I found the build sheet!
Car: 1983 Camaro Sport Coupe
Engine: 305 4bbl
I found my build sheet, or at least a copy of it. It was on the passenger side of the trans tunnel with the seat belt buckle stud bolted through it.
Car: 1992 Polo Green RS Z03
Engine: L03 - 5.0 Liter V8 TBI
Transmission: MD8 – 4 SPD Auto
Axle/Gears: GU2 - 2:73 Ratio
Re: I found the build sheet!
Cool . . jealousy ensues . . . still haven't found mine . .
Engine: 305 4bbl
I had almost given up. The hole you see in it, is where the passenger front seat belt buckle stud was drilled through it into the floor board.
So the build sheets on all thirdgens are stuffed somewhere between the carpet and the steel unibody?
Engine: 305 4bbl
I don't know that for sure. I found part of one screwed into the tunnel under the center console glove box, that I think was ripped off on delivery, and then this one. Some say there is also one above the gas tank, I'll let you know in about a week when I drop it.
I couldn't even tell you how many thirdgens I've had the carpet out of... Some of which were untouched before I got there. The only "build sheets" I've ever found are between the springs and foam on the under side of the front seats. I've yet to find one under the carpet, or in a door panel, or under the interior panels as some people have reported.
That's why I'm in no hurry to pull the rest of the interior out of my cars to try to find something that might not even be there.
Engine: 305 4bbl
I agree that I wouldn't purposely tear apart the car looking for it. I'm currently tearing down my '83 for a complete restoration and so eventually I'll come across them.
Nice find. I am also jealous. Hoping I run across mine one day, but like its been said, I dont want to tear apart my car for something that might not exist.
