Build sheet
Car: 86 Trans Am
Engine: 305 LB9
Build sheet
Hey guys,
Anywhere I can look up my build sheet? I can't find any places online. Pontiac dealers are now just dust, and the GM dealer around here is way more interested in selling me some brand new junk instead of any help really (offered to pay for the sheet). Thanks!
Community Administrator
Re: Build sheet
Keep in mind there is no way to get a copy of a buildsheet beyond the original in the car that may or may not be there. Only a copy of an invoice with list of major RPO codes is available, which is what the company AmorgetRS linked will provide.
Car: 86 Trans Am
Engine: 305 LB9
Re: Build sheet
Yeah I've done some further browsing and I'm pretty sure its gone forever. Looked everywhere in the car. Unfortunate but it happens. And I got an Ohio built bird, so one day when the car looks more respectable I'll buy the invoice and all that good info from phs
Reason I wanted it was to confirm I had a ws6.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Build sheet
John
Re: Build sheet
www.phs-online.com is your best option unless your car happens to be a Canadian export
Re: Build sheet
That badge was also included on Trans Ams without WS6. Meaning, that badge does not conclusively mean WS6.
A few old discussions:
https://www.thirdgen.org/forums/hist...ml#post1201519
https://www.thirdgen.org/forums/hist...ml#post5418215
https://www.thirdgen.org/forums/hist...ml#post4800682
Also, one of my Trans Ams does not have the WS6 but does have the badge.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Build sheet
I've come to the conclusion that,some got them and some didn't.but it should be noted that for 86 ALL Firebirds came with Modified front MacPherson struts and Rally Tuned Suspension,(I'm taking that as it was a option for previous years)but the Gas Filled Shocks was for the WS6 Package only.
Re: Build sheet
There were 3 suspensions available for any given year.
Going off memory here
- FE1 The Base Camaro or Base Firebird suspension for any given year.
- F41, which is the optional suspension for Camaro SC's, RS, etc. not really sure if the Base Firebird was ever given this option... This was the BASE Suspension for the Z28, and the Trans Am. This would have garnered the "Performance suspension" emblem on the dash of the Firebird line.
- FE2 / WS6 - This was the BASE Suspension on the GTA & Formula & IROC, it was also the optional suspension on the Trans Am and Z28... (again you would get the "performance suspension" badge on the dash.)
I am not sure if the 91-92 Z28 got the FE2 as the base suspension or not.
