vortec headers?
Old 11-02-2007, 08:03 PM
91L31Lo3's Avatar
Car: 91 camaro, 83 rx7, 07 cbr600rr
Engine: 305, vortec heads
Transmission: t5
vortec headers?
OK here's my deal i put vortec heads on the maro, the stock exhaust has to go its been leaking for the last week but, the passenger side stock manifold holes don't match up, i can pinch the rear bolt hole with my fingers, it hangs past the head, is this normal for these heads? anyone got any ideas should i buy some(what kind)
Old 11-02-2007, 09:24 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: vortec headers?
back hole isn't needed if you're talking about the 7th extra bolt hole. only need the 6 bolts. Definitely killing the whole point of vortec head swapping with stock manifolds, how about some nice tubular headers instead?
Old 11-02-2007, 09:57 PM
91L31Lo3's Avatar
Transmission: t5
Re: vortec headers?
i'm going to be getting tubular headers this weekend just tring to make sure that they are going to fit
Old 11-02-2007, 11:16 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: vortec headers?
On the exhaust side there is no difference between the standard SBC head ports and the Vortec head ports.
Old 11-03-2007, 02:03 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: vortec headers?
Yes there is a difference. The standard SBC heads have an extra hole on the back passenger side #8 cylinder (the #1 cylinder on the driver's side head). Vortec heads are missing that extra hole, and our stock exhaust manifolds require it. Headers will work with Vortec heads, no problem there.
Old 11-04-2007, 01:45 AM
91L31Lo3's Avatar
Transmission: t5
Re: vortec headers?
ok that what i was trying to say so should i get headers for a 305 or something else? or just sbc headers that will fit in the camaro? will pretty much every sbc header fit the vortec heads?
Old 11-04-2007, 04:29 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: vortec headers?
Get headers for a camaro. Sucks for you since you're in Cali, you'll have to get Headers with all the goofy emissions tubes and such, it'll cost you a pretty penny.
Look into Hooker 2055's, they should work with your stock catback, but Im not sure.
Old 11-04-2007, 10:27 AM
91L31Lo3's Avatar
Transmission: t5
Re: vortec headers?
alright thanks guys
Old 11-04-2007, 07:51 PM
Kevin91Z's Avatar
Re: vortec headers?
I guess when I said "headers will work with vortec heads, no problem there" I should have said ALL headers for thirdgens will work with Vortec heads.
And, the emissions tubes arent goofy, they are required by federal law to be on all street vehicles that came with them. That includes thirdgens.
The Hooker 2055's are a good choice.
Old 11-04-2007, 08:15 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: vortec headers?
Here's what I'm running with Vortecs: Hooker 2055's (Jeg's 520-2055). Catco high-flow converter (Summit CTO-9118). Hooker catback (Summit HOK-16823HKR).
JamesC
Old 11-05-2007, 08:22 PM
91L31Lo3's Avatar
Transmission: t5
Re: vortec headers?
i ordered the hooker 2055 earlier today thanks agian for the help
Old 11-15-2007, 01:45 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: vortec headers?
That's too bad.....
Old 11-15-2007, 09:55 PM
91L31Lo3's Avatar
Transmission: t5
Re: vortec headers?
thats pretty nice
z 28 jari
09-14-2021 10:03 PM
69GTOby
04-18-2016 02:34 PM
BLK87Z
09-18-2015 11:29 PM
89fast5oh
09-08-2015 09:55 AM
Quick Reply: vortec headers?
