LS1 caliper threads stripped
1 Post
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
Hey question for everyone would it be ok to chase LS1 caliper threads where the banjo bolt threads into or do i have to replacd the whole caliper now its only the top part of the threads that got stripped out not the whole way through
1 Post
Re: LS1 caliper threads stripped
Bump no one knows
1 Post
Would u happen to know the thread pitch of the 4th gen calipers i been looking online all day long and cant find out what it is
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i believe it's 10mm- take the bolt to a hardware store and put it in the thread checking gauge that they have in the bolt area.. then while you are there, get the proper tap..
Received 1,672 Likes
Chasing it probably won't work. All that does, is remove metal that's in the way; doesn't put already-removed metal back. You can try it, but don't be too surprised if it doesn't. When you cross-thread a bolt into aluminum as it sounds like you did, there's usually not anything left to "chase".
A Heli-Coil however will fix it right up better than new. If you have to buy any tools, i.e. if you don't already have the right thread chase, I'd suggest not spending money on that, but go straight to a Heli-Coil kit instead.
1 Post
Yea ended up getting s heli coil kit and it seems to be holding up on now to bleed it and see if there are any leaks then my LS1 brakes will finally be complete
rudolphschenker
09-04-2015 02:41 AM
UltRoadWarrior9
09-02-2015 08:24 PM
