Radio wiring help
Radio wiring help
So im trying to wire in a factory head unit with the EQ from a later year 3rd gen into my 86 IROC. The wire harness that is in the car wont fit the radio so Im left to splice the wires together.
Ive figured most of them out using diagrams I found here, except for a few. I got all the speaker wire figured out so they arent the problem.
The power wires are leaving me baffled. All the diagrams Ive read have a different order of wire than what I have. Even my chiltons book have different orders of the wire.
In the pic below, the top wire (orange) I believe is 12V constant, the yellow wire is 12V ACC. Im lost after that. I have a grey wire, brown wire then black. Im sure the black is ground, but according to some diagrams the black should be in a different spot.
Can anyone shed some light on this for me please?
Car: 16 Equinox,12 Silverado,91 Z28
Engine: 3.6l, 5.3l, 305 H.O.
Transmission: 6 Spd auto, 6 Spd Auto, 4 spd Auto
Re: Radio wiring help
See my reply and attached doc with with color codes for 91-92 Camaro radio.
https://www.thirdgen.org/forums/car-...und-radio.html
I found the info I needed. Just a bit a digging around found that they changed plugs in 89. So i just found wiring diagrams for both plugs and that was it. This place is great!
Car: white 87 iroc-z
Engine: 5.7 tpi
Axle/Gears: 3:27
Hey, can i get that info to, i am in the same boat. email me at spco818@comcast.net
Car: 1991 RS Camaro
Engine: 400 Smallblock
I believe that the dark brown wire is for a dimmer switch and the lighter tan-ish wire is unused, or at least thats what I can determine from looking at wiring diagrams and trying to remember when I did this.
If you ground that black wire and leave the brown and light tan wire disconnected the stereo should work fine
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Those are great diagrams!
I just want to add that the "lights dimming" and "lights on" wires are reversed if you are installing a later model GM radio (late 90's-up).
I'm replacing the carpet in my 89 RS and I want to run the speaker wires in the factory duct on the drivers side to the trunk. Have any of you heard of anyone doing this? Were there any issues like hum from the gas tank electronics?
Car: 87 Iroc
I was trying to install a radio in my 87 that the previous owner just cut out. All that I have to work with is a bunch of wires, there is no factory plug. Is this normal? I've done a few installs before and they all had a factory plug.
Car: 89 IROC-Z
Engine: 5.7L 350 TPI
Transmission: "The Beast"700R4 with B&M shift kit
Axle/Gears: 2.77 4 wheel disc brakes & CE SFCs
Ive got the black white blue connectors all reinstalled in mine but does any body know where I can get a replacement pigtail for the two prong connector shown above on the 82-88 diagram, the one for orange 12 vDc constant and brown light dimmer.
Car: 88 gta (black/black wheels)
Engine: 350tpi
Transmission: 700r
Axle/Gears: 3.27 posi
metra 71-1677-1
plugs into factory radio (replacement plugs)
http://www.sonicelectronix.com/item_...71-1677-1.html
or any local stereo shop can order it by that number
1 Post
Car: 92 Camaro Z
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Reviving an old thread (Searched!)
I wired in my aftermarket stereo last night based off XxWickedz28xX's diagram listed above for the 92 models. My stereo has another blue wire identified as a "power" wire on it but there are no blue connections on the wiring harness i bought. Everything else lines up perfect except this wire, which im not sure it goes to, or if its even relevant.
Anybody have any insight to this?
thanks
thanks
Car: '83 Z-28
Engine: 5.0 CFI
Transmission: 700-R4
thanks
thanks
Car: 1986 IROC-Z
So glad I found this thread. Was getting really pissed off trying to figure out why the former owner chopped the factory harness off. Now I know what goes to what! Thanks boys!
Car: 1986 Pontiac Trans Am
Engine: 350 cid bore too much to list.
Just had to look up this diagram and since I hacked up my harness back when I was 16 years old because I didnt know any better I have to splice wires. Thanks for diagrams and info guys.
Car: 1984 Pontiac Trans Am
Engine: 305 V-8 H.O.
Transmission: 5 Speed Manual
Question I have a 1984 Pontiac Trans Am and I am putting the OEM Am FM Cassette radio back in, I still have all the factory connection.
The Plug colors are Blue, White and Black, is there any order they go in behind the radio
Thanks ~~~ Don
Thanks ~~~ Don
Car: 84 Trans Am
But not to worry they only fit one way. Black on the bottom, White middle, Blue top. Also there is a 4th plug back there. 2 wires Orange and brown. It will go to the pigtail coming out of the back/middle of the radio.
db057
08-11-2015 10:11 PM
