Cleaning out Garage - Gears/Axles/Wheels/Tires/more!
Car: '85 IrocZ
Hey guys, I'm selling some stuff I've accumulated over the past year. All prices are negotiable and without shipping. So please just shoot me an offer if you're interested! Prices are reduced, need room in the garage!
--26 Spline Axles-- $30
Not much wear and tear, splines look good, the outside race for the wheel bearing looks great as well.
--3.23 ring/pinion set-- $40
Just removed this set recently to do a gear swap. The teeth on both look good.
--T56 midplate (LT1 Style)-- $90
Converting my LT1 t56 to an ls1 style, so I'm selling this LT1 style midplate, which does not have the counter-bore to accept the later style slave. Worked fine, never had any issues, just a bit dirty. Does not come with the timken conical bearing race.
http://i26.photobucket.com/albums/c1...psea7f9c9c.jpg
--T56 Input Shaft (LT1 Style)-- $90
I have a used 1995 T56 input shaft, obviously only fits LT1, not LS1 due to the length. I've included some pics. Looks great, barely any wear on the teeth, worked fine in vehicle. Comes with the bearing, which is also fine.
http://i26.photobucket.com/albums/c1...ps1dd246c3.jpg
http://i26.photobucket.com/albums/c1...psc729d634.jpg
--TPI Upper Plenum-- $15
This upper plenum is polished. Does not come with the runners or lower base, and does not come with throttle body either.
--EVOx Intercooler heat exchanger-- $30 obo
I know you're thinking WTF, why is an import EVO component in here, but heat exchangers all function the same. So if you're interested in a cheap intercooler for a turbo swap let me know. I can take some measurements if needed, it was mildly used. I got it from a friend who owned an EVO.
http://i26.photobucket.com/albums/c1...e/DSCF1466.jpg
--Knock Module-- $10 obo
Can't remember the exact years or engines this one is made for, but make sure its what you need if you're looking for one. Part # is in the pic.
http://i26.photobucket.com/albums/c1...e/DSCF1169.jpg
--Stock 2001 LS1 Lifters-- $30
Set of all 16 lifters from a 2001 LS1, they worked fine and are currently soaking in oil. Engine had ~42k miles on it, and they were replaced because i wanted to use LS7 lifters for a performance build.
--4 Stock 85 Iroc Wheels and newer tires-- $500
I've upgraded to new wheels and tires/brakes, so I have no use for the old set. It's the original 85 Iroc wheels and I recently put new tires on the rears...they've probably got ~200 miles on them, lots of tread.
One of the wheels does have curb rash as you can see from the pics.
The front 2 tires are 245/50ZR-16 Kumho ECSTA SPT and the rear 2 are 245/50R-16 Kumho Ecsta AST.
I'd really prefer someone to come pick them up, but if you really want them I can work shipping. I'm thinking $500 for everything but if you think that's too high just shoot me an offer.
http://i26.photobucket.com/albums/c1...psd8434db3.jpg
http://i26.photobucket.com/albums/c1...ps1b5f2065.jpg
--Plastic Snorkel Parts--
I have 2 intake pieces from the original TPI snorkel. Part 1(top) and (bottom part is SOLD!) are both $10 a piece.
--Stock Front Calipers-- $40
I've got a set of good working front calipers. It's just the calipers(piston still installed) along with the standard length of brake hosing, and the 2 pins that hold them to the brackets. I don't have the brackets though. They worked fine, but I upgraded recently.
Transmission: Pro-built 700R4
Re: Cleaning out Garage - Gears/Axles/Wheels/Tires/more!
Very interested in the upper plenum. Can you send pictures to formula_gta@yahoo.com please?
Car: '85 IrocZ
Car: '85 IrocZ
Bump if anyone is interested, I'll be putting them on craigslist and ebay soon!
Car: 1986 Camaro Sport Coupe
Engine: 383 Stroker
Transmission: stage 2 2004r
Axle/Gears: 3.55
How much for both snorkel pieces shipped to 44266?
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Sep 16, 2015 12:37 AM
Randomtask2
Sep 10, 2015 08:37 AM
84 TA NV
Sep 6, 2015 08:02 PM
