[TX] 113 Heads, 89-92 ported base, spacers, 1.6 and 1.5 RR, Cam Motion Cam, 3" I pipe
Old Aug 18, 2014 | 03:18 PM
LT1Formula's Avatar
I've got an accumulation of parts I need gone.
Corvette 113 casting aluminum L98 heads in great shape. Came off running engine with issues at all. Come with full set of LT4 valvesprings and LT4 lightweight retainers (Not Installed) Not pictured but included are the 3/8 rocker studs and guideplates. $500.
89-92 Tpi base ported by Darin Dochterman of High Flow Fuel Injection. Darin chose to leave the runner semi rough to promote higher air velocity. Just needs a cleaning. Darin's ported stock bases outflow cast aftermarket bases and cost less, and look stock. $SOLD.
2 inch billet wheel spacers, lightly used. Price for the pair is $SOLD.
1 1/4 billet wheel spacers, lightly used. Price for the pair is $50.
1 3/8 billet wheels spacers, have a little use on them but work just fine. $40 per pair and I have two pairs of these.
Comp cams pro magnum 1.6, self aligning, 3/8 stud in great shape. $SOLD.
Crane cams gold race rockers 1.5, self-aligning, 3/8 stud in good shape as well. $175.
Cam Motion 218/218 .523/.523 112 LSA. In great shape, lightly used. Fuel pump lobe is no good but most of the cars on this site don't use it anyway. Lift is with 1.6 rockers. Cam is slightly smaller than a Hotcam. $SOLD.
Also have a 3 inch intermediate pipe for single cat cars. I believe it's stainless because it came with an SLP two on the left I had but it does slightly attract a magnet. Some stainless does have impurities in them and can attract a magnet some. My SLP loudmouth does too. It's hard to find just this part. $100.
Dynomax 4 inch bullet muffler, new with Walker/Dynomax turndown. This is for you big HP guys. $50.
Thanks for your time guys.
Size:  68.0 KBName:  DSC03621_zps3b88c9ae.jpg
Size:  63.7 KBName:  DSC03622_zpsd179b99e.jpg
Size:  41.2 KBName:  DSC03623_zps516d4a71.jpg
Size:  50.4 KBName:  DSC03624_zps382077a8.jpg
Size:  57.1 KBName:  DSC03626_zpsd9222de2.jpg
Size:  43.8 KBName:  DSC03627_zps51833e8f.jpg
Old Aug 18, 2014 | 03:24 PM
LT1Formula's Avatar
Re: 113 Heads, 89-92 ported base, spacers, 1.6 and 1.5 RR, Cam Motion Cam, 3" I pipe
Size:  37.8 KBName:  DSC03629_zpsc5681c8f.jpg
Size:  48.2 KBName:  DSC03636_zps191e574a.jpg
Size:  40.9 KBName:  DSC03634_zps488dd730.jpg
Old Aug 18, 2014 | 07:28 PM
Benc1's Avatar
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
How much for the 113 heads without the lt4 springs retainers studs and guide plates. Just the assembled heads? Assuming still has the 1.94 intake valves size.
Old Aug 18, 2014 | 09:25 PM
GCamaroZ28's Avatar
Car: 91 Camaro Z28
Engine: 5.7L with 150 shot of nitrous
Transmission: 700R4, corvette servo with 2600 B&M
Axle/Gears: 3:42
LT1,
how much do you think it would be for shipping of the 2" spacers to 40175?
Are they hub-centric for a camaro/firebird with the correct bolt pattern?
Old Aug 19, 2014 | 12:10 AM
Mr.ChevyStroker's Avatar
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
What is the lift of the cam without the 1.6 ratio rockers? Do you have the rpm band that it is functional in?
Old Aug 19, 2014 | 02:16 AM
LT1Formula's Avatar
Lift with 1.5 rockers is .490/.490. Rpm powerband will be approximately 1500-5500...just a little less than an LT4 hotcam. Great for a TPI car.
Old Aug 19, 2014 | 09:01 PM
Car: RS Camaro
Since the lobe separation is decent along with the durationi at 50. would it be good for a 350 tbi possibly? I dont quuite remember what duration the pcm starts going bonkers....
Old Aug 20, 2014 | 12:10 AM
LT1Formula's Avatar
I've never had a TBI car so I can't honestly tell you much about them. I can tell you that it's great cam for a TPI car. As far as TPI cars go you can go bigger than this cam with no issues.
Old Aug 21, 2014 | 07:04 AM
flintlocks's Avatar
Want a title? Post!
Car: 46 Chevy truck
Axle/Gears: 342
Is this cam for a factory roller block or earlier non roller block, if it is for the earlier block I'll take it
Old Aug 21, 2014 | 01:04 PM
LT1Formula's Avatar
It's a roller cam.
Old Aug 21, 2014 | 01:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Cam doesnt have oem stepped nose so it looks to be retrofit style for older blocks
Old Aug 21, 2014 | 02:39 PM
LT1Formula's Avatar
My mistake I bought it as a roller cam (never looked close enough until now) but apparently the seller was incorrect. If you want it PM me as it appears it is for a non roller block.
Old Aug 21, 2014 | 05:34 PM
flintlocks's Avatar
Want a title? Post!
Car: 46 Chevy truck
Axle/Gears: 342
I sent you a PM,, I do want the cam,, Thanks,,
Allan
Old Aug 21, 2014 | 07:17 PM
flintlocks's Avatar
Want a title? Post!
Car: 46 Chevy truck
Axle/Gears: 342
Just sent you the payment,, thanks
Allan
Old Aug 21, 2014 | 08:12 PM
LT1Formula's Avatar
Thanks Allan. Cam is sold guys.
Old Aug 27, 2014 | 02:18 AM
LT1Formula's Avatar
Sold a few parts.
Old Sep 11, 2014 | 01:07 PM
LT1Formula's Avatar
Bump.
camaro71633
Sep 1, 2015 10:24 AM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
happyhapka
Aug 15, 2015 04:42 PM
