Period correct NOS vs Real Factory
For example the big exhaust clamp at the muffler on the big single systems from the late 1980's.
Clamp NOS part assy number #3634389 which includes clamp 11257765 and 257766 hardware set including washer and nut 2436164 and 11501033.
Re: Period correct NOS vs Real Factory
The Factory also used Clamp assembly 1257765 and 1257766 so that is good.
Here's the difference... The assembly used at the factory used a nut with a capive washer which needs to be sourced seperatly to be correct.
Engine: 4++,350 & 305 CIs
Nice to have that detailed info, thanks!
Here is another comparison... The big clamp at the converter originally was part # 14089474. This clamp was superceeded by # 15529483, both clamps are identical on a visual from the faces.
The exhaust clamp #1257766 is listed as 2-1/4": https://www.corvettecentral.com/c3-6...e-clamp-322151
The catalytic converter clamp #15529483 is listed as 3" : https://www.wheelerfleet.com/product...3-clamp/115644
