Another garage clean out
Ok I am going through my garage getting rid of some stuff I haven't used in a while...I will add some more as I sift through it.
Gauges
New Sunpro voltmeter CP7007 - $15
Used Sunpro triple gauge set CP8091 - SOLD
New Gsport (mr gasket-made by auto meter) 2-1/16" elec. water temp - $30
Used Gsport (mr gasket-made by auto meter) 5" tach with shift light - $100
New Mallory crank trigger #621 - $275
Gauges
Re: Another garage clean out
DFI throttle body...monster 1550 cfm! This was a display part, it is brand new but has some knicks and not perfect, but never ran. #74202S2 - $350
DFI TBI. This was a display part, it is brand new and not perfect, but never ran. Comes complete with 36lb injectors, IAC, and TPS. #77135 $600
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
Can you send some side pictures and different angles of that 3 gauge holder
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
What about hardware, vacuum fittings, IAC motors, or gaskets with the throttle bodies?
The big throttle body has the vacuum fittings and TPS.
The smaller throttle body has vacuum fittings and TPS
The throttle body with the rails and injectors comes with TPS, IAC, FP regulator, injectors, ad vac fittings.
Car: 87 Iroc z
Axle/Gears: 3:27
First need to know does it work and are all wires present and long enough to connect to? Is it also a memory tach?
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
ill take this..Moroso oil filter screen. Brand new #23845 - $10
paypal?..info
shipping? cost
the TB IAC & TPS =GM part numbers?
would have done a PM.. but it dont seem to be working...
paypal?..info
shipping? cost
The IAC is a GM part, but the TPS is a ford style re-pinned into a 3 wire GM connector.
Got the part.new unopened. Will leave good market place feed back. After getting feedback.I would be over 50 good feed backs.butt some guys just don't.do feedback.and some dont know how.
Car: Today? 98 GMC Sonoma
Engine: Seriously? The Sonoma has a TPI 305
Axle/Gears: 7.625/4.10
Ya still have that spacer? I can't seem to remember to compare the injector pods on my TB's, so let me know a total shipped price, (63445), and I'll find out if it'll fit a 454 tb when it gets here. lol If not, I guess I'll use it on my other truck.
Yep still have it. It will be $15 shipped to your door.
ttt...still have most of this stuff. As the weather warms up I'm going to add some more parts. If you are after something you don't see here please ask I have a lot of stuff.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Sep 16, 2015 12:37 AM
Randomtask2
Sep 10, 2015 08:37 AM
84 TA NV
Sep 6, 2015 08:02 PM
