[PA] parting out 2 88 Camaro's V6, V8 one manual trans, non AC
Old May 18, 2013 | 06:39 PM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
There are a lot of good parts on these V6 cars-
one has a manual trans- everything is there, clutch, pedals, trans, etc
both are non-AC, so I've got all the items that go with them, the underdash plate to turn on/off vents, controls, boxes, etc.
Have the TPI top end, one wants to start, but rusty gas line is keeping it from doing that....
pulleys, etc are all there.
non tilt columns
I also have a good running 305 TBI from another 88- can still hear it run, since I haven't pulled it.
Let me know your needs, and make offers on items.
http://s1140.photobucket.com/user/sl...Camaro%20items
Old May 18, 2013 | 08:18 PM
THEBEAST84's Avatar
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
Re: parting out 2 88 Camaro's V6, V8 one manual trans, non AC
Looking for a harness for 3.1 engine harness , a tilt steering colum, a set of grey sunvisorslet me know pic can be sent to redblaze332004@yahoo.com thanks again
Old May 18, 2013 | 09:56 PM
pauly01's Avatar
Car: 1991 Trans Am GTA
How is the condition of the manual shifter? Does it still have the shifter ****/handle? How much with shipping to 33860?
Old May 18, 2013 | 10:36 PM
Warnd's Avatar
Car: 1992 z28
Looking for the AC delete box from one of these cars with the blower. If you have some pics that would be great. Sending you a PM
Forgot to mention, I am also looking for the clamshell side of the motor mounts if those are available as well. The side that bolts to the engine block and connects to the frame side engine mounts.
Old May 19, 2013 | 07:12 AM
don't have a 3.1 harness, I am fairly certain I have a tilt column, I will check on the sunvisors.
From what I can see of the shifter, it's clean, and does still have the ****/handle. Let me get it out today....
got it, and I will get that pulled out later today, and I do have the motor mounts- haven't gotten that far on teardown, but will work on it.
Once I get back from church, we'll get working on getting these parts out.
Old May 19, 2013 | 11:32 AM
jessie83's Avatar
Car: 83 camaro 89camaro RS
Engine: 83 camaro 383 with t56
Axle/Gears: 4.11
Iam in need of AC delete box with blower pm me I take it if u got one
Old May 19, 2013 | 07:25 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I've been looking for the rear power steering pump bracket for a non-A/C car forever and a day (2 nuts hold it to the rear of the pump and another to the exhaust manifold bolt and a bolt possibly in the engine block). Also need the pulley on the pump (just the pulley... Have 2 pumps already) if the part number ends in 597 (14100597).
Old May 19, 2013 | 07:30 PM
Ok, let me check into those pieces for you.
How did that firewall bracket work for you?
Old May 19, 2013 | 07:39 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Need to find another bolt for it... Good thing I saved pretty much every fender bolt and "nut" I had on the 87 and other parts cars. Had to scrounge up the screws that hold the MAP on, though. It's working, but it's loose because of the bolt.
But, seriously, I need the pulley more than the bracket (but the bracket would be nice to help get just a tad more belt wrap on the crank), and I need it soon. That, the belt I need the pulley to measure for, and the fuel pump power wire are the only things stopping me from starting the engine for the first time in 3 years (wish I hadn't messed up my original pulley !).
Old May 19, 2013 | 08:53 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Oh, and I also need both parts of the catalytic converter hanger off of the T-5 car (mounted to the trans tail housing and the cat flange) and the rear intermediate pipe hanger (pass side behind the rear wheel, not on the tail pipe) off of the V8. I need to see a pic of the rear hanger first to make sure it's the right one.
Old May 19, 2013 | 09:00 PM
Warnd's Avatar
Car: 1992 z28
Any update on that AC delete with blower?
Old May 20, 2013 | 01:40 AM
XTINCTION's Avatar
Car: 89 formula 91 formula 97z28
Engine: all 350s!
Transmission: T5 in 3rd gen and T56 in 4thgen
Axle/Gears: 3:42 in all of em!
I am interested in the pedals, hydraulic assembly and all the bolts. Ill pm you now.
Old May 20, 2013 | 05:14 AM
I have no doubt I have the bolts.
Will check out everything tonight, and see if we can get it off.
Ok, that too.
Hubby was pulling it off at 8 something last night- got tied up yesterday longer than he expected working on putting an engine in my nephews car.
Got it, we're gonna hopefully have good enough weather to get things removed.
Old May 24, 2013 | 03:30 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Still interested... Money comes Thursday.
Old May 25, 2013 | 06:07 PM
pauly01's Avatar
Received the manual shifter today. Thanks for the quick shipping.
Old May 25, 2013 | 06:37 PM
I haven't forgotten- weather here has been miserable....
You're welcome! Will leave good feedback for you.
Old May 26, 2013 | 10:01 PM
Warnd's Avatar
Car: 1992 z28
Also still interested in an AC delete box. Please let me know if we can make a deal.
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
bjpotter
Oct 2, 2015 09:12 AM
