Cruise control wiring harness question
Old 08-28-2016, 11:47 AM
BovineZro's Avatar
Car: '91 Camaro Z28
Engine: L31 5.7
Axle/Gears: 10 bolt, 3.73
I debated putting this in the transmission thread; mods, please move it if that would be the correct location.
My question is this: I have a pedal harness from a 90 TBI Camaro with cruise control. I'm installing it in a 91 TPI Camaro with no cruise control (part of my T5 swap). This harness has all the provisions for the cruise control module, which I don't need. Am I OK to use this section of harness and just leave the connectors for the cruise control disconnected? Or will I need to make modifications to the harness? The wiring from the brake switch (which is the only thing on this harness I need) seems to be independent of the cruise control wiring.
I've browsed through a couple threads and hunted through so many wiring diagrams I had dreams (nightmares?) about them. It doesn't look like this would cause any problems, but I haven't been able to determine that for sure. Any input would be greatly appreciated! I will get some more detailed pictures of what I'm working with and post them later today.
Thanks in advance!
Old 08-28-2016, 06:19 PM
BovineZro's Avatar
Car: '91 Camaro Z28
Engine: L31 5.7
Re: Cruise control wiring harness question
Well, I (think I) figured it out. I was definitely overthinking things here!
That section of harness actually doesn't do anything for me; it doesn't send any signals where I need them to go. Instead, I just need to get the clutch switch wired up to the heavy gauge wires on this harness:
So I just cut the connector off of the section of harness I had and I'll wire it into this harness. Simple!
Kenneth Elmore
05-03-2016 12:15 PM
ken3983
04-13-2016 11:43 AM
ken3983
04-10-2016 06:29 PM
NewGuyw/89RS
09-04-2001 01:08 AM
CD MaroMan 91
Car Audio
08-05-2001 10:57 PM
Quick Reply: Cruise control wiring harness question
