89 Camaro Convertible parts questions
Car: 1989 Camaro RS convertible
Axle/Gears: 2.73 open
OK so I bought a project car. Of concern to me, is 1) the trunk latch is missing, and 2) the pin that goes through the center of the deck to latch the top down seems to be missing from the last top bow. Is it bolted on or part of the bow? Any shade tree ways or repair kits to replace this missing part? How about replacment trunk latches? I'm sure there may be other missing pieces as I really haven't done much more than bring the car home. I put the top down once to see how it all works. Thanks in advance!
Boyce
Boyce
Engine: 4++,350 & 305 CIs
Re: 89 Camaro Convertible parts questions
Welcome!
Fill out your avatar information so people will know more about u, where your at and what ya drive.
I have a 89 Camaro vert parts frame and can look to see if it has what ya need.
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Thanks guys! Let me know about the parts frame, and in meantime I will ck the vendor!
1 Post
Car: 89 GTA/90 Iroc Vert
Engine: 5.7/5.0L
Transmission: 700R4 x 2
Axle/Gears: 3.27/2.73
http://www.top-downsolutions.com/hat...pull-down-unit
they also sell parts.
Those are hatch pull down motors, maybe they'd work ? My vert doesn't have a motorized pull down.
Be patient and look around for parts, lots of members here have what you need. Verts are rare in junkyards.
Take your time, and keep telling yourself "its a project" - that's what I do.
Car: 89 Iroc Convertible
I have several of those pins that lock down the rear top.It attaches with 2 torx screws
Car: 1992 Camaro R/S
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Top down solution don't have s__t jersey89GTA said take time. I'm doing and convertible that had a lot pieces missing, staying on the Internet and eBay I eventually found everything I needed all in the color I needed because I didn't want to paint the parts. It took some time but I got everything.
Lon
Car: 89 IROC Convertible
Engine: 383
Axle/Gears: 373 strange axles
Yours HAD a motorized hatch (trunk) pull-down unit when it left the factory. Same one as the t-top and hard top cars. In mod 91 they changed the pull-down unit on the t-top and hard top cars to a different design. At that time they also changed to a non-motorized latch for the trunk of the convertibles.
Lon
Lon
89 convertible with motorized pull down for the trunk.
can I swap to a NON MOTORIZED setup....maybe from a 91+ ?
Is there a direct fit?
Rob
That grease is too sticky IMO. If you can't use the synthetic marine grease, then use white lithium grease. I used white lithium and recommended it before I switched to the synthetic marine grease. White lithium has a buttery smooth consistency which is very similar to the original light colored blue grease GM used. However with time it dries out and needs to be replaced.
Lon Salgren
Lon Salgren
Engine: 383
yeah that stuff is sticky.
will get me some synthetic marine next amazon order.
after checking the cabinet.
thanks
thanks
1992 Trans Am
05-10-2023 07:19 PM
