what wideband are yall using?
1 Post
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
I will be tuning with the EBL flash and am looking to buy a wideband just wondering which one I should get.
Re: what wideband are yall using?
I'm happy with my 14point7.com PP2.
1 Post
Engine: forged 350
Ok thanks so the pp2 with sensor for $275
1 Post
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
I use original SLC DIY from 14point7. Planning to use the Spartan on another project soon.
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Slc-diy2 here. I love the thing and it's worked great for 3 1/2 years now.
Originally Posted by 92rsvortec350
I will be tuning with the EBL flash and am looking to buy a wideband just wondering which one I should get...
http://dynamicefi.com/TT-1.php
1 Post
Engine: forged 350
No reason at all just seeing what everyone is using and if there is any pros and cons to different ones and what not. I do see the TT-1 is a little cheaper.
No reason at all just seeing what everyone is using and if there is any pros and cons to different ones and what not. I do see the TT-1 is a little cheaper...
1 Post
Engine: forged 350
Ok great thanks. so can you run a wideband all the time in the place of the stock style nb?
1 Post
Engine: forged 350
yeah I guess I will be running the wb in the other collector.
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
AEM UEGO 4110. Works pretty good. Hid the gauge in the vent. http://www.summitracing.com/parts/avm-30-4110
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Innovate MTX. I can't speak for other setups, but with the innovate it does have a 1V simulated narrowband output so you can replace the factory narrowband with the wideband sensor.
Car: 87 IROC
Engine: 420 EFI
Transmission: TKO500
Axle/Gears: Moser 9" 3:50
Hi Guys,
I am running dual WBO2 from Dynamic EFI (RBob).
They work great.
Best Regards,
Bruce
They work great.
Best Regards,
Bruce
Here's where I mounted my PP2
just to add to my previous post, I have used Innovate LC-1s in the past, but prefer the 14point7 products.
I recently got a hold of an AEM Failsafe gauge, which is a Wideband O2, boost gauge, datalogger and warning system/auto shutdown/switch over device that I will be testing out once I get a replacement O2 sensor and get my car running again.
I have had the LM1 from Innovate Motorsports for years......big and bulky, but still works great and i get the data out of it into the datastream, for datalogging.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
LC-1 for many years now. Less expensive and compact size.
Logs to datastream and gauge on my pillar with 2 different outputs.
pwdbychevy
04-16-2023 07:27 AM
efiguy
09-27-2015 01:30 PM
