Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
What class will I be in? Scca autocross
Old 05-10-2012, 07:07 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
The 20th will be my first time autox my 92 z28 in a scca autox event. I've raced it in some local porche club events but they are pretty laid back and do not put you in classes. I'm more about just having fun than getting too competitive but I do attend mos of the events in my area. My car is a stock lb9 auto 2.73 posi car only mods are 3in magnaflow high flow cat and 3in catback trimmed moog springs 1 coil in the front and 1 3/4 rear founders tubular adjustable poly/rod lcas and Panhard rod and lcarbs. Racetronix fuel pump/harness kit. I'm just on some doral 245/50/16 tires. In the process of trying to pickup an extra set of wheel and some good autox only tires. Really trying to figure out which class I should be in? I per registered for stx but unsure if that's where I should be. He car will get sfc strut bar and wonderbar still this season.
Old 05-10-2012, 11:26 PM
Midniteson2's Avatar
Car: 1991 Firebird
Axle/Gears: 3.42 w/auburn racers diff
Re: What class will I be in? Scca autocross
With those mods you can register in ESP (E stock prepared)
Old 05-10-2012, 11:29 PM
Screamin86's Avatar
Ok cool that's also what I was thinking but wasn't sure it's been a Lon time since I've ran a scca event last one I did in my own car was a stock 98 Camaro 3.8 y87 car I dominated the gs class with it lol. Last event I went too a month ago I drove a sts miata that was a TON of fun. I know until I get some tires I will not be too competitive but I'more worried about building the car how I want for everyday use over staying in a specific class.
Old 05-11-2012, 08:43 PM
slow305's Avatar
Car: 1982 Z28
Engine: LC9
Transmission: AR5
I think the rear LCAs would put you in ESP, not legal for STX. ESP would probably be more fun anyway since it's mostly other pony cars.
Pat
Old 08-01-2014, 10:16 AM
92camaro350's Avatar
I know this is an old thread but I was wondering if you ever raced and figured out what class you would be in? I would like to get into auto cross as well and I have founders poly/rod end lca's and LCARBs and from what I am reading in the rules for ESP that is not allowed?
Old 08-04-2014, 05:37 AM
Homer23's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
You are in C Prepared.
Old 08-19-2014, 01:21 AM
B4CHawk's Avatar
Car: 2004 Mazda RX-8
Engine: 1.3l Renesis
Axle/Gears: \
Yup; rod ends on a LCA bump you up.
Old 03-21-2018, 02:50 PM
Jared57's Avatar
Car: 92 Camaro
Has anyone raced their third gen in SCCA CAM class? If so how did you compare against the other cars?
Old 03-21-2018, 03:26 PM
Krye3rdGen's Avatar
The rules are so open in CAM that you have to put a stupid amount of work in to be competitive nationally.
That being said, most regional guys just go to CAM because they don't know what class to go into and their buddies are running in CAM so it doesn't really matter. Just jump in CAM till you figure out what your car would be classed as and would be competitive in that class.
Old 03-21-2018, 04:26 PM
Beater79TA's Avatar
This is definitely the case. If you only plan on running locally, enter the car in CAM and have fun. If you want to win nationally, think like an engineer and find a car / class combination that can be exploited for a win. CAM will, most likely, not be that class with a thirdgen.
BrianChevy
Wheels and Tires
08-08-2019 02:16 PM
PurelyPMD
05-05-2016 04:57 PM
webeeZ28
09-14-2015 12:00 PM
Brian Anderson
Wheels and Tires
09-12-2015 06:12 PM
scottmoyer
09-07-2015 07:06 PM
Quick Reply: What class will I be in? Scca autocross
