Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
AN fuel routing?
Old 02-23-2014, 08:42 PM
Jferguson1302's Avatar
AN fuel routing?
I have a sump on the factory tank, and was wondering where you guys are routing yours?
Old 02-24-2014, 07:52 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Re: AN fuel routing?
mine is down the passenger's side of the car, more torwards the subframe connector, then is snaked into the front subframe in front of the transmission crossmember where it goes into the engine bay and then comes out of the "frame rail" just behind the idler arm mount. i have a number 8 feed and a number 6 return both run there. I need to try to take some updated pictures of it.
Old 02-24-2014, 08:17 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I ran mine in the factory location. It's a carb'd setup with no return. I used 1/2" rigid line up to the firewall where it adapts to -8AN, goes over the bellhousing and then to the regulator which is mounted where the heater box used to be.
Old 02-24-2014, 09:07 AM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I have -8 supply and return to the stock tank at the top w/ a walbro 400 lph pump. Stock routing to a Mallory regulator.
Old 02-24-2014, 11:52 AM
Thanks guys, I was wondering cause the NHRA rules on routing fuel line had me thinking maybe it couldn't be in the factory spot(running beside the tranny)
Old 02-24-2014, 09:16 PM
Old 02-25-2014, 04:24 AM
mw66nova's Avatar
Engine: 7.0L
Regulator can't stay there if you intend to race the car
Old 02-25-2014, 06:29 AM
Whys that?
Old 02-25-2014, 06:54 AM
mw66nova's Avatar
Engine: 7.0L
NHRA/IHRA Rules. regulator must be 6" forward of the plane of the flywheel. mount it to the engine man, way cleaner anyway.
from the rule book:
1:5 FUEL SYSTEMS
Location: All fuel tanks, lines, pumps, valves, etc. must be outside
of the driver’s compartment and within the confines of the frame
and/or steel body. Cool cans, fuel-distribution blocks, etc. must be
located at least 6 inches forward of the flywheel/bellhousing area on
rear-wheel-drive (RWD) vehicles, and on opposite side of
flywheel/housing area on front-wheel-drive (FWD) vehicles.
Fuel
pressure gauge isolators, with steel braided line, may be mounted
on firewall.
Old 02-25-2014, 07:06 AM
Darn, lol, thanks!
Old 02-25-2014, 07:14 AM
mw66nova's Avatar
Engine: 7.0L
like this
Old 02-25-2014, 08:40 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Never had a track question a regulator position. Mines been back behind engine on firewall since 2009.
Anyway i run up stock location because exhaust runs down passenger side
Old 02-25-2014, 08:56 AM
mw66nova's Avatar
Engine: 7.0L
With the possibility of a clutch explosion now on my car, i won't want the fuel stuff anywhere near the flywheel area, lol!
Old 02-25-2014, 02:14 PM
Car: 91 Firebird
Engine: Turbo 355
I routed mine up and away for this reason. I might run into this sooner than later...
Old 02-09-2016, 10:24 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
Do you have any pics of where you ran the lines? Did you have to drill holes in the frame rails? I am looking to run the same size lines, but was planning to stay on the driver side.
Old 02-10-2016, 05:35 AM
mw66nova's Avatar
Engine: 7.0L
passenger's side right behind where the idler would mount:
yes, you have to drill holes.
Old 02-10-2016, 07:48 AM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Thanks for the pics. Looks good and well protected.
Without cutting, I was having a difficult time with my line routing in a manner that didn't make them susceptible to damage.
Where did you cross over from the driver side sender lines to passenger side?
Old 02-10-2016, 09:02 AM
mw66nova's Avatar
Engine: 7.0L
my tank has a sump, so it comes out of the sump and goes to the passenger's side.
Old 02-10-2016, 02:23 PM
no green's Avatar
I run at 3 tracks, and all of them will boot you for having the regulator on the firewall (and ironically, let you run with bigger infractions)
i ran mine through the framerail, and mounted the regulators here. I drilled a hole in the frame back by the transmission, and here, and ran a -8 line through the frame.
Old 02-13-2016, 08:40 AM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
Here's how I did it, this is for a FI LS swap used the stock sending unit and unmodified 3rd gen tank. I took these pictures before I finished the fuel system, I've since added in grommets on everything to keep it from damaging the lines.
Using the Corvette fuel filter the return line goes back to the tank, the feed line now loops back around and heads towards the front of the car.
Then runs through the subframe connector.
Comes out there and through a hole I cut on the inside of the fender where it eventually passes through another hole just underneath the rail the fender is bolted to. Again, everything has grommets on it now, that fuel system should outlast the car.
Old 02-13-2016, 08:48 AM
mw66nova's Avatar
Engine: 7.0L
through the sfc's ftw
Old 02-13-2016, 11:32 AM
khulsebus's Avatar
Car: '89 Camaro
That was side work I did for a buddy, on mine when I get back I'm thinking about doing it similar to how mw66nova did his.
92camaroJoe
07-29-2023 07:57 PM
Jote4805
08-25-2015 06:11 PM
kah992
08-19-2015 02:55 PM
92camaroJoe
08-13-2015 06:07 AM
mx127
08-10-2015 08:13 AM
Quick Reply: AN fuel routing?
