[NY] C4HD Brake Setup for 17" and larger. Same as baer track kit front/rears near new $500
Old Apr 20, 2013 | 09:11 PM
tonythetoad's Avatar
Car: 91 convertible, 89 TTA, 03 GT2
Engine: 5.0 TBI, 3.8 Turbo, 3.6 Twin Turbo
Transmission: 700r4, 2004r, 6 Speed
Axle/Gears: 2.73, 3.27
these are 13" front and 12" rears stock for j55 option on 1996 corvette grand sport. Will need to modify spindles and buy the adapter brackets from ed millar or on ebay. Very little use, they were on a project car which was never finished. New hawk hps pads up front. Rears dont have any pads. New russel stainless braided lines. What you see is what you get. I also have 2 brand new ebrake cables for the rears for 89-92 cars i will throw in for an extra $25 for the pair. You all know what you need to fit the front brakes onto our cars. The rears are direct bolt on if you have the 89-92 aluminum 1le rear brakes. If not, then you need a 1le rear bracket to install the rears.
Attached Thumbnails C4HD Brake Setup for 17" and larger. Same as baer track kit front/rears near new 0-img_1683.jpg   C4HD Brake Setup for 17" and larger. Same as baer track kit front/rears near new 0-img_1684.jpg
Old Apr 20, 2013 | 09:18 PM
Re: Big Brake Setup for 17" and large. Same as baer track kit front/rears near new $5
Shipping will be a flat rate of $80 anywhere in the States and $100 anywhere in Canada
Old Apr 24, 2013 | 08:41 AM
$500 shipped
Old Apr 25, 2013 | 05:36 PM
Price drop $475 shipped. Someone must want these?
Old Apr 27, 2013 | 12:29 AM
zday's Avatar
Car: 1987 IROC-Z
Engine: 305 roller
Transmission: LT1 t-56 six speed manual
Axle/Gears: 4.10 full posi richmond
Im curious How much you would have to modify the spindles and what kind of adapter brackets are you talking about for the front and back?
Old Apr 27, 2013 | 06:09 AM
I did some research into it, these front brakes are better known as c4hd brakes there is lots of info and parts avail for doing the upgrade. . The backs are stock 1le so if you have a 89-92 with the aluminum pbr rear brakes everything for the back is a direct bolt on. For the fronts, I will check today. For sure you need to modify the spindles exactly the same as if you were to do the 1le swap. Then you need to have your stock rotors turned on a lathe until they are just hubs. Finally you then buy the brackets which are about $85 http://www.flynbye.com/catalog/i56.html
Old Apr 29, 2013 | 01:28 AM
TennesseeIroc-Z's Avatar
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
I see that the C4 and c5/6 brackets are different. Can the same modified spindle be used on both?
Meaning, is there any differences in spindle modifications between the C4, C5, or C6 Z06?
Just wondering where to purchase modified spindles to fit these brakes. I was looking at the different options from BigBrakeUpgrade, they offer a package of modified spindles and brackets, minus the brakes. I can see the bracket is different, but wondering bout the spindles.
I sure would like these brakes....
Old Apr 29, 2013 | 06:16 AM
Re: C4HD Brake Setup for 17" and larger. Same as baer track kit front/rears near new
Check out the flynby website. The spindles are the same but the brackets are different. Get those modified spindles then you can do many different brake upgrades.
Price drop $400 shipped
Old Apr 29, 2013 | 06:52 AM
Pm sir.
Old Apr 30, 2013 | 06:53 AM
Looks like everything is sold to mcmxgateman. Deposit recieved.
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Eric-86sc
Apr 3, 2016 03:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
