A/C Delete Box Differences?
Forgive me if this has been addressed, but I looked through like 30 threads and couldn't find this answer. The pictures below are aftermarket fiberglass a/c delete boxes that accept the a/c blower motor fan. The first one shows a large raised triangle on right side mounting flange and the other does not have this. I noticed that the factory boxes seem to have this large triangle. What is this difference? I also found a seller with new gaskets that fit the "triangle" box.
I would be installing this in an 82 Trans Am and want to make sure I'm getting the right one if it matters. Thanks for the help!
Raised triangle mounting flange:
No raised triangle:
No raised triangle:
Re: A/C Delete Box Differences?
FWIW....
1986 Assy Manual shows the black box configuration. I can't comment on whether or not this was the correct configuration throughout the 3rd Gen production.
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
I bought one that looks like first one,came from Ukraine.That part description says that ac blower motor fits,it didn't.Otherwise fits ok,but needed non ac blower+cage.
Thanks for the input on that one! That's the one I'm leaning towards because I like the look of it, but if I need the other one, I'll live with the look I guess. I just can't imagine a triangular shaped cut out in the firewall, but I could be wrong. I have an 82 Trans Am and an 89 Firebird, both A/C cars and the firewalls look the same to me. I've had the a/c box out of the 82 before when I was painting the firewall, but for the life of me don't remember a hole that high.
https://www.thirdgen.org/forums/afte...-c-heater.html
Here are pics of it installed. I have since remove it and painted it black to match the firewall.
http://www.fquick.com/garages/viewga...=3&carid=31671
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
Im not 100% sure, but I know in the past when I have deleted A/C in past vehicles; 77 Monte Carlo, 77 Corvette, 72 Malibu, 70 Malibu, 69 Malibu, 68 Chevelle SS, the firewall is cut differently between a factory A/C and factory non A/C cars, they require a different box than what a factory non A/C car would have taken.
Transmission: 5-Speed Manual
Here is the link to the thread I made about the heater box I bought. Has pics also.
