BRAKE COMBINATION VALVE - Video on how to test
Old 03-13-2013, 11:09 PM
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
Hi guys..below is a video on how to test our brake combination valve..i forgot to mention that u can also use a brake pressure guage to test the proportional valve..the fronts should read around 1200 or more and the rear brakes should have around 500-800 psi...u can subscribe to my channel for updates on future thirdgen vids..thanks!
Sweed504 (08-05-2023)
Old 03-14-2013, 07:20 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: BRAKE COMBINATION VALVE - Video on how to test
Very nicely done. Finally a comprehensive explanation how OUR prop valves work!
I especially like the testing methods. I was never certain how to evaluate whether the thing is working properly and will use those tips to check my freshly installed system.
Thanks!
Old 03-15-2013, 08:46 AM
Thanks man..I know it is very hard to find good information on these things..
Thanks for watching! There are more videos to come!
Old 03-18-2013, 04:52 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Hey,
I did the paperclip-test and checked the movement on both ends. The pin moves out of the valve and back in, the paperclip also moves out and back in, though quite hesitatingly, I think.
There is about a half-second delay between fully pressing the pedal and paperclip movement. Is this normal?
Same goes for releasing the pedal.
It's like a thermostat. It "pops" open and back, no gradual movement.
Old 03-18-2013, 10:55 AM
that sounds normal..the valves have to have the right amount of pressure to build up before they both start moving
Old 03-18-2013, 03:20 PM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Ok, thanks. Makes sense.
Old 03-25-2013, 09:20 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
This is a great help. I've always considered combination valves to be some sort of mystery. I know what they do. But I don't know WHY or HOW they do it. The ability to test them is beneficial to rule them out. Because let's face it, 90% of people here complain about having no to little rear braking. The aftermarket Grainger springs make sense now in terms of why they're better.
Old 03-26-2013, 02:32 PM
yeah i realized alot of people do complain about their brakes on thirdgens..just one more thing to rule out, like you said.
Old 05-01-2013, 03:29 PM
funny thing..my friend called me up the other day and was having metering valve issues on his car.. kind of a coincidence it was around the same time i did this video lol...
You guys might want to check and see if your metering valves are in working order..alot of people do not realize this...make sure when u take the mushroom cap off the metering and prop valves..that the valves arent stuck on the out position..or halfway out position....pretty much follow what i talk about in the vid to test them..
Old 05-08-2013, 07:51 PM
IROCmenace's Avatar
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
Thanks a ton for this info! I am fighting brake issues right now and this is my next thing to tackle.
Old 06-07-2013, 11:29 AM
oh..Irocmenace..did you find the issue?
Old 06-08-2013, 07:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you've asked for other videos or have quesions about them, please PM the OP.
JamesC
Old 06-14-2013, 01:08 PM
Thank u
Old 12-31-2014, 10:17 AM
Just wanted to add the below video..you can check your brake pressures using the below gauge..i show how exactly to do it on a thirdgen. We were trying to see if the pressures to the back wheels were correct for the drum brakes that were on the car, in other words you can also check to see if your proportioning valve is working like it should.
Old 04-16-2015, 09:33 PM
1986lt1boy's Avatar
Car: 1986 Trans AM
Engine: 396 LT1 Stroker
Axle/Gears: Ford 9 Inch w/ 3:70 Gears
Do you know what the P/N is for the thicker "Vette Spring" ?
Old 03-20-2016, 10:40 AM
GCrites80s's Avatar
Car: '87 IROC-Z
Engine: TPI 5.7
In the first video, the OP states that the reason for having two separate springs is for panic stops. I'm thinking of adding an adjustable proportioning valve for autocross. They just have two passages and will apply the same pressure on all stops. Would I be making my car more dangerous on the street if I install the adjustable one?
Old 03-24-2016, 08:00 PM
esc
esc's Avatar
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Early third gens (like mine)don't have that extra valve.
Old 12-27-2018, 07:28 AM
87_LG4's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
Transmission: TH-700R4
Hi, can You answer me a quick question? On the red valve on the rear brake side of the prop valve, there is a small seal. behind the spring and the ridge on the valve. Witch way should the lip on the seal go. And where do the pressure come in, from the master cylinder? In on top, or in on the bottom port?
Old 01-05-2019, 05:09 PM
87_LG4's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
Originally Posted by 87_LG4
Hi, can You answer me a quick question? On the red valve-stem on the rear brake side of the prop valve, there is a small seal. behind the spring and the ridge on the valve-stem. Witch way should the lip on the seal go. And where do the pressure come in, from the master cylinder? In on top, or in on the bottom port?
ANYBODY !!!!!
Someone who knows about this valve?
Old 02-15-2019, 08:12 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
ANYBODY !!!!!
I am no expert by any means, but maybe this photo, (WHICH I TOOK TODAY) can be of use for you..
for your second question...I would think the fluid comes in from the top port an exits the bottom too right?
1992rs/ss
05-19-2020 07:02 PM
Vintageracer
01-10-2020 05:33 PM
Street Lethal
04-30-2019 12:14 PM
1992rs/ss
16
01-28-2016 09:58 PM
Quick Reply: BRAKE COMBINATION VALVE - Video on how to test
