wants it before next week, they can have it. I somehow screwed up with the bank over the last couple weeks and might barely make it for the headers I have a REALLY good deal going on.
BTW, the third pic in your post above is the rear alternator bracket, goes between the bracket on the back of the alt and the exhaust manifold bolts.
My PP address is martianenterprises2k@yahoo.com, BTW.
Car: 1991 Camaro RS
Ok thanks Mav just let me know when your ready. I have 2 egr set ups so ones yours when you want it. theprodigygolfer@yahoo.com is my ppal.
Car: 1991 Camaro RS
Alternator brackts sold
Still many parts for sale.
Do you happen to have the Lower Intake Manifold for the V6 3.1l ? The heater fitting where that big bolt is coroded out and when my friend/mechanic took it out, it busted into dust and after many scraping attempts to clear out the grooves for a new bolt, it just completely cracked the intake manifold where the big bolt hooks into the manifold to hold the heater thing.
Right now its JV weld holding it together from leaks and zip ties. I have looked all over for one for the last couple of months and can NEVER find one on ebay and everywhere else i find them its for local only which is 100+ miles away from where i live.
Would greatly appreciate a nice deal on this if you have it! I get paid tomorrow.
EDIT: Also do u know what part it is that is right by the EGR, its a little black mushroom looking thing about the size of a fist and has vacuum going through it. I cant figure out what its called.
Car: 1991 Camaro RS
Im not sure what the other item is that your describing? Are you talking about the air diverter valve???
Please let me know as tommorow im going to make a run to my parts stash and get items you may need.
Yes I have the lower intake manifold for you. What your zip code please.
Porterville, CA, 93257. Here is a image of the part i want, not sure if this image is the same one you would be pulling out, but before i buy anything whats the estimate on how much its gonna cost me out the door, shipping and handling included?
http://cliff.hostkansas.com/images/2011/DSC02662.JPG
Car: 1991 Camaro RS
Car: 1991 Camaro RS
Car: 1991 Camaro RS
Heres some pics of the items I have off hand
Timing cover, harmonic balancer, crank pully
Cruse control(I have the cable and such also) and the Blower motor for a a/c car.
Air diverter valve and a water pump
Stock oil pump or I can shim it for a extra few psi if you want.
Middle intake manifold and tentioner pully
Dizzy with newer cap and rotor. Also good ICM in there too.
Power steering pump and complete A.I.R pump. Actaully have 2 air systems for sale.
Upper intake manifold. TPS sensor IAC sensor Throttle body EGR tubes.
Fuel rail, regulator, injector harness, and a t-stat housing
2 complete heads. And 4 exhaust manifolds(2 sets)
I also have the stock 1 bar map sensor.
The rear end is for sale. The rear end is local pick up only. 3.23 in the rear and has 110k miles on it.
Thanks again for looking.
Car: 1991 Camaro RS
Also a pair of valve covers
And If you need a tune on a 1990-1992 V6 im your guy!!
Car: 1991 Camaro RS
Bump Bump
Engine: 2.7L V6
Axle/Gears: 4.41
Car: 1991 Camaro RS
No thats fine mav. If you have one to sell him, go for it.
Bump
Bump
Engine: 2.7L V6
Axle/Gears: 4.41
Well, I guess he didn't need it after all...
I'll be paying Thursday. I haven't forgotten yet.
