(PA) Parting Out Multiple Camaros / Firebirds / Trans Ams
I have a few third gen Camaros and a Trans Am that I am parting out. Unfortunatly, these cars are beyond hope, otherwise I would put them back on the road again. I have a ton of extra parts already pulled and from other cars so if you don't see something I probably have it somewhere!
-1984 Z28 (silver)
NO ENGINE OR TRANS. Had a 5 speed and was set up for the track, stainless fuel lines and some other upgraded stuff. Body is great, good quarters, doors, fenders, etc. It does have a hole in the frame which was why she was decomissioned. The previous owner unfortunatly hacked up the rad support to remove the engine.
-1986 Z28 (blue)
NO ENGINE OR TRANS. Had a 5 speed. Had t-tops with keys. Car was in an accident and left to sit for a while. Had locking t-tops with keys! Car is gone but I have most of the parts from it, whatever was damaged went to the scrap yard.
-1987 Sport Coupe (grey)
2.8 V6 with a 700R4 trans, runs and drives but doesn't make it far, the engine has a bad knock. Body is rough as seen in the pictures, interior is really nice, the previous owner had everything shined up and clean inside and planned to fix it up until the motor started to go. *****WINDOW WAS ONLY OPEN IN THE PICTURE. I had taken the door panels off that day and the window was down for the picture, but I did put it up again. None of my cars have ever sat out with open windows, doors, etc.
-1986 Trans Am
carbed 305 with a 700r4, still runs and drives but needs too much to pass inspection plus the body isn't the prettiest (mainly quarters)
base seats, power windows, locks, etc.
I also have roofs, front clips, and rear clips cut off and ready to go. I have machinery to load right onto your truck or trailer too! If you need anything just PM me, I can ship most things. Thanks!
-1984 Z28 (silver)
-1986 Z28 (blue)
-1986 Trans Am
Re: (PA) Parting Out Multiple Camaros / Firebirds / Trans Ams
I'll try to get some tomorrow if it isn't a downpour like they are calling for. It is a carbed motor, not tpi. Please email me at wwe442@aim.com then I'll email the pics to you. Thanks!
Best way to contact me is thru email, wwe442@aim.com. Please put Camaro parts in the subject. This way I can contact you faster since I can't get the site on my phone. Thanks!
Car: 86 Trans Am
Engine: 5.0 TPI V8
Transmission: 700R4 Auto
hows the trans on that TA? im very interested and i need one desperately!
Car: '86 camaro inthe works
Car: 1992 RS Camaro
Engine: 305 Turd Bucket Injected
Transmission: BW T-5 WC
Axle/Gears: 3.42 Auburn LSD, AND it works!
still got a pair of camaro tail lights? looking for the earlier style, either the z28 ones or the regular style, though I'd prefer the z28s. i'll give you $30 shipped for a decent pair.
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
Sent you an E-mail about the Trans Am interior
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
Hi do you have the metal bracket the connects the front spoiler to the fender at the bottom on the front bumper. I need the passenger side. How much shipped to 33010 ?
Car: 82' Z28
Engine: 5.7L 350
Transmission: ST10
What's the condition of the 84 passenger gfx? Any blow outs on sill mounting holes or any damages otherwise? Also interested in the fogs off the 87 if they interchange to 82.
Fog lights from the 87 are gone. I'll have to double check the gfx, I know one was cracked but I don't remember which side.
Car: 82' Z28
Engine: 5.7L 350
Transmission: ST10
That would be cool if all was good to go with the fogs and gfx. Paypal ready for some good pieces! Let me know.
Car: 82' Z28
Engine: 5.7L 350
Transmission: ST10
Car: 91 Firebird convertible
Engine: 350 tpi
Transmission: 700 r4
Axle/Gears: 3.73's
do you have a 91 firebird front bumper? Will you ship to 78516? Thank you.
Can i get some pictures of the hatch and fender, i need the ground effects on the passengers side right below the front of the fender
Car: 92 'bird
Transmission: 700r4, T5 in the garage
Any chance you have a clutch pedal, master cylinder, and U bolt? If so, how much to ship to 27540?
Car: 92 'bird
The u bolt that holds the master clutch cylinder to the firewall. And yes on the pedal rubber, if its decent. I'd like to get the whole pedal assembly (with the brake pedal).
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
I am looking for a Camaro drivers side rear wheel well plastic inner fender insert. the peice you remove for access to the gas tank fill tube. Howmuch shipped to 48127 ?
I like the vinyl look are there any cracks or rips burns ect. If in good shape how much for all 4? Were the door panels gray also?tryin to do a dark gray interior and light gray paint.
The door panels were grey. The driver's seat has the typical rip on the side but otherwise they are really nice. Theyre breathable too so you don't burn your rear end. Do you need the tracks too?
I'm having trouble finding anything online or in the books for it. I know what piece your talking about. PM me please.
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
Antenna please. Power or not. Antenna Tip to radio, harness all of it or any of it especially the wire between the antenna and radio.
I just have one loose one but I think it was from an 89. Not sure if it would interchange with an 82
