89 305 TBI CONVERSION TO CARB HELP!!!!!!
Car: 89 camaro rs
Engine: 305 v8 tbi
Transmission: 5spd
i have an 89 305 tbi 5spd that I want to have converted to carb. I want the most power that i cant get out of this conversion but I dont really know what parts would be involved. If some one could please write me a list of specific parts that would great, everything that i would need to do this conversion while making the most power. I also wanted to add a new performance manifold and cam. Please any help would be great. I already read the sticky but pictures of this would be great, thanks!!!!!
Re: 89 305 TBI CONVERSION TO CARB HELP!!!!!!
Parts List:
- Carb
- Intake manifold
- Vac/Mech advance distributor
- Cam
- Fuel Pressure Regulator
- All necessary gaskets/bolts/fuel lines/fittings
Other notes:
- The fan will need to be re-wired to bypass the ecm
- Torque converter lockup will need to be addressed, usually manually controlled.
- Make sure carb had TV cable attachment on it if you are using the 700R4
- Carb
- Intake manifold
- Cam
Other notes:
Car: 89 camaro rs
Engine: 305 v8 tbi
Transmission: 5spd
Thanks!! any specifics on what brands/model to get?? also isn't the lockup only a problem in automatics, any pics of this conversion??
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
And heads. Don't forget TBI heads will thwart any other modifications done.
Carb: Avoid Edelbrock. Since you have a 5-speed, you'll want a double-pumper style carb. That means Holley or Demon, or a company that makes clones (Proform, Quick Fuel Technologies, etc.).
Car: 89 camaro rs
Engine: 305 v8 tbi
Transmission: 5spd
so i am going to need new heads??? why? and any particular heads you recomend?
Car: 90 formula
Engine: 305 carb
Axle/Gears: auburn 3.73 posi
fuel pressure regulator I used a mallory 4309 and it worked like a champ..will forward pics and 57kid is exactly right about the heads...they have a blockoff in the intake runner that looks like it takes away 30% of the flow. I picked up a set of tpi heads and they work much better with the new cam and intake. If you dont care about keeping the centerbolt valve covers there are a lot of good deals on 602 heads for like 150.00 a piece all over the web. The centerbolt tpi heads are a lot harder to find.Conversion went together very well but be prepared to spend some hours on stuff....Good luck
Buzzman1
Buzzman1
Car: 90 formula
Engine: 305 carb
here are the pics , I just got mine running
Buzzman1
Buzzman1
Engine: LS1/LQ4
The '87-up heads have a different intake mount bolt pattern than 90% of carb intakes. Not a bad reason to give up center bolt heads.
Of course, there are also Vortec heads - center bolt valve covers, but requires a Vortec-specific intake manifold.
Car: 89 camaro rs
Engine: 305 v8 tbi
Transmission: 5spd
Thanks for all the input but im stil a little confused. This is my first motor bigger than 4cyl that i have ever touched. I am very unfamiliar with these 305's. What is the centerbolt head and a 601 or 602, and what would it mean if i i got heads that were not centerbolt?
Car: 90 formula
Engine: 305 carb
you would have to get new valve covers but 57kid id right that the intake manifold bolt pattern is different on the centerbolt vs the older style heads. The intake cost me about $30.00 more for the newer style but there are a lot more choices for the older heads and they are a little less money. I stuck with the centerbolts because I had the valve covers and spark plug wire minders for the centerbolts.good luck
Buzzman1
Buzzman1
Engine: LS1/LQ4
416, 601, 081 - those are the last three digits of the head casting number.
Center bolt - Starting in 1987, the factory went to 4 bolts down the center of the valve cover to hold it on. Before that, they had 4 bolts on the perimeter of the cover. Hence, center bolt vs. perimeter covers.
Car: 88 GTA "Cocaine"
Engine: 350 tpi
dont let everyone scare you out of the heads you have
the throttle body heads make scary torque out of the hole which is good on the street
only drawback is that they dont flow well over 4500 rpms
so shift under 5k
so shift under 5k
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
i wonder if that why my time on the track was only 16.0-16.3 because i was shifting at 5k each shift
Engine: 350 tpi
yeah if you want a quarter mile car these heads suck without major porting.
the exaust side flows really well but the ramp in the intake needs some major work
on the street it will pull really hard off the line to 5k
Car: 88 FIREbird
Engine: 305ci
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
hey buzzman what throttle bracket did you use it looks like it worked quite nicely my stock one sits to far from the carb so it doesnt wrk
zig
zig
Car: 90 formula
Engine: 305 carb
it is a holley hly-20-95 and I had to move it back about 1/2 an inch with a piece of steel but that bracket lines it all up nicely..you will also need a a hly-20-121 0r something like that to line up the cables and if you are using the stock tv cable you will need to shorten the cable to get it in the right postion, I drilled a hole in a bolt and a nut to shorten the tv cable like a bike brake cable. If you need pics let me know and ill take them.good luck
Buzzman1
Buzzman1
Engine: 383
well i thought i was gunna need sumthin like that but my dad came up with an idea we actully cut the mounting holes off and moved them back about 3/4 of an inch and it worked great
thanx though
zig
thanx though
zig
stay with tbi or go carb ??
hey guys i just bought an 88 firebird with no engine in it so im going to build a 350 to put in it so what im wondering is should i stay with the TBI set up or just put a carb on it ??? it has a 700R4 in it and im going to rebuild it for street/strip use. any help would be awsome ... thanx
Greetings from england. Im converting mine from tbi to carb and was going to use an edelbrock. However it seems after reading some posts that these are not suitable? Why not?
Car: 84 camaro berlinetta
Transmission: th350 4spd auto
1990 camaro tbi going to carb with th350 trans have a 83 camaro carbed as donor for gas tank ans wiring harness getting rid of computer 83 has electronic fuel pump but was was origional carbed car does that sound right? any help would be nice
Car: 88 Camaro
hey there,
what headers have you used?
im converting mine from tbi to carb and halfway from junking all the egr and seems a good time for a upgrade
Car: 92 camaro t-tops
Engine: 305 tbi
Transmission: auto
Axle/Gears: stock
im having the hedman shorty style put on mine right now they are pretty beastly you can get them from jegs for 159.00 plus shipping
Car: 88 k15000
Transmission: th400 (m80) 4x4
Axle/Gears: original
Depending of the carburetor available(mine s a holley 2 barrel 8450 from a 79 dodge ramcharger with a 360 engine) the aluminum adapter plate is made, I used the mounting gasket from the rebuild kit as a template , the adapter plate is made out of 1/2" aluminum then the carburetor bolts are drilled and tapped
there was enough clearance for the carburetor barrels to open without touching the intake when opened all the way one hole is drilled thru the plate to attach it to the original intake hole I used a bigger bit and an allen head bolt to make sure is flat on the adapter plate surface, the rest of the install requires epoxy all the way around were the adapter plate makes contact with the original intake leave it overnight to cure and presto
this is what my 88 k1500 looks like now, for the fuel pressure conversion(the original pump puts out 13 pds of pressure a carb would hold of to 9pds of pressure) I left the original pump in and used a Cadillac CTS fuel filter under he hood this filter has 3 lines to it in out and return, so I installed the input line in by the carb the return line bythe carb also)previously they would go behind the tbi and then he output line was hooked up to the carb NO PRESSURE REGULATOR NEEDED) since this filter has a return line all the extra pressure would just return to the tank and would not affect the carburetor.
a hei distributor from a 76 chevy truck was used and THE WIRING HARNESS WAS NOT CUT just tape it correctly and tuck it away on top of the manifold THATS ALL YOU MADE IT CARBURATED NOW!!!!!!!!!!!!!!
Car: 88 k15000
yes I do as a matter of fact I have an 88 and a 95 throttle bodies the 95 was rebuild the 88 was being used at the time of conversion my issues were with rats chewing on the trucks wiring( I live in the countryside) and I can help you with them, sendm me a private message and ill get back with you on how to go about this,thanks and godbless
