Air not blowing from vents
Old 12-02-2007, 11:36 PM
jtreadwell's Avatar
Car: ?
Engine: ?
Transmission: ?
1991 Firebird, 3.1 V6. The AC does not work, but that is probably a freon leak somewhere. (good time to convert) The compressor kicks on, but AC, heat, or just vent does not blow from the front vents, or the floor. Just by the windshield. The defrosters work, mostly. Where do I need to start looking?
Old 12-02-2007, 11:45 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Re: Air not blowing from vents
Start by checking the vacuum line under the hood. If you have a vacuum diagram under your hood it will have a section that says "TO HVAC". This provides the dash with manifold vacuum to operate. Defrost is the default setting for safety purposes. There should also be a check valve inline with the line coming off the intake.
Old 12-03-2007, 12:42 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
You might want to the cooling board for vacuum diagram. You should find a few good diagrams showing all the vacuum connections for the heat/cool controls regarding the air flow.
Dave
83 Crossfire TA
01-03-2016 01:26 PM
64goatman
09-09-2015 01:09 PM
TBRays98
09-06-2015 05:05 PM
scotrans am
09-05-2015 04:26 AM
90formulaVortec
09-03-2015 09:26 AM
Quick Reply: Air not blowing from vents
