List of 71 original GM 3rd Gen Part Numbers!!
Old 08-06-2015, 02:24 AM
1992 Trans Am's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
Hey everyone,
I am meticulously restoring my 1992 Trans Am convertible, with a factory 5 speed manual. I have been doing a lot of research and have put together a list of part numbers for 71 NOS Items I have purchased (and a few that I am still on the hunt for) so far for my car. I will add more part numbers to this list when I have more time! I thought it could be helpful to other members who might currently be looking for these parts too, or someone in the future who might want or need some of them. So, here it goes, in no particular order:
1. GM P/N: 10036629 power window switch. for both the driver and passenger window
2. GM P/N: 10037972 center console ashtray lid
3. GM P/N's: 12510764 (RH) and 12510765 (LH) Horizontal window convertible top weather strippings
4. GM P/N's: 12520807 and 12520806 vertical window convertible top weatherstrippings (Left and right)
5. GM P/N: 12504727 rear convertible top weatherstripping
6. GM P/N: 12520107 clear convertible tonneau cover protector sheet
7. GM P/N's: 12504732 and 12504733- The left and right side door jamb weatherstripping caps right next to the area when the front seat belts retract into the rear quarter panel trim area
8. GM P/N: 20514714 door panel screw trim w/ firebird phoenix logo
9. GM P/N’s: 19207617 and 19207200 - Left and Right Headlight Motors
10. GM P/N: 10034186 GM radio and hvac trim plate
11. GM P/N: 14038655 waffle pattern brake pedal cover
12. GM P/N: 14038638 waffle pattern clutch pedal cover
13: GM P/N:10126477 grey leather manual trans shifter ****
14. GM P/N: 10051992 Firebird phoenix front bumper decal
15. GM P/N's: 5975533 and 5975534 trans am taillights (1991-1992)
16. GM P/N: 10181782 Manual trans center console shift plate
17. GM P/N: 10037846 Center console assembly
18. GM P/N’s: 12337844 (LH) 20364442 (RH) black mirror to body gaskets
19. GM P/N: 19301809 spark plugs (platinum)
20. GM P/N: 19154579 Spark plug wire set
21. GM P/N: 10105135Thermostat housing gasket
22. GM P/N: 26016661 Rear differential gasket
23. GM P/N: 88900330 Posi Additive
24. GM P/N: 4587931 New outside door lock gaskets
25. GM P/N: 230018 Exterior door lock cylinder covers
26. GM P/N: 19166099 Distributor cap
27. GM P/N: 10496798 Distributor Rotor
28. GM P/N: 10120056 Upper radiator hose
29. GM P/N: 10120070 Lower radiator hose
30. GM P/N: 20632681 Interior door lock *****
31. GM P/N: 10105246 Serpentine Belt
32. GM P/N: 25171792 Fuel Filter
33. GM P/N: Oil Filter NOS correct one is a PF25
34. GM P/N: 10164142 Gas cap
35. GM P/N: 10409635 Radiator cap
36. GM P/N: 15630112 Coolant overflow tank cap
37. GM P/N: 10139568 Trans Am door decals in silver for both doors
38. GM P/N: 10051976 Trans Am silver rear bumper decal
39. GM P/N: 14109217 Hood to cowl weatherstripping
40. GM P/N: 10103279 The black rubber seal/gasket that goes around the front windshield
41. GM P/N: 10135310 Heater Hose
42. GM P/N: 10272096 Rear Exhaust muffler hanger
43. GM P/N: 10026085 Catalytic converter exhaust hanger (T5 cars)
44. GM P/N: 10105257 Evap/purge canister vacuum hose assembly
45. GM P/N: 14094720 Air intake rubber boot to throttle body
46. GM P/N: 10108427 Air intake long plastic tube from housing to rubber boot
47. GM P/N: 20540786 RH grey door sill trim piece
48. GM P/N: 20540787 LH grey door sill trim piece
49. GM P/N: 12500234 RH grey convertible seat belt assembly
50. GM P/N: 12500235 LH grey convertible seat belt assembly
51. GM P/N: 10052356 WS6 black/gold center caps
52. GM P/N: 10107650 RH bumper retainer bracket
53. GM P/N: 10107651 LH bumper retainer bracket
54. GM P/N: 12510763 Header and windshield weatherstripping (Convert)
55. GM P/N: 17988696 Pontiac Air Bag assembly
56. GM P/N: 10105287 Crankcase Ventilation Tube
57. GM P/N’s: 20350900 and 20350901 LH and RH door weatherstripping
58. GM P/N: 14079634 Wonder bar steering brace
59. GM P/N’s: 12520806 and 12580807 Vertical door window to top weatherstrippings (LH & RH)
60. GM P/N: 25043504 Air Filter
61. GM P/N: 10135312 Heater Hose
62. GM P/N: 14038655 Brake pedal cover
63. GM P/N: 14069107 Center console rear ashtray
64. GM P/N: 8995284 or CV789c PCV valve
65. GM P/N’s: 10124264 (RH) and 10124265 (LH) Exterior door window belt moldings
66. GM P/N: 17927383 Sun visor bushings
67. GM P/N: 10069174 Upper Radiator support plastic shrowd
68. GM P/N: 20638645 Exterior hinged gas/fuel filler door
69. GM P/N: 10164173 Rear frame bump stop/jounces
70. GM P/N: 12515799 Front interior #1 bow garnish molding (attached to the top)
71. GM P/N: 12509311 Front interior windshield garnish molding (convert)
gsmarcano (10-14-2023)
Old 08-06-2015, 11:43 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: List of 71 original GM 3rd Gen Part Numbers!!
Thanks for posting this. Got any pictures of your restoration/car? You never really see any stock restorations especially ones using all nos parts.
Old 08-07-2015, 09:05 AM
Polo Z03's Avatar
Car: 1992 Polo Green RS Z03
Engine: L03 - 5.0 Liter V8 TBI
Transmission: MD8 – 4 SPD Auto
Axle/Gears: GU2 - 2:73 Ratio
Camaro Related:
Others I've found: (typically searching for and/or from my 1992 Camaro RS V8
10120071 - HOSE, RADIATOR INLET (305 TBI)
10120070 - HOSE, RADIATOR OUTLET
10135311 - HOSE, HEATER WATER BYPASS VALVE INLET
10045204 - WATER NECK, THERMOSTAT HOUSING
12511116 - GUIDE, PASSENGER SEAT SHLDR BELT HEAD RESTRAINT (LT BEIGE)
12511117 - GUIDE, DRIVER SEAT SHLDR BELT HEAD RESTRAINT (LT BEIGE)
16604427 - STRUT, REAR COMPARTMENT LIFT WINDOW (Camaro RS)
10033125 - VALVE, FUEL TANK VENT
14083929 - DEFLECTOR, RADIATOR AIR LOWER
10164173 - BUMPSTOP, REAR AXLE
10198398 - MUFFLER (Camaro RS)
10078400 - SHIELD, FUEL TANK FILLER NECK
Old 08-07-2015, 05:26 PM
Axle/Gears: 3.08
I have been working on collecting all of the parts that I need for the restoration for the past 3.5 months. I have my parts separated and stored in 3 categories, which are the phases of the restoration that I'll be doing. First phase (beside collecting parts)= mechanical overhaul (which is what I am working on now) and refinishing of original wheels. Second phase= paint and body. Third Phase= interior and installation of all NOS GM weatherstripping and new top.
Old 08-07-2015, 05:28 PM
Axle/Gears: 3.08
Here it is in its current state...
bobycamaro (09-23-2022)
Old 08-07-2015, 05:29 PM
Axle/Gears: 3.08
Thanks for posting these part numbers! Hopefully we can gather more original GM part numbers from other members and have them all here on this thread!
Old 08-07-2015, 07:33 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
You do realize that there are thousands of part numbers for these cars. This one thread can't hold them all.
Old 08-08-2015, 07:43 AM
Polo Z03's Avatar
Best of luck on your project. Love seeing 3 gens earning their love. Been putting together a few mismatched parts for my Heritage RS.
Old 08-08-2015, 07:44 AM
Polo Z03's Avatar
Scott, yes and yes. But gotta share what we learn and know.
B_Dubya (05-03-2020)
Old 08-08-2015, 11:33 AM
Axle/Gears: 3.08
Polo! Absolutely correct. And there are going to be a lot of parts/part numbers that won't get posted because there are many parts on these cars that are simply unobtainable NOS or never break or wear out. We just try the best we can to help each other out with our third gens so people can restore and maintain them and keep them alive!
Old 08-08-2015, 05:54 PM
wcbrown1967's Avatar
This is cool, I just picked up a 92 RS camaro for my son, it has been seating for a while outside. We got about a yr and a half to gather parts and install. At first I thought you had this list for sale. I was about to grab a notebook and make a list to send you. Lol.
I am new to 3rdgen s so this will be great resourse for me.
If your wondering got 72 Z28 and for dd duty a 02 Z28 that shares duty with my 2010 CTS-V as my dd.
Can't imagine why I stay broke. Hope all had a great weekend.
Wes
Old 08-10-2015, 09:01 PM
Axle/Gears: 3.08
Haha wcbrown1967! I can totally relate! In any event, I have been collecting parts for a few months now, and I have had several other third gens in the past before the one I currently have (which I'll never get rid of!). So I have some duplicate and extra parts that I might be able to help you out with. What are you looking for? PM me your list, and I'll see if I can help you out!
Old 11-02-2015, 08:36 PM
irocracer87's Avatar
Car: '87 IROC Z28 , '90 IROC 1LE
Engine: 5.7 TPI , 5.0 TPI
Transmission: 700R4 , 5-speed
If anyone is needing a GM part #....I have a GM 1982-92 F body parts manual....feel free to message me and I'll look the number up for you.
Old 11-03-2015, 06:36 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I bought this off of Ebay when I decided to restore my TA, it literately has thousands and thousands of P/N
TTOP350 (06-13-2022)
Old 11-29-2015, 05:56 PM
RockinGTA89's Avatar
Car: 1989 GTA Trans sold :(
Engine: 350 TPI L98 (B2L)
Transmission: TH700 R-4
what's up ya'll. Saw this post, thought i chime in as well about the OEM part numbers. I want to mention despite that i don't have a Thirdgen anymore, however i'm always wanting to be involved with them and also like to help fellow thirdgen owners with their rides.
Awhile back i bought a OEM GM dealership parts and illustration catalog for 82-92 Pontiac F-body cars. This one is the 2nd revision edition and it's got ton of pages of OEM parts #. Of course we all know that quite a few of them have been superseded and also may no longer be available. But for those looking for OEM part numbers for the birds please send me a PM and I'll do what i can to help out as well....
Attached Thumbnails List of 71 original GM 3rd Gen Part Numbers!!-img_20151129_173232.jpg
Old 04-05-2016, 08:47 PM
Axle/Gears: 3.08
That's awesome! Thanks for offering that!
Old 04-05-2016, 10:20 PM
Drew's Avatar
Received 1,052 Likes on 748 Posts
There are several GM dealers with websites setup to sell parts online. Many use the diagrams from the Parts & Illustration manuals, and the GM Parts counter computer application. Probably 90% or better of thirdgen parts are discontinued, but the numbers help when searching ebay for NOS, etc. The #1 advantage of using the dealer's websites, is that they'll have the latest revision, while many of the Parts & Illustration manuals only go up to 1991.
Old 11-04-2017, 07:00 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Just curious if anyone out there might have any of these NOS parts. If so, either reply or PM me with what you have and what you would be asking for said parts.
Old 11-04-2017, 08:22 PM
Drew's Avatar
For future reference...
The 82-92 Firebird Parts and Illustration catalog in PDF form is posted in this thread -
https://www.thirdgen.org/forums/hist...oly-grail.html
Direct link =>https://drive.google.com/drive/folde...nNhUXl3d0dXRWc
Most of the 82-92 Camaro Illustration catalog is available on the Austin Thirdgen page -
http://www.austinthirdgen.org/parts/html/main1.htm
Old 11-04-2017, 09:28 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
I'm so glad this post was brought back, I've been looking for the Leather shift **** PN for what seems like forever lol!
Old 11-05-2017, 12:57 PM
Axle/Gears: 3.08
It’s amazing that over 290,000 views have happened to this thread! I have a lot more p/n’s to add eventually
Old 12-16-2018, 05:35 AM
sshoureas's Avatar
For anyone interested, SMS Fabrics in Oregon has the original, date-coded proper material. I had Princess from Lethal Interiors make new seat covers for mine, the door panels are next. I already have the new fabric but as it has to be sewn down near where it meets the carpet I'll be having a local auto upholstery shop do it. BTW- I love Princess's work on the seat covers and the support the new seat buns provide!
Hotrod383 (12-08-2020)
Old 02-03-2019, 04:10 AM
bronson/monty's Avatar
Car: 1984 Z28 Camaro
Transmission: T5 manual
Axle/Gears: 10 bolt 3.73
HI there,
I have a NOS console lid for 85 T/A onwards. Not in a box but never fitted. Stored in a garage for 20 years . No cracks, marks or colour fading. As new.
i am base in Australia.
Old 02-27-2021, 04:30 PM
Don Ho's Avatar
Wow , Thanks !
Old 06-13-2022, 10:18 PM
highrise's Avatar
Here’s what I have with Moog 5662 next to stock front. Won’t fit. 87gta. You guys sure that’s what you got? Why the difference??
Old 06-14-2022, 10:01 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Sub'd
Old 05-10-2023, 06:49 PM
sleverogers01's Avatar
Originally Posted by chazman
Sub'd
Fastest I've been was 155 on a turnpike. I have a JY 5 speed with 232 gears. I've had a few mild mods. 3 inch dual with double cats fuel pump and upgraded injectors and some igintion system upgrades and a K&N filet. no headers still rocking the manifolds and a mild cam from what the previous owners have said. thing rips like a champ though.
Old 05-10-2023, 07:19 PM
LeonardS's Avatar
Welcome to ThirdGen! I’m guessing that you posted on the wrong thread. This one has nothing to do with top speed.
mantaguy (05-11-2023)
Drew
04-30-2019 11:26 PM
1985blktransam
09-13-2009 08:16 AM
jodylee8310@aol
06-21-2003 09:35 PM
Quick Reply: List of 71 original GM 3rd Gen Part Numbers!!
